1. eNewsletter Sign Up
The Toolkit Thread
Discussion in 'Equipment' started by hilslamer, Sep 2, 2007.
  1. bkoz
    bkoz Been here awhile
    Dec 6, 2008
    684
    Kamloops, BC
    Or just use the teeth of the rear sprocket
  2. deep6blue
    deep6blue Been here awhile
    Sep 25, 2015
    126
    USA
    I've never had an issue sealing a bead with CO2 or a small electric pump. It's all about putting a little pressure on points where the bead is loose.
    SmittyBlackstone likes this.
  3. Snake Oiler
    Snake Oiler If the world didn't suck, we would all fall off
    Apr 22, 2016
    3,700
    Pennsylvania, but living in a toy hauler full-time
    And lots of lube
    Wesley J and outbacktm like this.
  4. AllSeasonRider
    AllSeasonRider Wandering, maybe a little lost...
    Feb 20, 2008
    2,751
    Los Angeles, CA
    I don't have much experience with CO2, but when trying to mount a new MotoZ on my 1090 (very stiff tire), I watched the fog of the CO2 cartidge blast out through the bead on two attempts. I ended up getting it seated with a regular pump using a ratchet strap and *just* the right amount of pressure. Took me hours. I'd have been hosed on a trail, which is why if you're riding off road and tubeless, bring tubes!
  5. Cabrito
    Cabrito On the mend 76% Supporter
    Jul 25, 2007
    542
    415
    This ^^^ all of it.
  6. oughtsix
    oughtsix Reverse Engineer
    Oct 11, 2013
    534
    NELA
    Building my tool kit right now, and wanted to share my axle wrench solution.
    I believe in supporting the awesome vendors and such, but at the same time, I'm a low budget guy. Frugal. Tight-ass. Call it what you will. I'd like to blow a wad on the motion pro tire iron/wrench combo. But I work in an industry where we are good at making do. It's second nature.
    Regardless, I had a half-drive impact socket kit from Harmless-Fake that just so happened to have a 27mm included which fits my XRR rear.
    Rarely use it. Have other nicer chromed stuff.
    A little grinder and 7018 later and we have this, fused with love to a tire iron.
    I started to hack away at a similar 17mm for the front then just happened to notice...it fits like a glove into the 27. A little more 7018 and some grinder action yields a 17mm socket with "dogs" on the outside that fits a 27mm 6 point like a glove.
    Next on the list is a driver solution that will take care of ratchet needs, and hopefully replace that fat-a$$ed 12-in-1 screwdriver. Something like THIS.
    I think I only need:
    1/4 drive adapter, and extension
    8,10,12,13 sockets
    4,5,6,8 hex
    45 torx (skid plate)
    jis 1, jis 2, slotted
    Vrode, GotFog, Kinsman and 3 others like this.
  7. 250senuf
    250senuf Long timer
    Feb 17, 2008
    3,699
    Nelson area, Kootenai, BC, Canada
    Nice tool mod!
    So? what happened to that thumbnail, looks painful?
  8. Gedrog
    Gedrog 1000 mile stare a 1000 stories to tell
    Oct 20, 2013
    2,930
    Lost in the Sahara
    That issue is all over the site thumbnails showing up blurry click on it and it shows clearly
  9. 250senuf
    250senuf Long timer
    Feb 17, 2008
    3,699
    I meant the purple from an impact
    SmittyBlackstone and oughtsix like this.
  10. oughtsix
    Oct 11, 2013
    534
    NELA
    Let’s just say I’ll hold the hammer with both hands next time
    tonyubsdell and SmittyBlackstone like this.
  11. BornAgain
    BornAgain Been here awhile
    Aug 31, 2008
    800
    Rosenberg, TX
    Your only supposed to hit it twice :lol3
  12. brianbrannon
    brianbrannon They'll ride up with wear
    Dec 15, 2009
    1,908
    Denver, CO
    You can get a 45 Torx bit with a 1/4 drive end from MAC tools
  13. cpallen
    cpallen Nearly Adventurer
    May 26, 2003
    1,720
    Panora, IA
    outbacktm, Zubb, Snake Oiler and 6 others like this.
  14. flei
    flei cycletherapist
    Apr 1, 2013
    10,088
    Western Mass.
    cpallen and JimVonBaden like this.
  15. Fastman
    Fastman Been here awhile
    Sep 15, 2002
    683
    Webster Groves, MO
  16. cpallen
    May 26, 2003
    1,720
    Panora, IA
    Snake Oiler likes this.
  17. krussell
    krussell Gravel Warrior Supporter
    Nov 19, 2009
    4,217
    Portland, Oregon
    outbacktm, cpallen and Fastman like this.
  18. JimVonBaden
    Feb 11, 2005
    88,548
    Alexandria, VA
  19. Zubb
    Zubb he went that-a-way... Supporter
    Sep 8, 2002
    2,852
    San Diego
    Tool Porn.
    Repent and be saved (from the wrath of Wife).
  20. cpallen
    May 26, 2003
    1,720
    Panora, IA
    JimVonBaden likes this.
