The Toolkit Thread
Discussion in 'Equipment' started by hilslamer, Sep 2, 2007.
  1. JimVonBaden
    Feb 11, 2005
    90,988
    Alexandria, VA
    Apparently.
  2. keepshoveling
    keepshoveling DNF
    Oct 9, 2014
    4,798
    NYC
    Try it. You might like it.
  3. JimVonBaden
    Feb 11, 2005
    90,988
    Alexandria, VA
    Other than hack fixes, most pliers will do it screw up nuts and bolts. I generally use them only after someone else has. No need for them if you have the right tools!
    AllSeasonRider and 2talltom like this.
  4. keepshoveling
    keepshoveling DNF
    Oct 9, 2014
    4,798
    NYC
    so you’re telling me there’s a chance?
  5. Solo Moto
    Solo Moto Hands are bruised from breakin’ rocks all day
    Apr 13, 2014
    427
    Northern Idaho
    :lol3
  6. HellSickle
    HellSickle Scone Rider
    Sep 19, 2005
    21,317
    Fort Collins
    Apologies if this is 205.
    I'm looking for a tool carrier that will fit under my left pannier rack on a KTM 790. My 990 had an aftermarket 2:1 exhaust, and the left muffler was replaced with a very nice tool tube that would fit a lot of spare parts and tools.
    I found this that I can probably make fit.
    https://www.wish.com/product/5b30ca...R83Z820Fb3glDlJn4i_e3RoC48wQAvD_BwE&share=web
    FYI, I'm aware of the generic plastic tool tubes and already have a spare floating around. Looking for something sturdier and roomier.
  7. dsilver1007
    dsilver1007 Long timer
    Jan 15, 2013
    1,838
    Honea Path SC
    That is pretty cool!
  8. 9Realms
    9Realms Drawn in by the complex plot
    Jul 23, 2010
    6,032
    Central Minn.
  9. advdoctor
    advdoctor Been here awhile
    Sep 18, 2009
    237
    Interior Alaska
    This is my 790 dilemma as well, but your link no worky. Can you repost or give brand and model number?
    thx
  10. brianbrannon
    brianbrannon They'll ride up with wear
    Dec 15, 2009
    2,260
    Denver, CO
    You obviously haven't tried them
    Luckycharms, Wattner and Valker like this.
  11. JensEskildsen
    JensEskildsen Long timer
    Mar 24, 2009
    2,244
    Denmark
    Theese have smooth jaws.
    I have smal cut down tire levers, and use the knipex as a rear axle wrench, an axle wrench that fit not only my bike but everyone elses. I have 4 bikes, and theres 3 different sizes of rear axle nuts. (22, 24 and 27)
    It will also tighten the 19mm footpeg bolts, remove a sparkplug from a dt125r without removing the tank/fairings ect ect.
    So I saved some weigh and bulk for tire levers/axle wrench and a sparkplug socket, and got a more versatile tool instead.
    For me it flat out works.
    I also bring feeler gauges, tow strap, spare clutch and brake lever, jb weld, spare masterlink, a piece of fuelline, a few different bolts, washers, and locknuts ect ect ect based on what I've needed to get people home. I've rarely needed much myself, but if some guy breaks down, we all stop anyway.
    A bmw rider lent a spare clutch lever, I've fixed a few broken chains, I soldered a fresh clutch cable with a jetboil stove, helped to fix a dusin flats, set the valves on a ticking exc400, reinstalled someones exhaust when he lost it becauese a bolt backed out (hence my bolt kit), tightened a few loose chains, and loosened a few tight ones, installed a hose clamb on a ktm 950 where the front sprocket nut came of. Based on that, i bring shit with me. My kit still only takes up a bit more space than a 6pack (excluding spare tubes, and depending if i bring a pump or only co2)
    I use the same tools in the garage for maintenance.
    We're all different, and hopefully here to share our experiences.
    outbacktm, Chalkie62 and flei like this.
  12. JimVonBaden
    Feb 11, 2005
    90,988
    Alexandria, VA
    I have. They are the best hack tool you can buy! But, why not use the right tool. A tool kit should be well thought out, not just filled with expensive tools you may never need.
    2talltom likes this.
  13. Dirty bike
    Dirty bike EricV
    Apr 10, 2011
    1,745
    Tupelo, MS
    Are you aware of the GIVI S250 that's similar? Internal divider, water proof with a gasket. They have a universal kit and the lid can go on with the lock up or down for flexibility. Not that hard to roll your own mounting kit. I don't think they offer an over priced mounting kit specific to the 790 yet.
    Chalkie62, Bowler, Spyrious and 2 others like this.
  14. SteelB12
    SteelB12 Our Purity of Essence Supporter
    Mar 6, 2009
    5,760
    South Central, VA
    I wonder if that would work on a KLR with Happy Trails rack and cases??
  15. TigerDude
    TigerDude Adventurer
    Jul 21, 2015
    20
    Acworth GA USA
    That's the thing - these aren't channellocks with grooves to screw up any nuts you find. They're smooth, adjust to nut size, and work amazingly well.
    Luckycharms and Wattner like this.
  16. brianbrannon
    Dec 15, 2009
    2,260
    Denver, CO
    I think you must be thinking of a different tool.
  17. RichBeBe
    RichBeBe All Hail Seitan!!! Supporter
    Mar 13, 2004
    7,539
    NYC
    I agree and carry a well thought out kit with what I will likely need. I use my tools in my kit at home to test things, and feel good about what I have in my it.
    With that I carry a small Knipex as a hack tool, you never know when you won't have the right tool, need to improvise something, etc, etc. The weight penalty is not a ton and if I use it once to get out of a jam it is worth more than I paid for it.
  18. JimVonBaden
    Feb 11, 2005
    90,988
    Alexandria, VA
    To both, no.
  19. HellSickle
    Sep 19, 2005
    21,317
    Fort Collins
    Thanks. I found that one too. From my research it appears to be ABS. Sitting right over my chain and getting splattered with oil is not a good situation for ABS. I think I'll take my chances with the aluminum GS one. I will, of course, have to find rattle can paint in KTM orange :deal
    SmittyBlackstone likes this.
  20. Dirty bike
    Dirty bike EricV
    Apr 10, 2011
    1,745
    Tupelo, MS
    Err, you do understand that body panels and fenders are ABS, right? I've yet to see the underside of a fender painted. I suppose if you're using some odd toxic sludge on your chain...
    Resist the urge to paint it orange. There are multiple threads on every forum about what color code to use to match KTM orange. KTM, in fact, doesn't know either, so keeps changing it. :fpalm
