The TT600 Thread
Discussion in 'Thumpers' started by Zahnarzt, Mar 29, 2011.
  1. Fantuzzi
    Fantuzzi Been here awhile
    Jul 29, 2008
    214
    Germany, Niederrhein
    It is the stock gear lever, I guess.
    The bike is sold meanwhile.
  2. tscham
    tscham Been here awhile
    Mar 12, 2018
    100
    Seville
    Thank you for replying! Not the stock one, but looks really nice, though.
  3. Mr.JAJA
    Mr.JAJA Long timer Supporter
    Nov 29, 2010
    1,851
    San Diego, just north of BAJA "
    As I remember, the splines are the same. The lima housing on later bikes and 12 Volt XT can be different. But with being a XT steel shifter, you can heat it up and bend as needed.
  4. tscham
    Mar 12, 2018
    100
    Seville
    Perfect, thank you! Ok, if, whenever you can, you could tell me of the dimensions of the 86 XT600E's, I would very deeply appreciate it! Thank you very much for all the help!!
  5. Mr.JAJA
    Nov 29, 2010
    1,851
    This a XT600 from a 3TB motor and the short TT600 Aluminum version. 20210516_091805.jpg 20210516_091827.jpg 20210516_091916.jpg
  6. tscham
    Mar 12, 2018
    100
    Seville
    WOW, THANK YOU VERY, VERY MUCH!! Well, absolutely noticeable difference between the two, though my TT-RE's stock lever is different (and seems longer than the aluminium one you posted).
    Will try to source the XT 600's lever for a fair price, thought it might be difficult. Thank you very much for all your help!!
  7. tscham
    Mar 12, 2018
    100
    Seville
  8. Mr.JAJA
    Nov 29, 2010
    1,851
  9. tscham
    Mar 12, 2018
    100
    Seville
    Thank you, I will. But, on principle, can you tell me if it should fit my TT-RE?
  10. gaal_alexandru
    gaal_alexandru n00b
    May 17, 2021
    2
    Klausenburg
    Hy,
    For a TT600R (2000), are the following specs for the front wheel bearing and seal correct:
    BALL BEARING 6003-2RS. 17-35-10 & OIL SEAL(4DA) 22x35x5mm
    Does anyone know the size for the rear bearings and seals?
  11. Mr.JAJA
    Nov 29, 2010
    1,851
    I don't have a TT-RE to compare. the splines is what I see and there should fit. Bend and length, I don't know.
  12. tscham
    Mar 12, 2018
    100
    Seville
    I completely understand! Will order and try it out. Thank you very much for all your help!!
  13. ramoneTT600R
    ramoneTT600R Adventurer
    Apr 25, 2019
    16
    Slovakia
    Hey guys, here is small upgrade of my wheels - powder coated rims (black) and hubs (chrome and blue), stainless spokes :-)
    #TT600Rally #TT600R #YamahaTT600 #YamahaRally
    IMG_6918.JPEG IMG_6929.JPEG IMG_6927.JPEG IMG_6925.JPEG IMG_6919.JPEG IMG_6924.JPEG
    OzCRU and panterg55 like this.
  14. gaal_alexandru
    gaal_alexandru n00b
    May 17, 2021
    2
    Klausenburg
    Hy,
    From where could I buy repair kit for the front and rear brake master cylinder?
    From what other bike are the parts compatible?
    Also does the TT600RE wheal with cush-drive compatible to the TT600R ?
  15. Tritwin
    Tritwin Been here awhile
    Nov 8, 2011
    374
    Norway
    54541444-4048-4892-930D-65735892EBD9.jpeg Out for a ride today, to Faråsen bridge...
    Jeremy K, OzCRU, tuscan and 1 other person like this.
  16. Tritwin
    Nov 8, 2011
    374
    Norway
    B6BB8569-36D0-4A37-905B-DCAB81EBAB1A.jpeg Camping in Einunndalen ,Norway
  17. antonijn
    antonijn Been here awhile
    Jul 22, 2015
    241
    Netherlands
    Hi guys and girls!
    I'm a new TTR owner, and it's the most fun bike I've owned so far:clap.
    The bike is a 1999 Belgarda TT600R.
    It's currently in supermoto trim but it's got all the parts to build it back to original, which is what I'm doing.
    I also already have my first question, and I'm sure someone can help me.
    Is it possible to easily install a cushdrive on these bikes?
    A RE wheel might fit but those are quite rare in Holland...
    OzCRU likes this.
  18. AlicFat
    AlicFat RUS
    Nov 6, 2016
    6
    RUS
    Rolled around the North Caucasus - 5000 km
    2021-06-08 14-54-28.JPG 2021-06-08 13-53-28.JPG 2021-06-08 13-25-32.JPG 2021-06-02 13-03-35.JPG 2021-06-06 11-37-50.JPG 2021-06-08 09-35-50.JPG 2021-06-06 07-27-03.JPG
    Jeremy K, OzCRU, tuscan and 2 others like this.
  19. Mr.JAJA
    Nov 29, 2010
    1,851
  20. tscham
    Mar 12, 2018
    100
    Seville
    Hello, guys,
    I do have great luck all-round, but, sometimes, I hit the jackpot:
    Just snapped the top of the exhaust valve cover on my 2004 TT 600 RE.. This is the part:
    Does any of you have a suggestion on how to get if off? Dunno, weld another bit to and try to unscrew? Drill holes to try and get a hold of it? Try to break it to pieces? I also thought about using some Nural paste, which then hardens up just enough to reuse or enable unscrewing..
    Any advice is appreciated.
    Thank you very much.
