The TT600 Thread
Discussion in 'Thumpers' started by Zahnarzt, Mar 29, 2011.
  1. tscham
    tscham Adventurer
    Mar 12, 2018
    98
    Seville
    Unlike what was said, the needle for the main carb of the XT 600 E does fit that of the TT 600 RE. I ordered a kit from Aliexpress advised by someone that has a TT 600 R and the needle fits perfectly, just so anyone who's interested knows. The bike has actually more power on low and mid ranges, behaving better than before. No need to spend 10x more for an original part.
    I'm now trying to address one last issue which the bike already had before the needle broke. In 3rd, 4th and 5th gears (maybe in all gears, but I notice it in these three), when I open the throttle to the max (from 4/5 till fully open), the bike stutters and doesn't keep on reving/rpm drops a bit. As soon as I go back to 4/5 throttle, it starts revving up again. Any idea about what might be causing this?
    I've read about (and will try) taking the air filter out and checking if it improves, disconnecting the sidestand switch, buying a new slider/diaphragm for the secondary carb.
    As always, thank you very much in advance!!
  2. dzl
    dzl adventurer wannabe
    Apr 21, 2009
    281
    Adelaide, South Australia
    I dont think any one said the XT needle wouldnt fit? The difference is in the profile of the different needles. The factory uses specific profile to suit the characteristics of each bike. The biggest difference on the TTR is the difference in airbox size and the venturi size on the primary carb. Suspect it is now running richer at lower throttle sttings now. Check you r plug for colour after youve done a few kms.
    Did you check/ clean the rest of the carb when you had it out? Cleaned all jets? Removed float needle valve and check the cleanliness of the filter under the needle seat? sounds like it could be starving for fuel under full power ie running out of fuel in the float bowl
  3. tscham
    tscham Adventurer
    Mar 12, 2018
    98
    Seville
    Thank you for your answer. Did about 200km and the consumption is still the same as before I changed my needle--almost 6l/100km--, but I will check the spark plug's color, indeed. I will also check the filter under the valve seat, which in fact I did not check. Everything else was thoroughly cleaned with carb cleaner.
    Thank you!
  4. crazybond700
    crazybond700 Adventurer
    Oct 21, 2013
    27
    Once in a while we need a tyre discusion imo. Lol. I have a couple of sets of wheels of one needs new tyres for the road. Was thinking annakee, but not sure they are in the correct size available.
  5. tuscan
    tuscan Been here awhile
    Mar 20, 2010
    796
    Nu Ziland
    Pirelli MT21
    OzCRU likes this.
  6. brucifer
    brucifer Long timer
    Nov 27, 2007
    3,352
    Eureka, Ca.
    Hey guys, have a little issue going on with my 1984 model. Starts easy and runs great, as a rule. However, it seems as it warms up--or gets hot--the throttle response gets weird. It's as though the secondary carb. stops functioning.
    At first into the ride, it rips--great throttle response and power at all throttle positions. But in time. the throttle response gets sluggish, especially at smaller throttle openings. If you open the throttle more, the exhaust note doesn't change much and the bike doesn't accelerate properly then suddenly it takes off like it should. It never does this when first riding it, only after it has run for several minutes into the ride.
    The engine is built. 621cc, 11.5:1 compression, ported head, Web motocross camshaft, K&N air filter, stock carburetors with, I believe, stock jetting, stock exhaust with end silencer removed.
    Bike is a rocket ship when running properly. Probably only 4-5 hours of run time since complete rebuild.
    Any input is greatly appreciated!
    Bruce
    [​IMG][​IMG]
    OzCRU likes this.
  7. panterg55
    panterg55 Formely panterg Supporter
    Jun 18, 2010
    105
    Madchester UK
    20200804_132856.jpg 20200804_132912.jpg 20200804_133254.jpg 20200804_132856.jpg 20200804_132912.jpg 20200804_133254.jpg 20200804_132856.jpg 20200804_132912.jpg 20200804_133254.jpg
    OzCRU and Tritwin like this.
  8. panterg55
    Jun 18, 2010
    105
    Madchester UK
    Apologises for the post size - I'm a computer novice ! Long story short ... Sold my TT last year and bought the sister bike that me and a mate built last week :-). Plan is to fit the twin headlight fairing this month and a B& B bashplate when it arrives . Glad to be back ! All The Best Glenn
  9. Tritwin
    Tritwin Been here awhile
    Nov 8, 2011
    344
    Norway
    524B41C1-0137-49A4-9AE2-CD48309E2995.jpeg Touring Vinjevegen mountain road
    panterg55, tuscan and OzCRU like this.
  10. Tritwin
    Nov 8, 2011
    344
    Norway
    94BB00E4-B424-4B8F-94D8-ADB3C7B4E667.jpeg Ringebu Mountain , Norway
  11. Tritwin
    Nov 8, 2011
    344
    Norway
    Welcome back....looking forward to see the final result with the fairing:)
    OzCRU likes this.
  12. OzCRU
    OzCRU Long timer
    Feb 16, 2015
    1,063
    Sydney Australia
    Ditto what he said panterg55 ^^^
    Very nice bike!
    Tritwin - Beautiful shots
  13. panterg55
    Jun 18, 2010
    105
    Madchester UK
    Thanks Tritwin and OzCRU - Hope you are enjoying your travels Tritwin !
    OzCRU likes this.
  14. panterg55
    Jun 18, 2010
    105
    Madchester UK
    Hi All , Quick few pics of the fairing fitted , High Level rear led light and a 1200GS Touratech top plate mounted on a Kedo carrier . . . . . . Now all I need to do is fit the B & B bashplate when it arrives on Monday as well as the front fairing decal . . . and take the Ohlins rear shock ( TT600 R ) to be refurbished - then I'll be finished ! . . . . or will I ? :D
  15. brucifer
    brucifer Long timer
    Nov 27, 2007
    3,352
    Eureka, Ca.
    So no input on this issue??
  16. panterg55
    Jun 18, 2010
    105
    Madchester UK
    Now with the decals on and the B & B Bashplate fitted ! Only the freshly serviced Ohlins rear shock to fit . . . . . Cheers Glenn
  17. OzCRU
    OzCRU Long timer
    Feb 16, 2015
    1,063
    Sydney Australia
    That’s looking great Glenn!!
    panterg55 likes this.
  18. panterg55
    Jun 18, 2010
    105
    Madchester UK
    Thanks OzCRU !
  19. Mr.JAJA
    Mr.JAJA Long timer Supporter
    Nov 29, 2010
    1,839
    San Diego, just north of BAJA "
    Did you solve the problem? Check if the Carb slider is moving free, all air,vacuum lines are sealed, and the air cleaner clean with not to much oil(K&N type).
    brucifer likes this.
  20. brucifer
    brucifer Long timer
    Nov 27, 2007
    3,352
    Eureka, Ca.
    No, I have not. I'll check what you have suggested. Thank you.
