1. ** Enter to win a $250 gift card! We want to hear from you, please take this survey **
    Take this survey which covers a range of questions about improving the community, the things that interest you and anything else you want to share with us. All responses will remain anonymous.
    Click here to take the survey
    Dismiss Notice
The TT600 Thread
Discussion in 'Thumpers' started by Zahnarzt, Mar 29, 2011.
  1. Pawlie
    Pawlie Been here awhile
    Sep 26, 2004
    206
    Vancouver, B.C.
    Hey Bruce,
    I'm gonna chime in here with a possible scenario that happened to me on a non XT machine. Worth checking into.
    Bike would run great for 5-10 min then warm up and off idle response would go wonky(bog)...Bike would continue to run well at higher revs/ throttle openings.
    I chased perceived carb issues even swapped out carbs with a buddy who had the same bike.
    Exact same symptoms would show up. Pulling out my hair at this point and a guy on a forum pipes up and says check your coil!
    Coil changed...Instant solution to problem!
    Apparently there is more resistance in the electrical (spark)at idle/low revs..... Combine resistance + heat degradation =Poor spark at just off idle/. Again bike would rev up and pull hard at higher engine speed.
    Worth investigating.
    Good luck! Love your TT!
    Pawlie
    brucifer and OzCRU like this.
  2. brucifer
    brucifer Long timer
    Nov 27, 2007
    3,326
    Eureka, Ca.
    Thanks for the input, Pawlie. I don't think that's what's happening here but I'm willing to look into any avenue at this point. I have an XT600 that has a known good coil I can try.
    I'll give it a shot and report back.
    OzCRU likes this.
  3. jagerb
    jagerb Adventurer
    Jun 12, 2019
    34
    Amsterdam
    Small little update on the TT again: I did some work on the back end of the bike.
    - New exhaust
    - New fender
    - New taillight/licenseplate holder
    - New fenderbag
    The sound of the exhaust was absolutely obscene so i had to fabricate a baffle for it, worked out quite alright :)
    Only 1 little hurdle to overcome; the taillight is led, so naturally, 12 volt DC required. The TT generates 6 volt AC :) But i think i can come up with something to make it work.
    dtysdalx2 and brucifer like this.
  4. panterg55
    panterg55 Formely panterg Supporter
    Jun 18, 2010
    98
    Madchester UK
    Ohlins now fitted ! All I've got to do is extend the side stand . . . . . :hmmmmm , Cheers Glenn
    OzCRU likes this.
  5. OzCRU
    OzCRU Long timer
    Feb 16, 2015
    1,040
    Sydney Australia
    Looking good Glenn!
    I’ve nearly got mine installed on the XT.
    Made a little bracket to hold the reservoir in a similar place to the TT.
  6. panterg55
    Jun 18, 2010
    98
    Madchester UK
    Hi OzCRU , Thanks mate - I was given rubbers that fit round the frame and reservoir by the people that rebuilt the shock . I was going to use metal cable ties but they didn't look right - you may have noticed that one cable tie is black and the other is green , I ran out of black ones ! All I've got to do now is re-wire the front wiring loom with waterproof connectors . . . . . . but that's a project for the winter ! Can't wait to see your's fitted to the XT , Cheers Glenn
  7. OzCRU
    OzCRU Long timer
    Feb 16, 2015
    1,040
    Sydney Australia
    Hey Glenn,
    Check the XT thread, I’ve posted some pics in there.
    panterg55 likes this.
  8. panterg55
    Jun 18, 2010
    98
    Madchester UK
    Will do mate !
  9. mungus
    mungus Been here awhile
    Nov 17, 2007
    123
    Central Victoria, Australia
    I made this set up a few years ago. eBay DG muffler with several DB killer inserts so I can tone it down for ADV (roads/people) or in forests, or run the bigger insert at home. Bought a couple of stainless bends from an exhaust shop, quick bit of stainless MIG-ing and voila. The headers are the OTR ones. I likem.
    brucifer and panterg55 like this.
  10. ramoneTT600R
    ramoneTT600R Adventurer
    Apr 25, 2019
    13
    Slovakia
    So finished my rally rebuild :) Im thinking of replace rear mudguard to EXC
    ADV67, Tritwin, mikseven and 4 others like this.
  11. tuscan
    tuscan Been here awhile
    Mar 20, 2010
    771
    Nu Ziland
    Looking good
    Have you got details of what you did to the foot pegs ?
  12. panterg55
    Jun 18, 2010
    98
    Madchester UK
  13. ramoneTT600R
    Apr 25, 2019
    13
    Slovakia
    Hi, here are some detail fotos of them, it is stainless steel material.
    tuscan likes this.
  14. ramoneTT600R
    Apr 25, 2019
    13
    Slovakia
    Thanks :) fork are from early YZs or TT600S (KYB 43mm USD)....for steering damper I made DIY bar holders with place for scotts, see pics
  15. mikseven
    mikseven Adventurer
    Nov 3, 2014
    84
    Italy
    Forks are from a TT600s. It’s a Paioli on Kayaba License. It’s almost the same. The brake caliper is Brembo instead of Nissin.
    I have the same with some enhancements in order to have a better response on fast tracks
    OzCRU and ramoneTT600R like this.
  16. panterg55
    Jun 18, 2010
    98
    Madchester UK
    Thank you very much ramone - food for thought , Cheers Glenn
  17. tuscan
    Mar 20, 2010
    771
    Nu Ziland
    Thanks for that
    Have you got shots of the right hand side and did you modify the brake pedal? From memory the brake pedal travel is limited by the frame and by lowering the pegs the brake would be too high. How did you solve?
    Cheers
  18. ramoneTT600R
    Apr 25, 2019
    13
    Slovakia
    You are right, I have lowered footpegs by 30mm so there was lever too high....I needed to cut some lines into lever and bend it down, than weld cut lines, no big deal
  19. ramoneTT600R
    Apr 25, 2019
    13
    Slovakia
    Hi PropTP, did you need to change brakers to have 320mm disc on front wheel? Thank you! Nice TTRE
  20. mikseven
    mikseven Adventurer
    Nov 3, 2014
    84
    Italy
    OzCRU likes this.
