The XR400 Thread
Discussion in 'Thumpers' started by Hayduke, Jan 16, 2008.
  1. cmbthumper
    cmbthumper Been here awhile Supporter
    Sep 29, 2018
    888
    Ramona, CA
    While I can agree 100%, the fact that it turns this is even better and the main reason I bought it.
    BSW and gammel like this.
  2. FFK
    FFK Rock and Roll
    Jun 1, 2008
    11
    Arizona
    I'm in AZ now and it never impede at all.....my fender bag is a front tube attached (moose bag)
    I tend to ride a lot of single track besides the faster stuff and the slower stuff I never had any heat issues.
    Even when I first came out here 10 years ago and decided to try a ride in the DUMB summer.
    PHX_Joe likes this.
  3. arghhh
    arghhh Adventurer
    Jun 14, 2015
    58
    UK
    How much molybdenum oil do you coat on engine parts the XR manual says to? Thin smears or massive coats? If it's mixed 1:1 with engine oil, wouldn't it just wash off once the engine heats up to its standard operating temperature of 1,000,000 degrees?
  4. PHX_Joe
    PHX_Joe Been here awhile Supporter
    Oct 11, 2016
    124
    That's interesting, I was concerned - especially with the trailtech dash, watching the temps rise into the 220+ range (sensor on upper engine mount bolt). Good intel, thanks!
  5. molnar.b
    molnar.b Been here awhile
    Aug 16, 2018
    134
    Hungary, Budapest
    I finally dropped off the bike at my mechanic. He said that his first impression was low compression, so most likely it needs a top end.
    The bottom end is pretty much bulletproof on these bikes right?
    Stretch67 likes this.
  6. portero72
    portero72 Been here awhile
    Aug 25, 2007
    210
    austin, tx, y'all
    03EE33B0-1D12-4A28-B6D3-96589DEA4BBE.jpeg Went on a DS ride last week from West TX into NM. Great weather and riding the whole time. Switch bikes with my buddy’s 650r for TEN MINUTES and he does this...
    elBeardo, gammel, molnar.b and 3 others like this.
  7. portero72
    Aug 25, 2007
    210
    austin, tx, y'all
    It was way slimier than it looks.
  8. Jeff B
    Jeff B Socially Awkward
    Feb 13, 2008
    9,625
    SW PA.
    Relative to some.............. Yes, but I hate that term "Bulletproof".
    I had to split my cases on account of a $2 shifter return spring failing. This was an
    anomaly, but never less left me stranded on a trip.
  9. grogger
    grogger Been here awhile
    Mar 15, 2016
    432
    OR
    Back into the game guys.
    I regrettably sold my garage floor up 98 rebuild a couple of years ago and going to go pick up a clean 96 tomorrow. The seller says a top end tick.
    Where should I start to troubleshoot the tick ?
  10. cmbthumper
    Sep 29, 2018
    888
    Ramona, CA
    IMO check the valve clearances and then cam chain tensioner. The pull the valve cover for rockers, cam etc.
  11. arghhh
    arghhh Adventurer
    Jun 14, 2015
    58
    UK
    Two questions:
    1) Can you remove the stock carb without removing or loosening the intake boot mounting bolts?
    2) Can you remove the Mikuni carb without removing or loosening the intake boot mounting bolts?
  12. MartiniUp
    MartiniUp Long timer
    Jul 14, 2010
    3,721
    TX
    Those barkbusters should be parallel with the ground. Zero strength like that, if you hit anything they will fold under. Look at any real dirt rider's bike who is active in enduro, HS and you will see the correct orientation.
    bork and shinyribs like this.
  13. shinyribs
    shinyribs Thumpers for life
    Sep 24, 2011
    6,166
    The South
    I never take the intake manifold off the head. I just pop off the subframe. Everything is wide open then. Seems excessive, but you can have the whole subframe off in a couple minutes.
    Stretch67 and arghhh like this.
  14. teledan
    teledan Been here awhile
    Apr 9, 2013
    134
    Utah, USA
    this is what I do as well. I have the Mikuni tm36. I usually just loosen the lower subframe mounts slightly and then remove the top bolt so the whole thing swings down. After you do it a couple times it becomes a fairly easy process. Oh and I have to pull the muffler as well.
    Stretch67, NSFW and arghhh like this.
  15. shinyribs
    Sep 24, 2011
    6,166
    The South
    With the stock shock linkage mudflap in place you can easily break the mudguard by letting the subframe droop down. I detach the exhaust from the subframe mounts, but leave the exhaust in place and intact. Even the stock exhaust is light enough to float. Many ways to skin a cat.
  16. grogger
    Mar 15, 2016
    432
    OR
    Anyone have a good condition complete with mounts skid plate they're not using ? Ricochet, Moose, MSR, Devol ?
  17. arghhh
    arghhh Adventurer
    Jun 14, 2015
    58
    UK
    Two oil questions.
    1) When doing an oil change, can the bike frame take the entire 1.8 litre / 1.9 qts of oil in one go?
    Because I read on the internet that you pour some oil into bike, start engine so it drains frame so you can pour in the rest. But I poured the whole lot in without starting the engine.
    2) When the engine is off, does oil drain out of the frame and into the crankcase? (Like overnight)
  18. teledan
    Apr 9, 2013
    134
    Utah, USA
    Yes, this is called “wet sumping”. Not to be confused with “dry humping” or even worse, “wet humping” :)
    Just make sure you check your oil right after you run the bike for a while and shut it off.
    Also, there was a conversation a few pages back about this.
    arghhh likes this.
  19. Johnnyboxer
    Johnnyboxer Long timer
    Oct 23, 2003
    1,381
    Yorkshire, UK
    I pour a litre in first
    Then I pull the decompressor in, kick the bike over 20-25 times to circulate the oil
    Then pour 600ml in and check that there is oil showing onto the bottom of the dipstick
    Start the bike and run for 5 mins, stop bike and then let the oil settle for 5 mins
    Re-check the dipstick and pour in the final 200ml
    Start bike, run for 2-3 mins and stop, let oil settle and then recheck after 5 mins
    arghhh likes this.
  20. Jeff B
    Feb 13, 2008
    9,625
    SW PA.
    I have found that "Wet Humping" is the best method for adding fluids to the bike. :nod
