The XR400 Thread
Discussion in 'Thumpers' started by Hayduke, Jan 16, 2008.
  1. G600
    G600 Been here awhile
    May 18, 2009
    557
    Iceland
    arghhh likes this.
  2. arghhh
    arghhh Adventurer
    Jun 14, 2015
    58
    UK
    I see people buy a CRF450 cam chain (part number 14401-MEB-671) instead of another XR cam chain, but I haven't seen any long term updates. I assume all is well with using the CRF450 cam chain in the long run?
    Stretch67 likes this.
  3. dlock5
    dlock5 Been here awhile
    Nov 23, 2015
    249
    US
    Yes, its better and actually cheaper .
    arghhh likes this.
  4. cmbthumper
    cmbthumper Been here awhile Supporter
    Sep 29, 2018
    891
    Ramona, CA
    Never read that and though I'm a ways out from replacing I will be interested to read replies.
  5. Stretch67
    Stretch67 Mad Scientist Supporter
    Mar 22, 2006
    22,598
    Bent, But Not Broken
    arghhh and cmbthumper like this.
  6. shinyribs
    shinyribs Thumpers for life
    Sep 24, 2011
    6,169
    The South
    I also run that chain. Fits perfect and will hold up longer in the long term, actually.
    arghhh likes this.
  7. Johnnyboxer
    Johnnyboxer Long timer
    Oct 23, 2003
    1,383
    Yorkshire, UK
    2003 Honda XR400R - how to improve the suspension?
    In particular the forks, all standard are present
    I am 105 kgs, so I guess the forks could do with heavier springs, for a start and/or heavier weight oil, for starters
    I was thinking Race Tech Valves too - maybe
    I don't want to lose the 'plushness' in favour of harder suspension as I am only trairiding at 30 mph or less, not racing
    At the rear, I have changed the shock for a WP version and this has improved it no end, much more 'plushness' and a resistance to bottoming out
    Any thoughts or tips.....................what have you done?
  8. shinyribs
    Sep 24, 2011
    6,169
    The South
    I thought the stock forks were harsh, so I worked on mine to gain a plush ride. Since you mention a plush ride and fear getting a firm suspension, I think your first step is deciding what you want when you say "improve suspension".
    If you are happy with the current plushness while trail riding, but are experiencing lots of bottoming, just re-spring and see where you are after that.
    If you are after suspension work just to chase the idea of "upgrading", every rider and terrain is different- there's no right or wrong on a suspension setup.
    Johnnyboxer and cmbthumper like this.
  9. arghhh
    arghhh Adventurer
    Jun 14, 2015
    58
    UK
    You guys not had any problems with worn cam chain guides or anything? I'm just wondering since the CRF chain is wider, does it sit on those ridges of the cam chain guide that normally "hold" the stock cam chain in position. Basically filing them off and creating some debris?
  10. Johnnyboxer
    Oct 23, 2003
    1,383
    Yorkshire, UK
    Thanks, I want plushness overall
    How did you improve the harshness of the forks on yours, what did you do?
  11. Stretch67
    Mar 22, 2006
    22,598
    Sounds plausible, but I've seen no adverse effects.
    arghhh likes this.
  12. shinyribs
    Sep 24, 2011
    6,169
    The South
    It's kind of long to explain, but it's in this thread somewhere. Basically, after experimenting, I decided the stock compression valve was unable to flow enough oil ( the shims weren't the restriction), so I modified the valve for more flow. Really wasn't a very complicated process.
    https://advrider.com/f/threads/the-xr400-thread.302523/page-654
    Johnnyboxer and Stretch67 like this.
  13. shinyribs
    Sep 24, 2011
    6,169
    The South
    No issues. The CRF chain is is the same profile, so it doesn't dig in to the guide in any unusual way. The CRF chain is just a plate or two wider, so it's stronger stronger.
    arghhh likes this.
  14. Luke
    Luke GPoET&P
    Aug 25, 2004
    5,151
    Beaverton, OR
    IMO the crf chain is too wide. It can move side to side on the sprockets and is wider then the groove in the guides. I ran it for a little while, then went back to a stock chain at the next rebuild.
    arghhh likes this.
  15. shinyribs
    Sep 24, 2011
    6,169
    The South
    When I first read about guys using the CRF chains I was curious if the XR chain guides would accommodate it, but when I fitted mine up the edges on the guides were plenty wide to take the wider chain without and clearance issues.
    As far as moving on the sprocket, I'm not sure how that would happen. But, it's been 3 years since I rebuilt my engine and installed the CRF chain, so there could be something I'm not remembering.
    arghhh and Stretch67 like this.
  16. Jeff B
    Jeff B Socially Awkward
    Feb 13, 2008
    9,628
    SW PA.
    If I could of acquired a matching set of sprockets [also wider] I would of used the wider CRF chain. So I saw now advantage since it wouldn't change the contact area at all.
    About the only effective change would of been increased revolving mass.
    arghhh likes this.
  17. shinyribs
    Sep 24, 2011
    6,169
    The South
    Very rarely will you see a cam chain eat in to the teeth of the sprocket. You never really see the teeth of the chain worn away either. What we do see cam chains do is "stretch". Whether that stretch is pin wear or actually plate stretching, more links helps to offset that wear.
    Are stock chains problematic? Not really.
    Do CRF chains cause problems? No, and it was a third of the cost when I was buying a chain.
    Depending on your point of view, budget, etc I don't think your can go wrong with either choice.
    arghhh likes this.
  18. Luke
    Luke GPoET&P
    Aug 25, 2004
    5,151
    Beaverton, OR
    It's got room to walk a few mm side to side. There's nothing to force it but it seemed like it could wander on its own. If it sat on one side it would likely wear in slightly and stay there.
    That's just my impression, though. When I replaced the chain it seemed fine, the rest of the motor was trashed. So it may just be my imagination.
    arghhh likes this.
  19. shinyribs
    Sep 24, 2011
    6,169
    The South
    Yeah, I'm not sure either since it's been so long so I looked at one. But generally, the teeth of the sprocket go up in to the chain, which keeps the chain from wandering off the sprocket. I don't think these engines are any different. The cam chain tensioner guides just runs the chain to provide tension and a keep chain slap down, they don't offer any lateral guidance.
  20. Hafbakt
    Hafbakt Travel Junkie
    Jul 15, 2012
    102
    Left side Of the Great Divide
    Anyone have an oversized tank they would like to sell? I’d be happy with any of the 3.9 to 5.8 tanks. Thanks
    (I’m in Phoenix at the moment)
