The XR400 Thread
Discussion in 'Thumpers' started by Hayduke, Jan 16, 2008.
  1. shinyribs
    shinyribs Thumpers for life
    Sep 24, 2011
    6,791
    The South
    Rule of thumb for sag is 1/3 total travel. If you've got 12" of wheel travel to want 4" of laden sag ( you on the bike). 9" of travel, 3" of sag...and so on.
    If you road ride or use luggage a lot you'll appreciate a stiffer preload than 1/3 sag. If you like popping wheelies, or just want it to come up easier, stiffer shock preload helps there also. 1/3 is a good starting point, but it's not set in stone. Careful on the internet....some folks will have your thinking if your sag is 3mm out that the bike will inexplicably become a deathtrap or something :D
    Stretch67, NSFW and molnar.b like this.
  2. Throttle&Clutch
    Throttle&Clutch Adventurer
    Jun 2, 2019
    57
    NorCal
    Thanks @NSFW
    I will see what all I can find. I've just been playing too much on atv trails with a friend on a raptor, so I'm riding it pretty hard at the moment.
    I know the preload is off because the previous owner had it set for 20lbs heavier than me.
    NSFW likes this.
  3. molnar.b
    molnar.b Been here awhile
    Aug 16, 2018
    161
    Hungary, Budapest
    Thanks man, you always have some good advice, appreciate it!
    shinyribs and NSFW like this.
  4. The Patagonia Kid
    The Patagonia Kid gnarly adventurer
    Feb 6, 2007
    1,089
    SOUTHERN CALIFORNIA, Thousand Oaks.
    On the XR I decided to remove the nice / new fancy IMS gear shifter installed by PO ... I know was replaced because after a fall the stock was bent and trying to bend it back broke.
    I think rather have the less strong original shifter even though is shorter ... :-) XR400R 13.jpg
  5. cmbthumper
    cmbthumper Long timer Supporter
    Sep 29, 2018
    1,397
    Ramona, CA
    As long as your foot is Happy and it keeps it's way out of the case, name means squat. I only run the IMS because it is perfectly placed for my dirt or street boots.
    On my XR600 I knocked in a alum plug for the tip. The extra 1/4 keeps.me from miss shifts
    The Patagonia Kid likes this.
  6. grogger
    grogger Been here awhile
    Mar 15, 2016
    451
    OR
    Replacing bent shift shafts = no fun.
  7. Stretch67
    Stretch67 Mad Scientist Supporter
    Mar 22, 2006
    26,316
    Bent, But Not Broken
    Yep, hence the value of the soft, malleable Honda shift lever. It takes the brunt of the damage so the shaft doesn't have to.
    flybynite and The Patagonia Kid like this.
  8. North Thai Biker
    North Thai Biker Been here awhile
    Oct 18, 2004
    334
    Hawaii, Las Vegas
    Hi,
    I have an electric start XR400 listed for sale in the Flee market. It's located in Las Vegas.
    Joe
    PHX_Joe likes this.
  9. Run Away
    Run Away n00b
    Oct 6, 2012
    8
  10. molnar.b
    Aug 16, 2018
    161
    Hungary, Budapest
    I think all XR400s have the same Keihin carb, just different jetting from the factory. The choke lever has 3 positions, and it is on the left side of the carburetor.
  11. saltyD
    saltyD Been here awhile
    May 17, 2020
    889
    Great Southern Land
    I've got a mikuni, but the Oz OEM carb has the choke on the side, too.
    Run Away and Stretch67 like this.
  12. JMo (& piglet)
    JMo (& piglet) Unicorn breeder
    Apr 1, 2007
    9,258
    California
    That's not the choke on the clutch lever, that's the decompressor lever.
    The choke is on the carb.
    Jx
    flybynite likes this.
  13. Run Away
    Run Away n00b
    Oct 6, 2012
    8
    Yeah I'm aware where the choke and decompression lever are on North American XR400s, just wondered if the Australian road-legal versions had it in a different spot.
    XR650Ls have it on the clutch lever like so
    CRF230L and CRF230M also have it located on the clutch lever, whereas the standard CRF230F has it on the side of the carb.
    XR250L have a push/pull knob next to the ignition and under the gauges, XR250R have the usual lever on the side of the carb.
    JMo (& piglet) likes this.
  14. The Patagonia Kid
    Feb 6, 2007
    1,089
    Happy Memorial weekend to everyone ...
    Finally last week trailered my XR to a friend that has the toy hauler and we were on our way out to the desert ... California City.
    The 400 performed flawlessly and I've had a blast with it ... really glad made the switch to original shifter lever. Back home now safe and sound and thinking about the next time out.
    No humans or machines were harmed in this adventure! :rofl
  15. RED1
    RED1 yes it really is me
    Sep 10, 2007
    656
    The High Country, Vic, OZ
    No, same as everywhere else!
    Run Away likes this.
  16. slideways
    slideways España
    Mar 1, 2003
    15,890
    Spain
    I used the Motion Pro cables on all of my XR’s. They seem to have cables for everything.
  17. The Patagonia Kid
    Feb 6, 2007
    1,089
    After last weekend ride emptied the gas tank, carburetor and ordered new rubber.
    Installed a clean UNI and waiting on inner tubes. Also today started it, to make sure everything was in good working order.
    Goodies are arriving already ...
    As soon as tires are installed will be ready for the next adventure! :-) XR400R 16.jpg
    shinyribs, gammel, cmbthumper and 6 others like this.
  18. The Patagonia Kid
    Feb 6, 2007
    1,089
    One down one more to go ... :1drink
    The tools of the trade!
  19. The Patagonia Kid
    Feb 6, 2007
    1,089
    And now ready to be called on for the next adventure ! :1drink
    Saving garage space ...
    Guano11, shinyribs, Yeti2ride and 4 others like this.
  20. shinyribs
    Sep 24, 2011
    6,791
    The South
    I lost my patience with the rim guards years ago :D Unfortunately, my rims show it, but I can't see it from the saddle :ricky
    Bike looks good, man!
