The XT600 Thread
Discussion in 'Thumpers' started by CR_TurboGuy, Jan 21, 2007.
  1. vladu7z
    vladu7z n00b
    Jun 20, 2009
    7
    Hello everyone,
    I need your advice on a decision. :)
    I had 2 XT600Z Tenere 3AJ (1988 and 1989) and loved them both. I had to sell them because I moved and moving the bikes would have been very expensive. Now I am looking to buy another bike and am undecided:
    • use case: 300-400 km daily trips in Austria and 1000-3000km trips once per year in summer, two people (65kg+45kg) and some luggage.
    • some wishes: the sound of the 3AJ, cheap and easy to find parts, very reliable, easy to maintain, simple
    XT600E:
    • basically same bike as 3AJ, but more parts are available.
    • Light, robust, easy to maintain, enough power
    • Harder to find in Austria (easier to find is the XT500E: same bike but smaller engine)
    • Newer models don't sound like my 3AJs
    • expensive
    XTZ660 Tenere:
    • better for longer trips with heavier stuff
    • power
    • more expensive to buy in good condition
    (Honda NX500 Dominator (the NX650 is rare in Austria))
    • cheap to buy (1000-1500€) in very good condition
    • only 24hp
    • very nice design
    • quality parts and cheap to find
    • not so reliable?
    Thank you very much :)
  2. jjxtrider
    jjxtrider questionable
    Aug 17, 2013
    4,291
    Halfway to hell (WI.)
    I'd think the E would work but you'd need some suspension stiffening to run 2 people . Obviously not as great for trips as the more powerful 660 but with less weight and bulk to deal with daily . 24hp absolutely won't cut it for a 2 up tourer and have fun doing it . Some older pipes may(I'm assuming here) be fitted to get the sound but a frame brace is needed to make up for the bright idea of them using the stock exhaust as a structural item .
    OzCRU likes this.
  3. OzCRU
    OzCRU Been here awhile
    Feb 16, 2015
    870
    Sydney Australia
    I can’t speak for the other bikes, but have the ‘90 E,
    Definitely put a firmer spring on the stock Shock, probably in the range of 100Nm for two up, the suspension on the E isn’t as good as the 88/89 models.
    I’ve got an eibach 96Nm spring currently on the stock shock on mine. Huge improvement over std spring.
    Wilber’s still offer an excellent adjustable rear shock, but it’s not cheap. I’ve just had converted an Ohlins shock off a TT Belgarda, but haven’t picked it up or fitted it yet. Will advise once I do but expecting it to be even better.
    I’m also running Belgarda front forks on my 90E.
    I second also the frame brace, (I made my own.) if you change the exhaust which you should be able to find options.
  4. Squily
    Squily Squily Supporter
    Sep 18, 2006
    2,970
    Esperance WA (Down Under)
    Honda IMO more reliable than Yammy. Did lot of touring on both and the XT has more low-down torque, but that's about it. The Honda motor is a better design used in XR range from 200-650cc. And no cam problems like the XT.
    Edit: and no electric/stator issues like the XT
  5. jjxtrider
    Aug 17, 2013
    4,291
    Having rebuilt motors from all the main brands, I can assure that Honda's are not any more reliable or run longer than the other brands. All brands have certain issues , thing with Honda is they tend to greatly detune motors which is easier on them but then lack the power of the rest. There is a reason they do that. Honda xl/xr motors(similar design as the xt )are well known for cam and rocker failures and oil use under sustained highway use. They also have soft aluminum so stripped threads are normal compared to the othe 3 Japanese mfgs. Key to all is good maintenance and watching oil levels and keeping temps as low as possible. Both brands should've taken notice of Suzuki's use of plated cylinders in many of their motors, heck even Kawi did it in several.
    MATTY, BygDaddee and OzCRU like this.
  6. trevis_01
    trevis_01 n00b
    Nov 8, 2019
    1
    Poland
    Hello everyone and best regards from Poland!
    I own 1992 XT600 and need some spare parts for it (gasket plus oil filter). I was looking for a parts online and found online catalog with diagrams (https://yam-shop.de/Yamaha-Genuine-Ersatzteile). But they diagrams have both models XT600 and XT600E. Is there any difference in spareparts between 1992 XT600 and 1992 XT600E?
    Thank you!
  7. jjxtrider
    Aug 17, 2013
    4,291
    They all take the same oil filters , '83-'0? (TT's as well) until it was turned into the 660's .
    trevis_01 likes this.
  8. Mr.JAJA
    Mr.JAJA Long timer Supporter
    Nov 29, 2010
    1,354
    San Diego, just north of BAJA "
    Squily: And this is why I build me a XT600/TT600. I just like the color.
    takis600 likes this.
  9. Mr.JAJA
    Nov 29, 2010
    1,354
    OK here a Question to solve a Problem. I build a 84 TT600 with a 95 XT600E motor. Everything went well, till I try to get a new front sprocket. The Motor is a 3TB with a fine spline (22) on the countershaft. I can get a 15T but like to run a 14T. I check the JT, Sunstar, catalog, but no one makes the front sprocket. Any suggestion from a cross reference Part like the Yamaha MX models for the 1995 3TB Motor?
  10. OzCRU
    Feb 16, 2015
    870
    Sydney Australia
  11. OzCRU
    Feb 16, 2015
    870
    Sydney Australia
    takis600 and Mr.JAJA like this.
  12. Mr.JAJA
    Nov 29, 2010
    1,354
    Why cant I find this here in the US on the internet? Searching for two days and some on from downunder has to give me the hint for the US. Stupid Internet.
    Yes that is exact what I need.
    Stay save from the Fire on the east coast. I have many friends on the east coast from Byronbay to Melbourne and Esperence.
    Its on order. For some reason, I get a different Catalog if I search for the Bike. but your lead is spot on. Thanks OzCRU
  13. OzCRU
    Feb 16, 2015
    870
    Sydney Australia
    You're welcome!
    No idea why that wasn't coming up for you - But happy to help.
    Interested to see your bike as it gets more complete - It's looking good.
    Fires are certainly bad this year in both NSW & QLD - I think it's going to be a very long summer, & we haven't even gone close to hitting the normal hot weather that we expect to get!
    Mr.JAJA likes this.
  14. Mr.JAJA
    Nov 29, 2010
    1,354
    I raised the seat to my need and had to cover a gap. Did it with some Aluminum like this .
    I hope to paint the frame before X-mas
    Squily and OzCRU like this.
  15. gbiddy
    gbiddy n00b
    Dec 13, 2019
    4
    BC / Canada / Van Isle
    I'm on the fence XT-wise, and looking for an opinion or two.
    I can buy a very good condition '90 XT600E that starts, runs, rides, and stops like a beaut, and that's rolling on collector insurance right now (super cheap, $150/year), and that I can pick up for about $1800 Canadian Pesos, and that other than an older Supertrapp, is stock and original (thus the collector plates). In almost every sense, it's pretty near mint. Good tires, too. But it has 85,000 kms on the thump-mill.
    It's a pretty rare bike in these parts, but other than throwing on some knobbies and stripping off a few bits, and maybe adding some LEDs, my plan would be to spend 90% of my time off road with tha' beast, so I'm not worried about aftermarket parts, do-dads, and electronic junk to strap to the bars so's I don't get lost (the point will kinda be to get lost).
    Given all of the above, how's the price sound?
  16. MATTY
    MATTY BORDER RAIDER
    Jun 23, 2014
    4,000
    England On the Scotish border
    My 97 600E is stock geared (15x45) i want to gear it down/lower the gearing. It is ok but want the available power to be better employed where and how i use the bike.
    Its on the stock 17 inch rear wheel . I use the bike mostly on back roads some A roads but only ever 50 / 80 miles tops mosst days.
    Road speed i tend to ride this bike sedately 60mph is about as fast as i ever take it on back roads, and A roads cruise around 60/ 65 lower 70s when overtaking but never more.
    I try and throb about down in the 40s 50 on back roads if the mood takes me, but i want the lively response lower gearing will give me acceleration and the tight stuff is where i like to be.
    I dont mind it screaming in top at 75MPH i will only ever go there short term . I thought about 14x47 but i want my gearset choice to count first time, hense by in depth description of my useage requirements here.
    Any thought observations experience here would be greatfully recieved thank you all in advance.
  17. Mr.JAJA
    Nov 29, 2010
    1,354
    I think a 14 X 45 change will be enough an make a big difference. And you save the $ for the rear sprocket.
  18. MATTY
    MATTY BORDER RAIDER
    Jun 23, 2014
    4,000
    Sounds good economically my chain set is about half worn i guess, so not be too bad with just the front sprocket, thanks.
  19. Axleman
    Axleman n00b
    Sep 30, 2018
    2
    Somerset,England
    Put a 14t on my 95 Xt600e,going by your description I use mine the same on smaller roads and it's ok .
    Might change the rear if I get into the Greenlane off-roading here in the UK .
  20. MATTY
    MATTY BORDER RAIDER
    Jun 23, 2014
    4,000
    Yes thanks i will try the 14T front.
    In stock form i think mine would pull up to early 80s a bit more mabe, never really tried, saw close to 80 on the clock once was reving though i felt.
    I do not have clocks in mine now just a phone i use, it means i am on ear if you understand. if i remember it used to rev a little over 4000 at late 60s mph.
    Looking on a calculator bears this out and swamping to14T i should loose around 6mph so 4000 should be 60mph that is enough cruise speed for me and what i am doing , it might be still a little too high but it will change the nature of response in other gears and this might be a sweet simple easy swap that gets me what i want.
