The XT600 Thread
Discussion in 'Thumpers' started by CR_TurboGuy, Jan 21, 2007.
  1. webmonstro
    webmonstro A Aventura Continua....
    Jul 21, 2008
    1,255
    Portugal
    There's a small switch in the clutch lever . It's usual to go bad . You can join the two wires together
  2. amishman71
    amishman71 Adventurer
    Mar 4, 2021
    48
    mi
    i tested the clutch wire and comes back normal, like i cant just hit start when its in gear i have to hold clutch in and tap starter. thought this was what it was earlier in the week. stumped
    unlimited_explorer likes this.
  3. Brage
    Brage Mechanic
    Jul 30, 2010
    82
    Norway
    Here is a better pic of the XT without the KTM in front:thumb
    Not bad for an over 30 year old bike. The MY1983 30 litres tank was a real masterpiece with baffles inside. Up to 600km range:clap, they don`t make it like that anymore:(. 20210802_124832[1619].jpg
    Kindly regards Brage
    Baloffski, Bors, OzCRU and 3 others like this.
  4. zap2504
    zap2504 Dave E.
    Feb 15, 2006
    1,865
    Middletown, PA
    Neutral safety switch? Part #1 here: upload_2021-8-2_17-27-49.png
    amishman71 likes this.
  5. amishman71
    Mar 4, 2021
    48
    mi
    ya thats what i was pondering in my first post, glad i live 2 mins away from a yamaha dealer 15 bux and finally fixed. for some reason ppl were confused when i talked about a neutral safety switch.
  6. Godoh
    Godoh Adventurer
    Jan 28, 2019
    17
    Australia
    Hi Amishman, I don't know about the Tenere bikes with electric starters, mine (83) never had one.
    But most bikes with electric starters have a switch on the clutch that prevents the bike starting unless the clutch is pulled in, and also some are also linked to the neutral lamp as well. The thing you say that looks like a spark plug by the front sprocket could be two things. It could be the Oil pressure switch or a neutral switch.
    What model do you have?
  7. amishman71
    Mar 4, 2021
    48
    mi
    ya it was the neutral safety switch, ended up just going with my gut. was just a pain testing it all and no 1 seems to kno what a neutral safety switch is lol. mine is a 93 xt600e
  8. Godoh
    Godoh Adventurer
    Jan 28, 2019
    17
    Australia
    Well done amishman, glad you got it sorted.
    Brage that is a nice looking Tenere. Pity I had to sell my 83 tenere, I had balance issues for a few years and so sold the bike. I loved the range with the 30 litre tank.
    Balance fixed now, have a F650 bmw (96) that I have customised a fair bit. It is a nice bike now.
    Pete
  9. unlimited_explorer
    unlimited_explorer Been here awhile
    Aug 10, 2020
    254
    Czech
    That was also on my radar when I was buying a bike 15 years ago .
  10. unlimited_explorer
    Aug 10, 2020
    254
    Czech
    Bors and Brage like this.
  11. Godoh
    Godoh Adventurer
    Jan 28, 2019
    17
    Australia
    Yep I loved mine too. I think it was a fair bit lighter than the F650 I have now. It also had a lot less weight on the front wheel.
    That caused me grief one day though, riding up a very steep track that had steps in it, 35 degree C heat, and the front wheel would not stay on the ground. Fell off 8 times that morning, wheelstanding up steep hills while leaning over the headlight was not fun.
    Looking back , I should have taken my soft saddle bags off and hung them over the tank.
    Oh well, sometimes adventures are not all smooth. No damage to the bike, just one tired old fellow by mid day.
    We got up the hill in the end.
    Pete
  12. unlimited_explorer
    Aug 10, 2020
    254
    Czech
    I think the water cooling might be edge . My XT sometimes seems it needs a bit of pause it also has lower fuel consumption, right?
  13. amishman71
    Mar 4, 2021
    48
    mi
    can i ask what pipe u have? and does any one kno the size socket id need for the primary gear nut?
  14. Brage
    Brage Mechanic
    Jul 30, 2010
    82
    Norway
    Hi.
    The end pipe is a Laser Produro stainless exhaust. From the tip of my tounge I think the fwd gear nut is 32mm, but I might get this mixed up with some other mechanic questions in a completely different matter:doh Might be 24mm ....
  15. unlimited_explorer
    Aug 10, 2020
    254
    Czech
    Hello.
    How you renew the standard black XT exhaust?
    (It's getting a but rusty at some places but it's just on the surface)
    I'm thinking about sand blasting and then a paint used for metal chimneys? Or is there a better paint to use ?
    Yes I was thinking about a stainless system but I like to be quiet since off-roading is illegal where I live and being quiet helps.
  16. zap2504
    zap2504 Dave E.
    Feb 15, 2006
    1,865
    Middletown, PA
    If you have access to spray paint used for auto exhaust manifolds, I'd use that instead of chimney/stove paint - higher temperature rating.
  17. amishman71
    Mar 4, 2021
    48
    mi
    OzCRU likes this.
  18. dzl
    dzl adventurer wannabe
    Apr 21, 2009
    284
    Adelaide, South Australia
    Ive never had to replace metal roller or cover, only the plastic roller. Unless you see they are worn, no need. Metal roller is generally a loose fit over metal seal. Might as well pull whole rear arm out and check, clean, regrease bearings while youre at it.
    amishman71 and OzCRU like this.
  19. amishman71
    Mar 4, 2021
    48
    mi
    ty, now 1 other issue i just noticed ive been having my brake light only works when it wants too. bulb looks good, some days my front brake and rear brake will work perfect. others only get the light when i hit front and vice versa. were should i start i dont see any dmg to the lines?
  20. unlimited_explorer
    Aug 10, 2020
    254
    Czech
    Also check the switches if they click right
