The XT600 Thread
Discussion in 'Thumpers' started by CR_TurboGuy, Jan 21, 2007.
  1. amishman71
    amishman71 Adventurer
    Mar 4, 2021
    48
    mi
    ok so once the shock is detached and i pull that bolt it should just wobbile side to side? or do i have to actually back it all the way out
  2. OzCRU
    OzCRU Long timer
    Feb 16, 2015
    1,089
    Sydney Australia
    you'll have to pull it all the way out as it runs through the swingarm as well as the motor & the frame, so until you pull it out nothing will move.
  3. amishman71
    Mar 4, 2021
    48
    mi
    mb i meant the swingarm not the bolt.. once i get the bolt all the way out do i have to fully back the swingarm out or or will it drop down? ive never removed a swingarm so mb for the questions.
    OzCRU likes this.
  4. OzCRU
    OzCRU Long timer
    Feb 16, 2015
    1,089
    Sydney Australia
    Doing it the way I've suggested the swingarm will then swing down on the lower link (which is still attached to the frame underneath & the pivot buit into the swingarm). It should only take a moment to slip the new part over & then you can put it back together. Take your time & you'll be fine. dont forget to spread grease all along the swingarm bolt before you put it back in - It will likely be quite dry when you remove it so this will be a good opportunity to lube it all.
    Take some photos beforehand so you can refer to them as you go for reassembly.
    amishman71 likes this.
  5. unlimited_explorer
    unlimited_explorer Been here awhile
    Aug 10, 2020
    254
    Czech
    OzCRU and amishman71 like this.
  6. amishman71
    Mar 4, 2021
    48
    mi
    looks good been wanting to paint mine was gonna do it when i did my plastics as well, bike was in a shed for years first ride in my michigan weather the pipe got rusty lol.
    unlimited_explorer likes this.
  7. unlimited_explorer
    Aug 10, 2020
    254
    Czech
    Cleaning with gasoline
  8. Angustini
    Angustini n00b
    Aug 28, 2021
    3
    Marlborough - Blenheim Central
    Good afternoon,
    Does anyone have a link to a page that may have the engine numbers corresponding to year and model?
    I have an engine here and are trying to track down some info on it?
    Thank you.
  9. unlimited_explorer
    Aug 10, 2020
    254
    Czech
    I would apply a anti rust thing and after that baking paint /stove paint in spray. I have done it twice in 20 years. Riding the bike whole year I'm trying to ride just off-road in the Winter - no salt in the woods
  10. amishman71
    Mar 4, 2021
    48
    mi
    so after u spray it u put it in the oven for a bit? i ride my bikes till snows on the road. we get -20 degrees were i am pretty frequent in the winter lol.
  11. unlimited_explorer
    Aug 10, 2020
    254
    Czech
    I'll let it idle for a few mins and then ride it for a while it works
  12. unlimited_explorer
    Aug 10, 2020
    254
    Czech
    Shouldn't this hose connected somewhere? It has a filter at the end .
    I briefly looked at the manual and could not find it.
    So it's just breather hose for the secondary carb ? Screenshot_20210905-113056-395.jpg
  13. zap2504
    zap2504 Dave E.
    Feb 15, 2006
    1,865
    Middletown, PA
    I'm working on a Coleman propane 2-burner I got cheap. After cleaning I decided to spray the tops of the burners. Got some VHT flame-proof header spray paint (silver). Proper application is to either bake it (3-step process) or run the engine (another 3-step process). Will be baking my parts obviously. It's all on the can.
  14. unlimited_explorer
    Aug 10, 2020
    254
    Czech
    OzCRU likes this.
  15. amishman71
    Mar 4, 2021
    48
    mi
    this just hangs under the seat for me just a vent with a lil half ass filter on it. does any one kno the part number to the top 2 oil cover screws the longer 2 1's? they both bolt into the case cover the guy before me stripped most of the threads then put a bigger bolt in that wasnt even long enough lol. cant seem to find the part number any were on the catalog.
  16. unlimited_explorer
    Aug 10, 2020
    254
    Czech
    Thx
    https://www.xt600.de/xt_werkstatt/_technische-referenz/-explosionszeichnungen/index.htm
    Here you can find part numbers
  17. OzCRU
    OzCRU Long timer
    Feb 16, 2015
    1,089
    Sydney Australia
    @Angustini
    Try this link for your XT600 model codes:
    https://kedopartsaustralia.com/tt600-xt600-model-id/
  18. unlimited_explorer
    Aug 10, 2020
    254
    Czech
    Hello XT people.
    It's bad for the engine to run without the stock exhaust baffle /spark arrestor?
    It seems it has more grunt in low revs without it .
  19. OzCRU
    OzCRU Long timer
    Feb 16, 2015
    1,089
    Sydney Australia
    I don't run the original exhaust or spark arrestor.
    No, I don't believe that it's bad for the XT engine to run without the stock baffle or arrestor.
    In case this info helps you I'll detail what I do run.
    I made a frame bar to bolt in place where the original exhaust supports the frame on the RHS. I have a '90 model.
    I've used a GSXR 1000 titanium can from early 2000's marked '18-G1' same as the guys run on the Suzuki DR650's - there's heaps of info on this & other forums so I won't repeat again here. IF you can get a hold of the one marked '40-F0' - that's the absolute best as it's shorter but they are rare as hens teeth now - BOTH are significantly lighter than the standard XT (boat anchor) exhaust. I liked it's performance & sound - but I did have a cobbled together midpipe that I had made to make it work & I wanted to sort that out better. (I'll probably use it again when I build up my TT600R).
    So ... I've since removed that can & replaced it with an old second hand Staintune unit that I picked up. Staintune is a fully stainless steel Australian made unit that used to be very popular on lots of different brands & models in Australia.
    They are LOUD - at least this one is VERY LOUD. I managed to secure a replacement baffle/restrictor that reduced the final diameter, but isn't a spark arrestor.
    This quietened it a little, but it's still pretty hard on the ears. I like it :lol3
    I have found both of these exhausts improved engine performance & both units are lighter than stock so another saving. (even including the weight of the frame bar.)
    From memory Yamaha changed the frame between the 90-96 model & the 96-04 model (need to check that) so you may not need to make a frame bar to fit a different exhaust.
    Anyway - hope that's useful somehow now or in the future.
    Cheers,
  20. zap2504
    zap2504 Dave E.
    Feb 15, 2006
    1,865
    Middletown, PA
    I have a '94 and would be interested in any details about your frame bar. I know they used to be included in some aftermarket exhaust kits. Have thought several times about switching out my muffler for something lighter/less restrictive but would need a similar bar (also have seen others run an aftermarket exhaust w/o one and thought that looked suspect).
    OzCRU likes this.
