    Dismiss Notice
The Yamaha Super Tenere XT1200Z Big Thread
Discussion in 'Japanese polycylindered adventure bikes' started by mr moto, Feb 9, 2008.
  1. madrider5150
    madrider5150 Riding somewhere
    Oct 15, 2013
    1,332
    PNW
    Maybe do several layers of it, or maybe the primer it'll adhere better. Mine was on bare metal , didn't hold up
    davyjones likes this.
  2. twinrider
    twinrider Pass the catnip
    Aug 20, 2002
    17,717
    日本
    I would go with powdercoating myself. I think I'm going to make my silver Givi skidplate, which appears to be powdercoated, black.
  3. ArkieRider
    ArkieRider Been here awhile
    Apr 29, 2013
    710
    Greenbrier, Arkansas
    Appreciate the input. Yep I’m sure powder coating is the best route...but since I already have the self etching primer and bedliner stuff, I may try the cheap route first to see how it holds up. Plus it can be easily touched up I imagine
  4. Slowklr
    Slowklr Attempting to fall in style
    Jul 20, 2019
    82
    Texas
    I use spray on bedliner on my trucks skidplates and when I damage it I just respray the damaged spots. I'm thinking about doing the one on the Tenere so it has some sound deadening but the exhaust is mighty close to it so I'm wondering if it will get burned.
  5. ArkieRider
    Apr 29, 2013
    710
    I plan to put a coat of high heat paint between the primer and Bedliner and then maybe a couple of coats over the Bedliner.
    But if I find the heat is an issue I’ll try the high heat paint alone
  6. ram350
    ram350 Adventurer
    Jan 25, 2006
    69
    My shock has blown a seal and Yamaha says the shock is not rebuildable. New shock is $3100.00 Canadian. Anyone know of someone who does rebuild the stock shock. This is the ES model. Or possibly someone who sells a replacement at a better price.
    RiderA2B likes this.
  7. Paul466
    Paul466 Been here awhile
    May 28, 2013
    110
    Colorado
    Get a Ohlins for $1200
    Bill 310 likes this.
  8. Bill 310
    Bill 310 Poser Emeritus Super Supporter
    Dec 4, 2002
    5,083
    Slip 35
    For $3100, you can get a Traxxion front end, an Ohlins rear shock and still have gas money left over
    Paul466 likes this.
  9. twinrider
    Aug 20, 2002
    17,717
    日本
    There’s a thread on the S10 forum that says the shock can be overhauled. Race Tech, etc.
  10. theregulator
    theregulator Shut Up and Ride Supporter
    May 26, 2002
    565
    Philly
    RT can rebuild the shock. They also do re-valving. They don't have adequate experience with an actual ES to make them proficient with proper replacement springs. Something about the difference in geometry between the standard and ES model...
  11. Paper
    Paper I can see Iowa from my yard!! Supporter
    Feb 23, 2003
    8,013
    Seneca, WI
    I thought the only difference was the electric servos that adjust the shocks?
    And heated grips.
    Paul466 likes this.
  12. BergDonk
    BergDonk Old Enough to Know Better
    Nov 15, 2010
    14,105
    Snowy Mountains Oz
    I expect Cogent can sort it. Great people too. Maybe @NC Rick will chime in?
    WVhillbilly and Paper like this.
  13. Milechaser
    Milechaser Long timer
    Jul 20, 2014
    2,003
    Vermont
    It took me a year for Race Tech to figure out a spring for my 2015 Super Tenere ES.
    Works great. They recommended revalving but I didn’t live close enough to anyone they use at the time.
    One place is in New Jersey if I remember correctly of course the other in California.
    Not sure what you need for a spring set up but my set up works great for me 200lbs plus and all my gear, luggage, ect.
    And handles passenger also no problem. If you want to talk to Race Tech and ask them what my set up is for exact specs tell them to look at Karl Emde’s specs. Hope this helps.
    For the record why it took so long was because they had not had hardly any ES’s to work with. They were very accommodating.
    FYI
    Installing the spring yourself is no joke. You have to do it with the shock still connected to the bike. Little room for error!
    Make sure you have a good spring compressor!
    Good luck and hope this helps anyone who needs it.
  14. Maverick2076
    Maverick2076 Adventurer
    Jul 16, 2018
    91
    Texas
  15. ram350
    ram350 Adventurer
    Jan 25, 2006
    69
    Thanks for all your reply’s regarding my leaking ES shock. I will have to make some calls and get a firm answer from some of your suggested vendors.
  16. russell44
    russell44 Adventurer
    Jul 8, 2017
    86
    Dartmouth, Nova Scotia
  17. ram350
    ram350 Adventurer
    Jan 25, 2006
    69
    Has anyone actually had their ES shock rebuilt
  18. Super08
    Super08 Been here awhile
    Dec 29, 2017
    311
    Alberta
    Some have, I was talking to one of the suspension shops down in the states and they have not had very good success with rebuilding/revalving them.
  19. Super08
    Dec 29, 2017
    311
    Alberta
    Ed, is that you?
  20. WVhillbilly
    WVhillbilly Long timer
    Oct 20, 2010
    40,211
    WV
    Different stickers :deal
    Paper likes this.
