    Dismiss Notice
The Yamaha Super Tenere XT1200Z Big Thread
Discussion in 'Japanese polycylindered adventure bikes' started by mr moto, Feb 9, 2008.
  1. fpalbrecht
    fpalbrecht Been here awhile
    Aug 17, 2008
    152
    Lake Mills, Wisconsin
    Probably not this simple, but turn off traction control and see how it performs. If you haven't already done so.
    treybrad, swakop_toe and lukasteam like this.
  2. Midnightventure
    Midnightventure -
    Dec 23, 2008
    1,244
    Eldon,Mo
    Part of the reason I have decided to not buy anything the previous owner has done any modifications to. Personally I think that is why so many have problems with Harleys because they almost all get modified.
    JeepDawg and RonKZ650 like this.
  3. elricfate
    elricfate '15 S10 ES
    Sep 6, 2019
    54
    Ohio
    On the flipside of that though, the previous owner of my bike made a lot of modifications that were not performance based. Adding lighting controllers and aux LEDs and whatnot, but they did replace the air filter with a K&N (recently discovered when doing my plugs) - so I guess that's a "mod", per se. Personally as long as the bike runs when it's cold AND when it's hot, without sputtering or spitting, and it has a smooth power curve all the way through, I don't care what you did to it. But I see your point on wanting a bike mostly stock so you can either leave it that way or do the things you want to do to it. It's why a lot of folks keep the stock parts around to swap back in when they sell. If it's not something I can get rid of locally, I just chuck whatever parts I take off.
  4. Midnightventure
    Midnightventure -
    Dec 23, 2008
    1,244
    Eldon,Mo
    When I bought my Tenere it was loaded with luggage, cruse control, lights and other stuff and I was and am tickled. But the engine had nothing done to it. I had a DR650 previously that had all the forum recommended things done to it including opening up the airbox. It never failed to start and never failed me but it was always surging just a little. I took what I could back to stock and the gas mileage improved significantly but it just never was perfect. Now my stock 1200cc Tenere gets much better gas mileage and since the recall was done on it runs perfect.
    Jdhuff and elricfate like this.
  5. HAYVIATOR
    HAYVIATOR Don't be me dude.
    Dec 1, 2012
    453
    Skagitopia, WA
    you don't happen to know which speed bleeders you bought to plug the 4 holes?
  6. pnw-rider
    pnw-rider Adventurer
    Apr 26, 2017
    64
  7. Jdhuff
    Jdhuff RAT BRAIN
    Aug 1, 2013
    50
    Mississippi
    I've put speed bleeders on every bike I've had since about 85. They make it so easy.
  8. Milechaser
    Milechaser Long timer
    Jul 20, 2014
    1,985
    Vermont
    I’m sorry if I’m not following.
    I thought that there was no issues with the 2014 S-10 and up?
    I have a 2015 with over 87,000 miles on it. I’ve noticed a little rattling of some sort when I’m in neutral?
    When I pull the clutch lever in it seems to disappear?
    So I’ve been trying to pay attention to some of these posts.
    Thank you in advance.
  9. Pdrhound
    Pdrhound Been here awhile Supporter
    Aug 15, 2015
    530
    80421
    My '12 rattles always until about 2000-2500 RPM. Sat down with mechanic friend and stethoscope one day a few years ago and isolated it to the clutch. There is a "star "shaped sprocket thingy in there". He felt that was the culprit like he had seen on others bikes over the years. I wonder if you got the same rattle as me? Mine does not changes pulling in the clutch.
    I'm probably going to get second opinion when i get my second valve check at 60k.
    But its been the same for 30000 Miles.
    You can see how spot on (not) my science is on this subject.
    Milechaser likes this.
  10. Milechaser
    Jul 20, 2014
    1,985
    Vermont
    Been an awesome bike and the last thing I want to say is that I’ve never had to do anything and then kaboom
    I like anything that after it’s been used for some time that the tones or other noises can be a little more pronounced.
  11. BaldKnob
    BaldKnob I Wanna Ride
    Jun 3, 2013
    1,795
    SENC
    Most, if not all, wet clutch applications will have some added noise when disengaged. Not to worry... they will do that.
    Jdhuff, Milechaser and DirtyRoadie like this.
  12. NightWatcher
    NightWatcher n00b
    Feb 4, 2020
    6
    attiki hellas
    Hello all S10 owners.
    Do you upgrade ecu ;
    It is wirth it what difference do you see in reality and dyno.
    2. Exhaust ?
    I have a stock S10 1st Gen for 65K and its a man machine. i can say !
    DirtyRoadie likes this.
  13. HeliMark
    HeliMark Long timer Supporter
    Jun 23, 2013
    1,106
    Tennessee
    Absolutely on the tune. You can get rid of the restrictions in the first three gears, and smooth it out some. And with the right tune, a little more power. Exhaust, really depends on what you want. It will help on the power, but are you looking for that? You will feel it, but it is a heavy girl, and most do not do the exhaust.
    NightWatcher and DirtyRoadie like this.
  14. DirtyRoadie
    DirtyRoadie Long timer
    Nov 8, 2009
    1,002
    Western N.Y.
    Yes on the ECU flash for the reasons quoted above. My son had a Gen I and had great result with ECU flash, Arrow header and Two Brothers exhaust. If you plan on keeping it a while it would probably be worth the money. I'm on a GenII and am really pleased with just the ECU flash.
  15. Milechaser
    Jul 20, 2014
    1,985
    Vermont
    Where are the recommended places to get ECU flash in the United States?
  16. DirtyRoadie
    Nov 8, 2009
    1,002
    Western N.Y.
    A lot of guys here on the forum use someone named Anthony. I have a shop 10 miles away that did mine with a super quick turn around time. Shop I used was Right Side Up Kreations in Webster NY.
    StanBo and Milechaser like this.
  17. NightWatcher
    NightWatcher n00b
    Feb 4, 2020
    6
    attiki hellas
    Yeah. I read again about the restrictions of first 3 gears and tune the ecu is the answer.
    The problem is where i can do that and do the right flash in Greece if someone know of course.
    For sure i dont need more power but if only with reflash i can get better result , why not .
  18. Milechaser
    Jul 20, 2014
    1,985
    Vermont
    Thank you. About 7-hrs from me.
  19. DirtyRoadie
    Nov 8, 2009
    1,002
    Western N.Y.
    Yeah, my daughter lives in Bradford VT. It takes us about 7 hours to get there if we go the scenic route through the Adirondacks. I love riding in VT, lots of dirt roads to get "lost" on.
    Milechaser and StanBo like this.
  20. Milechaser
    Jul 20, 2014
    1,985
    Vermont
    Just went through Bradford on Sunday
