The Yamaha Super Tenere XT1200Z Big Thread
Discussion in 'Japanese polycylindered adventure bikes' started by mr moto, Feb 9, 2008.
  1. Achtung
    Achtung Wicked Pisssah Adventurer Supporter
    Nov 1, 2002
    3,174
    Waltham MA
    Anyone have Anthony's contact info for a reflash? I'd like to get mine done this winter.
  2. HeliMark
    HeliMark Long timer Supporter
    Jun 23, 2013
    1,138
    Tennessee
    I think there is someone in the U.K. that does it. Some of the European guys here should know. If not, over on the Super Tenere forum there are a number that have done it, and will help you.
    NightWatcher likes this.
  3. theregulator
    theregulator Shut Up and Ride Supporter
    May 26, 2002
    568
    Philly
    User:
    avc8130
    MVI, Stomp347 and fpalbrecht like this.
  4. ArkieRider
    ArkieRider Been here awhile
    Apr 29, 2013
    711
    Greenbrier, Arkansas
    i have his email also. I’ll pm you with it
  5. Dons1911
    Dons1911 Long timer
    May 24, 2017
    1,143
    Hayden, Idaho
    Any Super Tenere owners in north Idaho or anywhere nearby?
  6. NightWatcher
    NightWatcher n00b
    Feb 4, 2020
    6
    attiki hellas
    Most owners i see you are from America
    Nobody from south europe
    So Ecu reflash to well known mechanics
    is difficult here
  7. ricerooster
    ricerooster Adventurer
    Sep 27, 2018
    39
    US
    Replaced my radiator fan motor after I dropped it from my last off road adventure. Fan motor is from a 2007 FJ, all I did was splice the wires together as they matched in color. When the fan kicks in its pulling air out instead of pushing air into the radiator, is this correct or did I wire it backwards?
  8. HeliMark
    Jun 23, 2013
    1,138
    Tennessee
    Yes, you got it right. Air comes in through the scoops, through the radiator and out. Fan helps it when needed.
    Jdhuff likes this.
  9. ricerooster
    Sep 27, 2018
    39
    US
    Awesome thank you.
  10. rd400racer
    rd400racer Long timer
    May 14, 2013
    4,728
    Louisville, Ky
    I'm simply confirming what I believe I've read in this thread regarding slip-ons, full systems, etc to make sure I'm keeping up. Keep in mind this is my son's bike and he doesn't live in the same town as the bike (it's in my garage).
    1. Simply replacing the stock exhaust with a slip-on is damn near useless without performing the cat clean out.
    2. With a cat clean out, the stock system damn near performs like a typical slip-on, so purchasing one doesn't help greatly.
    Am I correct in these assumptions? I recently met a guy that owns a welding shop and he'll perform the canister cut for a very reasonable amount. I've got all winter so no big hurry. Bike has been flashed.
  11. elricfate
    elricfate '15 S10 ES
    Sep 6, 2019
    58
    Ohio
    Yes and yes(ish) - on the second thought, for the most part you'll have a better experience with flashing the ECU for arrow headers as they remove the bell, meaning the transfer of gasses is far less turbulent, on the other side it acts as an expansion chamber, which helps a lot of 2 into 1 exhaust systems with burning exhaust more efficiently. The results of either are mostly negligible and equal to one another, so it's not really a big deal either way. If you got a guy who will cut and weld the catted system for cheaper than a set of arrow headers, you're pretty much good to go. Either way you should be seeking an ECU flash thereafter if you truly want to see results/not cause an overly lean condition.
    rd400racer likes this.
  12. BergDonk
    BergDonk Old Enough to Know Better
    Nov 15, 2010
    14,306
    Snowy Mountains Oz
    FWIW the Staintune slip on I fitted reduced some of the throttle snatch off closed throttle. That and fixing the header leak combined more or less eliminated it. I mainly fitted the Staintune so I could hear the engine, I never quite got used to not hearing the engine with the stock muffler and as a result was too often in too tall a gear when I needed throttle response.
  13. elricfate
    Sep 6, 2019
    58
    Ohio
    New Dunlop Trailmax Missions installed
  14. K Michael Kadinger
    K Michael Kadinger Adventurer
    Sep 28, 2019
    11
    Indianapolis IN
    Let me know what you think of them. I live in Indiana USA and while flat here lots of mud so I'mm intetested in how well they clean out and traction in the sloppy stuff
  15. NewEnglander
    NewEnglander Been here awhile Supporter
    Sep 9, 2007
    600
    Southern NH
    I have been running a set on my Super T for about 4000 mi now. Recently did the NEBDR with them. I don’t think they are even half worn yet, especially the rear. I am impressed with them. The front has great feel and seems to perform well in most terrain off road and on. The mud/ slick conditions are where the rear performs least well. The front seems good in the mud. My AX41’s were better off road (knobbies) but were very loud in comparison to the Missions.
    StanBo, BaldKnob, MFP and 3 others like this.
  16. twinrider
    twinrider Pass the catnip
    Aug 20, 2002
    17,742
    日本
    I'd wager the Shinko 804/805 and the Michelin Anakee Wilds will be much better in muddy stuff.
    Jdhuff likes this.
  17. OKDQ
    OKDQ Long timer
    Nov 7, 2009
    1,040
    OK
    Have you done much wet pavement riding in the 4K you’ve been running them? What’s your thoughts on them in that situation?
    Milechaser, Jdhuff and MFP like this.
  18. Karson
    Karson Been here awhile
    Apr 18, 2010
    334
    AMES IOWA
    Looking to pick up a Motofizz tail bag. Hoping to have it be double purpose as a softer backrest for a pillion, too. This will be replacing a Givi 46L on an AltRider rack. Can anyone offer insight on if the small or medium is best for this? I think the large is too big, but I'm not sure.
  19. Pdrhound
    Pdrhound Been here awhile Supporter
    Aug 15, 2015
    583
    80421
    8300 miles on gps tractionator. At the wear bars. Tire is 3 months old and the MOTOZ cracks had started. rear was good. lasted little longer then k60. not a fan of the front. gonna run a TKC 80 up there next. Had a e07+ rear mounted for the winter. IMG_20201014_112907384.jpg
    MFP likes this.
  20. zxrider11
    zxrider11 Been here awhile
    Jan 11, 2010
    717
    West Michigan
    For comparison, here is my MotoZ Tractionator GPS mounted in Off-Road direction with almost 11,000 miles. Will probably strecth it out for another 1,500 miles before replacing.
    Mixed riding of paved curves, 85mph highway loaded with luggage, Michigan sand, gravel & two-tracks. Typically run 36psi.
    Jdhuff, Pdrhound, MFP and 1 other person like this.
