The Yamaha TW200 Thread...
Discussion in 'Thumpers' started by neepuk, Jan 10, 2009.
  1. MartiniUp
    MartiniUp Long timer
    Jul 14, 2010
    3,337
    TX
    Any of you fellas 6'1"/ How do you adapt to a TW? Got a chance to pick up a nice one for a song.
    frog13 likes this.
  2. nihil
    nihil Adventurer
    Mar 17, 2018
    52
    Midwest
    I'm only 5'14", but it fits me pretty well after a set of bar risers.
    JagLite likes this.
  3. Allucaneat
    Allucaneat When do we stop to eat? Supporter
    Apr 25, 2014
    1,009
    Fayetteville, GA
    I'm 6'-0" and I think you'd hate it. Now, tell me where I can get that nice one for a song! :jack
    frog13 and JagLite like this.
  4. engineman
    engineman Been here awhile Supporter
    Sep 26, 2012
    727
    Eastern Iowa
    I'm 6'2" and have no issues with the fit. I put a set of pro-taper ATV high bars on which makes it about perfect.
  5. Allucaneat
    Apr 25, 2014
    1,009
    Fayetteville, GA
    Keep quiet! - he was just about to tell me where that great deal is!
    frog13, JagLite and cateyetech like this.
  6. James Adams
    James Adams Long timer
    May 29, 2006
    16,837
    Grand Junction
    I'm 6' and with a Seat Concepts tall seat it's a great fit.
  7. frog13
    frog13 Long timer
    Feb 10, 2007
    2,925
    SW Ohio
    Sing the song.......ride the TW. Enjoy !.
  8. NJ-Brett
    NJ-Brett Brett
    Sep 8, 2010
    9,390
    Southern New Jersey
    I am 6 feet tall, taller bars is all I needed.
    There is enough extra cable unlike some bikes...
    I got the normal seat concepts seat but the stock one is not all that bad.
    JagLite likes this.
  9. JagLite
    JagLite Long timer Supporter
    Jun 17, 2010
    7,951
    Anchorage Alaska
    I'm 6'-4" and I am very comfortable on the TW and almost always ride two up:
    That was the stock seat which was okay, but I installed a Seat Concepts and it is better.
    rjnutt, potski, juno and 8 others like this.
  10. Ride Now
    Ride Now Graybeard
    Aug 17, 2011
    427
    Yakima, WA
    These guys are lying to ya. :-) TWs are not meant for tall folks. Now, what's a good phone number to reach that "nice one for a song"? :lol3
  11. frog13
    frog13 Long timer
    Feb 10, 2007
    2,925
    SW Ohio
    Ride Now......I believe your out of luck.... :)
    Ride Now likes this.
  12. Cyclepath
    Cyclepath Lost wanderer
    Mar 17, 2006
    2,081
    SW. Wa. state
    1-800-EAT-SHIT
    opps got carried away. hahahaha :-)
    ChopperCharles, Ride Now and mentolio like this.
  13. azgsa
    azgsa Dude
    Feb 11, 2008
    1,711
    Central Arizona
    I've had 2 TWs in the last 6 or so years, both later 2006/2007 models, have the 2006 now. I could never get either running right at higher RPM's/speeds running down the road, they would cut out like they are starving a bit. Both acted exactly the same way. Tried everything, rebuilding the carbs, rejetting, etc. So couple weeks ago I decided to give the Amazon Chinese carbs a go, for a tad over $35 it seemed a good gamble. Well, I have to say my TW has never ran better. It's amazing how well it runs, over 70mph (until it got kinda scary with my Pirelli MT21 front tire weave), no hiccups or cutting out. I'm a believer. It appears to be an exact copy except for the throttle cable attachment piece, and it had a simple screw for idle adjustment. Just swapped the throttle cable mount and the idle adjust cable/knob with the ones from original carb. Can't want to take it up in my RV camping and exploring again. This is the one I bought on Amazon.
  14. frog13
    frog13 Long timer
    Feb 10, 2007
    2,925
    SW Ohio
    Just curious. On your OEM carbs when you rejetted them, did you use Teikei jets or Mikuni ? . Did you Rejet the main and pilot ?.....again , just curious.
  15. azgsa
    azgsa Dude
    Feb 11, 2008
    1,711
    Central Arizona
    Whatever the Yamaha part numbers refer to.
  16. offroadtoys
    offroadtoys Been here awhile Supporter
    Feb 14, 2013
    179
    Oak Harbor, OH
    Yep same here, yamaha part numbers. But mine is a 2000, old carb.
  17. mentolio
    mentolio Been here awhile
    Jul 14, 2016
    549
    At what throttle position did your bike “cut-out?” Any throttle position 3/4 or below is likely a needle issue (try one or two shims under the needle, test). Anything beyond 3/4 throttle is main jet (try going one size leaner, if no better start jetting richer). This is where I would start. A lot of carbureted bikes are kinda rich on the main, but have lean needles and pilots. This is how they meet emissions standards but still make halfway decent power. Could also be you have a bike jetted for low altitude but live in a high altitude, or vice-versa.
  18. afordableperformance
    afordableperformance Been here awhile
    Jul 22, 2010
    357
    I have been messing with TW's for a long time and I can't help but think he either had a low float setting or it is a flow issue through the needle. I have noticed on a few TW's I have tinkered with the fuel flow from the tank is good but once it makes the turn into the carb and then through the float needle the flow is greatly reduced even with the needle removed. That's what I would check and see if there's anything slowing the flow between the float needle and carb housing. Just a thought, but $35 is cheap for a working carb, if I have one I can't get going that might be an option!
    frog13 likes this.
  19. Cyclepath
    Mar 17, 2006
    2,081
    SW. Wa. state
    I'm sure glad that carb worked for you. Wish I knew what one to buy for the older TW. There is a million to choose from.
  20. WYO George
    WYO George I have no idea
    Sep 1, 2005
    5,593
    left of nowhere, WY
    I put the new style CV carb on my 1990 and am very pleased with the results.
    Eatmore Mudd and frog13 like this.
