1. eNewsletter Sign Up
The Yamaha TW200 Thread...
Discussion in 'Thumpers' started by neepuk, Jan 10, 2009.
  1. Cyclepath
    Cyclepath Lost wanderer
    Mar 17, 2006
    2,125
    SW. Wa. state
    Thanks for the reply. I might give that a try.
    What did you do about the different throttle cable positions and could you use the old twist grip assembly. And did it match up with the original air box rubber boot?
  2. WYO George
    WYO George I have no idea
    Sep 1, 2005
    5,885
    left of nowhere, WY
    Had to use the new style carburetor joint (front boot) part # 5LB-13586-02-00 and air cleaner joint (rear boot) part #5LB-14453-10-00 and I believe I used the stock 1990 throttle cable, but had to leave it as a single cable instead of two cables. Many dirt bikes and some dual sports (DR200 for instance) only use a single cable so I wasn't concerned about not having the safety redundancy of the push/pull cable. It's not like the TW has enough power to get out of control in the rare event the throttle sticks. So far it's been working this way fine for the last two years and 2,500 miles.
    turbodieseli4i6 likes this.
  3. WECSOG
    WECSOG Dirt Road Denizen
    Mar 30, 2013
    1,816
    Just past the pavement's end in North Alabama
    I put a genuine Mikuni VM26-606 on mine. I'm happy with it so far.
    frog13 and Nobade like this.
  4. Cyclepath
    Mar 17, 2006
    2,125
    SW. Wa. state
    Where did you get the Mikuni from and how much did it cost you and tell me about fitting it to the TW, if you don't mind
    frog13 likes this.
  5. Cyclepath
    Mar 17, 2006
    2,125
    SW. Wa. state
  6. Cyclepath
    Mar 17, 2006
    2,125
    SW. Wa. state
    Thanks for getting back to me with that info. I would never have a problem with a single cable carburetor. That's all we ever had back in the old days and the return spring inside of those old amals was pretty weak. If I go that route I will be looking up those part numbers.
    Do you know what kind of fuel mileage you are getting with that newer carburetor
  7. WECSOG
    Mar 30, 2013
    1,816
    I got it from Dennis Kirk. https://www.denniskirk.com/mikuni/2...de-carburetor-vm26-606.p165141.prd/165141.sku
    I'm running an angled pod filter with it, but it could probably be made to work with the factory air box if you prefer.
    Jetting was reasonable out of the box. I modified the factory pull cable and left the push cable disconnected. That's workable, but I intend to change to a cable that is a more proper fit to the carb.
    The carb fits the factory intake spigot like it was designed for it. This is on an '87 btw.
  8. WYO George
    Sep 1, 2005
    5,885
    left of nowhere, WY
    It’s hard to say because it’s mostly for my wife or friends to ride, but on the White Rim Trail it got 70mpg, that’s the only time I ever checked it.
    frog13 and Cyclepath like this.
  9. Cyclepath
    Mar 17, 2006
    2,125
    SW. Wa. state
    Thanks for the info mine is a 1994. So I think it should be the same
    WECSOG likes this.
  10. azgsa
    azgsa Dude
    Feb 11, 2008
    1,793
    Central Arizona
    Just got a tank bag for my tdub today thought I share the info. Looked around for the right one for awhile and found a guy on YouTube that had one of these, seemed like a good fit and not as expensive as the small Wolfman. Also easier to remove for fueling up and better features.
    SW-MOTECH EVO Enduro LT Strap Tank Bag | 5-7.5 Liters - US$103.95 shipped Link
    As it arrived:
    Mounting on TW200:
  11. azgsa
    azgsa Dude
    Feb 11, 2008
    1,793
    Central Arizona
    Close-ups of features:
    Front of bag cable pass-through and mount points for optional GPS/phone device mount (has rear pass-through also):
    Inside compartments:
    Expandable:
    Attention to detail, even an elastic zipper pull retainer for the expandable zipper:
    Internal waterproof bag included:
    Tank protection adhesive film sheet included:
    JagLite, frog13, WYO George and 5 others like this.
  12. Cyclepath
    Mar 17, 2006
    2,125
    SW. Wa. state
    What kind of tire do you have on the front of your TW.
    How do you like your Himalayan ?
  13. azgsa
    azgsa Dude
    Feb 11, 2008
    1,793
    Central Arizona
    Pirelli MT21.
    I like the Hima, it has its place in between the TW and Africa Twin. Cheap, simple, surprisingly good off-road, tractor-like long stroke single. Not good for long hi-way stints at higher speeds but 60-65 is fine.
    JagLite and Cyclepath like this.
  14. frog13
    frog13 Long timer
    Feb 10, 2007
    3,079
    SW Ohio
    I like the tank bag........ :)
  15. TheAdmiral
    TheAdmiral Long timer
    Apr 3, 2010
    2,967
    Frosty Hollow, Idaho
    Couple TW200's and a DT200 at 11,653 ft on Mt Patterson near Walker/Bridgeport CA. It was chilly up top...and windy!
    potski, wildknits, Ride Now and 6 others like this.
  16. frog13
    frog13 Long timer
    Feb 10, 2007
    3,079
    SW Ohio
    Admiral......if there's a video , can't access it ???.
  17. TheAdmiral
    Apr 3, 2010
    2,967
    Post above should just be a picture (no video yet). If there is a problem viewing the picture let me know. I've been getting reports of folks not being able to view my pictures on the TW200 Forum as well. If not being able to see my pictures (on both forums) I suspect my photo host (Google Photos) must be the culprit. ...and if that's the case I'll try and attach photo's directly instead of using the photo host. There may be a problem with Google Photos.
    P.S. I can see my posted pictures so I can't tell what the problem could be other than the Google!
  18. Nobade
    Nobade Keep on keepin' on...
    May 30, 2012
    1,206
    Albuquerque, NM
    The pic shows up on my preview but not if I open the forum. Using tapatalk on the phone.
  19. JagLite
    JagLite Long timer Supporter
    Jun 17, 2010
    8,270
    Anchorage Alaska
    No picture for me :dunno
  20. TheAdmiral
    Apr 3, 2010
    2,967
    Let me know if I fixed it. Thanks
    frog13 likes this.
