The Yamaha TW200 Thread...
Discussion in 'Thumpers' started by neepuk, Jan 10, 2009.
  1. Knute Dunrvnyet
    Knute Dunrvnyet Padawan
    Sep 3, 2005
    6,983
    CNY: "Traveler's Rest"
    They are for sale, somewhere, in Unobtainium Land... I'd love a set, simply because of our family's DT background; but, ultimately, on our gravel/dirt roads around here; there's no point.
  2. Mi0
    Mi0 Rock or something
    Aug 8, 2019
    104
    You should have seen him working the tire spoons, he said it was ruff. He works cheap though--all he wants is treats.
    MYUMPH, frog13, WECSOG and 5 others like this.
  3. nicholastanguma
    nicholastanguma nicholastanguma Supporter
    Sep 9, 2009
    3,081
    Downtown Los Angeles
    :rofl
    frog13 likes this.
  4. WECSOG
    WECSOG Dirt Road Denizen
    Mar 30, 2013
    2,007
    Just past the pavement's end in North Alabama
    :jack :lol2
    frog13 likes this.
  5. frog13
    frog13 Long timer
    Feb 10, 2007
    3,390
    SW Ohio
    MiO......nice sense of humor.....always appreciated. :)
    WECSOG and JagLite like this.
  6. heirhead
    heirhead worlds worst mechanic
    Jan 2, 2009
    1,471
    On the water in South OC
    Have used 3 xt225 Clarke tanks on my T-Dubs an 4 on my xt225s.
    Am a good customer.
    Trim the seat, trim the side panel,(right), move the pucks up and back, cut rear mounting bolt off, move it back just a little and fill tank and go. 4.1 ga!
    Pic with 4.1 Clarke and Cyclerack with bike rack and bike.
    NO, it did NOT handle well.
    hh
    wwm
  7. thumpism
    thumpism Between bikes
    Dec 16, 2005
    7,100
    Richmond, Virginia
    FB Marketplace shows several in Pennsylvania. Get a move on.
    https://www.facebook.com/marketplac...rch/?query=tw200&vertical=C2C&sort=BEST_MATCH
    *edit*
    I've heard the FB search can be wonky and it seems that the link above proves it. Try for yourself. There had to be a dozen of them. Good luck!
    frog13 likes this.
  8. ryder1
    ryder1 Long timer
    Nov 12, 2012
    7,297
    SEPA
    A little wonky is an understatement.
    When I click on a bike I get a blank screen on the phone.
  9. Cyclepath
    Cyclepath Lost wanderer
    Mar 17, 2006
    2,332
    SW. Wa. state
    Hi heirhead. I'm looking at the 4.1 gallon tank on your TW and it looks like the lowest part of the tank up toward the front is quite a bit lower then the entrance to the pet cock. If so there would be a lot of fuel that you can't use. Seems to me that the pet cock should be installed at the lowest part of the tank. Or am I just not seeing it right in the pic ?
    frog13 and JagLite like this.
  10. JagLite
    JagLite Long timer Supporter
    Jun 17, 2010
    9,084
    Anchorage Alaska
    Here is the 4.1 on an XT225 (from ProCycle website)
    Looking at the fuel lever through the tank I see you are correct.
    Just need to wheelie to the next gas stop. :ricky
    The right side has a step in the bottom that would trap some fuel behind it.
    If there is a step on the left side also, the rider could rock the bike with the front brake locked to slosh fuel from the lower front back to the rear pocket area.
    I haven't see the tank in person so I don't know if that is the case but the potential is there.
    Edit:
    Yes, the left side has the same shape:
    Cyclepath, Ride Now and frog13 like this.
  11. Cyclepath
    Mar 17, 2006
    2,332
    SW. Wa. state
    Hi Jag , thank you for posting that pic of the tank on a xt225. If you go back to that pic of the tw200 it looks like the front of the tank is much lower then on the xt225. So maybe it is just the way the tank got mounted on the TW. Also in that lower part of the 4.1 gallon tank how do you get the fuel from the right side to the left side without doing a wheelie like you said, hahaha
    It may be just the angle of the picture we are looking at but it appears to me that there would be quite a bit of fuel not being used? Back in the good old days, he he, there used to be a fuel crossover tube located at the lowest part of the fuel tank which was usually back near the petcock so you would draw fuel from both sides of the tank. I guess the manufacturers today are just not as smart as they used to be. Hahaha
    I wonder if the stock xt225 tank is built the same way as the plastic one? It would be pretty easy 2 modify the metal tank for a crossover tube with a quick disconnect line 4 easy tank removal without slobbering gas all over the place. I need to do some searches for the metal tank to see what it looks like. If I had a 4.1 gallon fuel tank I would not have to carry my rotopac. Maybe just a couple of small fuel canisters just in case.
    JagLite likes this.
  12. JagLite
    Jun 17, 2010
    9,084
    Anchorage Alaska
    I haven't noticed a tank with a cross over in many, many years... :scratch
    When I run really low on fuel I stop and lean my bike way over to the left to get the gas on the right side to flow to to the left side.
    No wheelie required! :ricky
    Not ideal but it does remind you that you need to get fuel soon. :yikes
    I would think there is probably a thread or three on the TW forum about installing different tanks on the TW.
    What is required to modify and how each works.
    I still have the stock tank on mine but if I was going to be traveling farther I would go with the 4.1 gallon.
    WECSOG likes this.
  13. Cyclepath
    Mar 17, 2006
    2,332
    SW. Wa. state
    Yeah, I'm prolly dating my self talking about such things as cross over lines :-) Like I had on my 1963 Triumph Bonneville and others......yikes..... that was a long time ago :gerg hahaha
    I have the Clarke tank on mine and it wasn't enough fuel on a 187 mile loop ride in Death Valley. Had to use my rotopack. So I have been just snooping around for an xt225 4.1 gallon metal tank. I would add a crossover line or maybe a second petcock on the other side of the tank.
    You know..... all of the different Triumphs I owned through the years had two petcocks and a crossover line. Today I guess that would raise the price of the bike another dollar.hahaha :deal
    JagLite likes this.
  14. Aguaski
    Aguaski Been here awhile
    May 2, 2018
    222
    Phoenix area
    The OEM XT225 tank is metal with a capacity of 2.3 gallons. Clarke makes an aftermarket plastic tank with a capacity of 4.1 gallons. I’m not aware of 4.1 gallon metal tank that is used on the XT225. If a metal tank is your requirement then your max capacity will be 2.3 gallons. If 4.1 gallons is your requirement then you’re likely going to have to settle for a plastic tank.
  15. JagLite
    Jun 17, 2010
    9,084
    Anchorage Alaska
    I "think" I read a thread over on the TW forum where some have used the stock metal tank from some bike or other that was around 4 gallons...
    If you can weld or know somebody, any big stock steel tank could be modified to fit.
    I have a slightly dented stock BMW GS tank that I laugh at putting on the TW some day.
    It is humongous!
  16. Nobade
    Nobade Keep on keepin' on...
    May 30, 2012
    1,532
    Albuquerque, NM
    XT350 tank is steel and quite a bit bigger than the TW tank. Don't remember how much though.
    JagLite likes this.
  17. WECSOG
    Mar 30, 2013
    2,007
    I have a steel XT tank, either a 500 or 600. Late '80s. I don't remember any more than that for certain, but I bought it to put on my TW. I might actually get around to it one of these days.
    I'm thinking it's an '87 XT600 tank. The Internet says the XT500 tank is only 2.3 gallons, and I'm quite sure it's bigger than that. But the Internet also says the XT600 had a 30 liter tank, or about 8 gallons. I don't think it's that big.
    JagLite and frog13 like this.
  18. WECSOG
    Mar 30, 2013
    2,007
    Here it is:
    No way is that 8 gallons. More like 3, maybe 3-1/2.
    frog13 likes this.
  19. WECSOG
    Mar 30, 2013
    2,007
    Edited post above.
  20. WECSOG
    Mar 30, 2013
    2,007
    frog13 likes this.
