1. eNewsletter Sign Up
The Yamaha TW200 Thread...
Discussion in 'Thumpers' started by neepuk, Jan 10, 2009.
  1. Padilen
    Padilen Long timer
    Jun 21, 2014
    3,491
    I created an issue on my DRZ. I used a California tank. Plugged the air vent. I mistakenly assumed that if gas leaked out air could get in. Once I un- plugged vent gas flowed. Is gas flowing to carb all the time.
    JagLite likes this.
  2. Mi0
    Mi0 Distilled potato connoisseur
    Aug 8, 2019
    83
    Lowcountry
    I do have a question on using the clutch since my finger naturally curls back on the bar thus not covering the lever like @afordableperformance mentioned. When I shift down I usually do not disengage the clutch. Is that a bad habit? I only do this when I am moving fast on trails (by fast I mean TW speed).
  3. frog13
    frog13 Long timer
    Feb 10, 2007
    3,076
    SW Ohio
    JagLite. If you don't mind, and if your brother is so inclined, have him switch the main jet only from your bike ( carb) and put in your brothers bike ( carb).....just to see the affect. If it starts.....it's definitely his carbs main jet......if this hasn't already been done.
    JagLite likes this.
  4. frog13
    frog13 Long timer
    Feb 10, 2007
    3,076
    SW Ohio
    Always disengage clutch during shifts.....unless it's a gigga-second emergency.
  5. afordableperformance
    afordableperformance Been here awhile
    Jul 22, 2010
    405
    I have experienced issues similar to this and it has been moisture in the fuel (E10) and/or tank. Look very close at the main jet you will most likely see a small water bubble on the jet keeping fuel from passing through the main jet. It takes a lot of flushing and 100% gas if you have it in your area. Otherwise you may have to run some sort of additives or filter your gas. That has been my experience and it was mainly due to E10 been running 100% with no issues for many years now.
    JagLite likes this.
  6. nihil
    nihil Adventurer
    Mar 17, 2018
    71
    Midwest
    Some bikes can tolerate clutchless shifting, to a point. As a general rule, always have a finger on the clutch. Not just for shifting, but modulating it along with throttle for more finite control under the sometimes odd circumstances a farmbike in the woods can get you into.
    Maybe pick up a set of adjustable shorty levers if you haven't already.
    Mi0 likes this.
  7. Mi0
    Aug 8, 2019
    83
    Lowcountry
    Already got shorties.
    JagLite likes this.
  8. Padilen
    Padilen Long timer
    Jun 21, 2014
    3,491
    I'm a bad person, I shift without clutching often. It's actually a good skill to learn. If you ever break a lever, your not stranded.
    JagLite, WYO George and Mi0 like this.
  9. FEG32
    FEG32 Too old and fat for any of this.....
    Aug 23, 2010
    245
    Cincinnati, OH
    Added a little peace of mind in the form of additional fuel capacity. 614FFA5C-DA30-4ECE-A0E2-FB3F04E9D561.jpeg A0AC612D-7D71-4FCB-9FC6-DE4B4287F8D0.jpeg
    JagLite and frog13 like this.
  10. FEG32
    Aug 23, 2010
    245
    Cincinnati, OH
    You’re gonna love it, congrats!
  11. NJ-Brett
    NJ-Brett Brett
    Sep 8, 2010
    9,586
    Southern New Jersey
    I would remove the gas tank and do a POR-15 on it.
    That will take care of any rust or grunge in it that will plug up small jet passages.
    You can then remove the fuel filter, they can cause problems.
    My bike, with the pro cycle jet kit needs choke to start and a little bit of throttle.
    Once it starts, it will idle high and I can put the choke to the center position and ride off.
    In summer I can turn the choke off and ride off, but not in winter.
    The bike will not start on the choke without some throttle.
    As an easy test, before trying to start it next time, have him turn the gas on, then open the carb bowl drain screw for a second and let some gas/water out,
    close, then try and start with the choke on.
    I agree, the main jet has nothing to do with starting, it can be plugged up and the bike should still start normal.
    Sounds more like water in the gas as it WILL be at the bottom of the float bowl.
    JagLite likes this.
  12. NJ-Brett
    NJ-Brett Brett
    Sep 8, 2010
    9,586
    Southern New Jersey
  13. FEG32
    Aug 23, 2010
    245
    Cincinnati, OH
    Yeah, very well could be, I’m gonna give it a go and if it feels weird I’ll mount it to the top.
  14. WYO George
    WYO George I have no idea
    Sep 1, 2005
    5,869
    left of nowhere, WY
    I would take a good look at the float level. If the float valve is letting fuel slowly seep in too high then it will self correct when he drains the bowl to remove it and blow through the main jet. A simple test with a clear tube will show you where your fuel level actually is. It's also how you double check your float settings after a carb rebuild.
    Most bike carbs will have the fuel level at or just slightly below the parting line where the bowl meets the body. I'll see if I can dig up the exact measurement for a TW, or if not I'll go grab the measurement off one of the ones in my shop that has a brand new carb on it. I work on so many different bikes that I no longer trust my memory when it comes to all the details of a particular model.
    Mi0, frog13, Ride Now and 3 others like this.
  15. frog13
    frog13 Long timer
    Feb 10, 2007
    3,076
    SW Ohio
    WYO George.......nice!.
    WYO George likes this.
  16. Fr8dog61
    Fr8dog61 Been here awhile
    Aug 15, 2016
    373
    Lake Barkley
    “Fuel level gauge” is just a piece of clear tubing.
  17. Lil' Steve
    Lil' Steve PussyWagon™ Chauffeur Supporter
    Oct 3, 2006
    5,892
    Gilbert, AZ
    I see you already received some good suggestions. But the problem is you're a few miles away from the bike. OK, a little more than a few. Let us know when you'll be down again next month and we'll try to get it sorted out. Then we can go to that great Mexican restaurant again! :dukegirl
    frog13 and JagLite like this.
  18. JagLite
    JagLite Long timer Supporter
    Jun 17, 2010
    8,238
    Anchorage Alaska
    I like that idea! :beer :ricky
    frog13 and Lil' Steve like this.
  19. frog13
    frog13 Long timer
    Feb 10, 2007
    3,076
    SW Ohio
    Love it when a plan comes together!.
    JagLite likes this.
  20. frog13
    frog13 Long timer
    Feb 10, 2007
    3,076
    SW Ohio
    Nice !...... a good team member you are.
    JagLite likes this.
