The Yamaha TW200 Thread...
Discussion in 'Thumpers' started by neepuk, Jan 10, 2009.
  1. Little Bike
    Little Bike Air/Clutz Sue Supporter
    May 13, 2012
    12,573
    Oceanside CA
    It’s beautiful up there. I was on my way to an overlook when I got to a pretty steep rocky uphill (the kind of steep where if you stop with the brakes on you just slide backwards) and the bike kept losing speed as it got bounced around and just couldn’t make it. Unfortunately there wasn’t enough room to make a run at it.
    JagLite likes this.
  2. JagLite
    JagLite Long timer Supporter
    Jun 17, 2010
    9,897
    Anchorage Alaska
    That sounds like an area where a really good shock shines, keeping the rear tire on the ground while climbing a rough hill.
    The Cogent Dynamics shock on DR 650's made a huge difference climbing dirt roads with corrugated surfaces.
    With the stock shock the bike would slow down no matter what you did with the throttle as the rear tire just didn't stay on the ground long enough to generate enough forward motion.
    With the new shock I could easily accelerate, slow down, speed up, stop and start again, all with excellent traction even on the worst trails and roads.
    Nobade and Little Bike like this.
  3. Little Bike
    May 13, 2012
    12,573
    Oceanside CA
    I would like to upgrade the suspension on the little thing, at the very least my back and butt will thank me!
    JagLite likes this.
  4. Johnny Phoenix
    Johnny Phoenix Adventurer Supporter
    Jul 16, 2015
    65
    SW Wisconsin, USA
    Seat Concepts for the butt, start with fork oil level for the rest...
    On the other hand, I have changed both my front and rear springs and am pleased with the result. The front were Hyperpro #SP-YA02-SSA022 and the rear was the Procycle 15 kg/mm spring. I had to add more oil to the front springs to prevent bottoming out, and some say simply adding a bit more oil to the front is enough. All I can say is that when I decided to change my setup, it was winter and I was bored...
    JagLite and Little Bike like this.
  5. NJ-Brett
    NJ-Brett Brett
    Sep 8, 2010
    11,028
    Southern New Jersey
    The front is easy, springs and emulators, the back calls for a new shock.
    Don't forget to air down, I run 5 psi and I think its still a bit stiff.
    JagLite, Little Bike and Yamasakialo like this.
  6. DomEOD
    DomEOD 'murica
    Apr 10, 2013
    3,160
    Colorado Springs, CO
    I wish I could run 5psi. At my weight, a little air time at 10psi and I hit the rim. I’m limited to 12psi up front.
    JagLite likes this.
  7. NJ-Brett
    NJ-Brett Brett
    Sep 8, 2010
    11,028
    Southern New Jersey
    Worked last night so was off today.
    Kind of cool out in the morning after a short heavy rain, more rain in the forcast, its TW time!
    Since I had wet sand, I decided to explore some sandy roads and explore a bit into bad area's.
    What I call the trail/road to hell, its super thick sand and/or a flood zone, most times both:
    Just churn through the stuff:
    Some nice spots close by though, popular with the kayak people.
    Its a more open area.
    Some singletrack in the mix.
    About 75 miles of hard fun.
    I had a little rain on the way home, about 10 drops, so an ideal day.
    About 10 deer, nothing/no one else, had a lot of wild blueberries which were super good.
    The TW did great.
    velofish, NxtGoRnd, wildknits and 6 others like this.
  8. Little Bike
    May 13, 2012
    12,573
    Oceanside CA
    Is that the seat concepts seat?
  9. NJ-Brett
    NJ-Brett Brett
    Sep 8, 2010
    11,028
    Southern New Jersey
    Yes, the standard seat setup with a gripper top I think they call it.
    Its wonderful.
    The stock seat is better then almost any other stock seat on a bike except maybe the vanvan but the seat concepts kit takes it to another level.
    JagLite, Little Bike and JB44 like this.
  10. NJ-Brett
    NJ-Brett Brett
    Sep 8, 2010
    11,028
    Southern New Jersey
    I don't have the stock tire up front.
    The stock tire is very soft and thin (and light).
    The Kenda is a much tougher and stiffer tire, and also a lot heavier, but I slam into roots and such no problem at 6 psi.
    Rocks might be different...
    When I sit on the bike, brake, the tires do not seem to bulge much.
    JagLite and DomEOD like this.
  11. Yamasakialo
    Yamasakialo Adventurer Supporter
    May 16, 2020
    74
    Nc
    Looking at your front fender. I have a lower extension on mine. I see you also have a upper extension. What are you using?
  12. NJ-Brett
    NJ-Brett Brett
    Sep 8, 2010
    11,028
    Southern New Jersey
    Plastic jug stuff, Iced tea I think.
    Small screws with aircraft locking nuts on them.
    Helps a huge amount.
    JagLite likes this.
  13. DomEOD
    DomEOD 'murica
    Apr 10, 2013
    3,160
    What Kenda is that? I’ve got the Shinko 241 and absolutely hate it.
  14. NJ-Brett
    NJ-Brett Brett
    Sep 8, 2010
    11,028
    Southern New Jersey
    Its the Kenda version, which is a bit softer with taller knobs but otherwise the same tread pattern.
    What is wrong with the 241?
    I have not used a trials tire in a long time but many riders like them.
  15. NJ-Brett
    NJ-Brett Brett
    Sep 8, 2010
    11,028
    Southern New Jersey
    Went for a street ride last night on my sold (maybe) TU250 and thought a TW350 with a 6 speed would be about the ideal all around bike
    for my use, fun and fast enough on the street to go anyplace, great in the sand and mud off road.
    The TW does amazingly well on the street, only limited by engine size/rpm, a bit more power and anther gear for some overdive would be SO nice....
    Never happen though.
    JagLite and Yamasakialo like this.
  16. Little Bike
    May 13, 2012
    12,573
    Oceanside CA
    I was thinking the same thing the other day, a tw350.
    JagLite likes this.
  17. youngforever
    youngforever Been here awhile
    Jul 26, 2019
    122
    Puerto Escondido mexico
    I dream to ride back to South America to explore the Andes and sail down the tributaries rivers to reach the great Amazon river. It's a 24 months expedition. I'm leaving in about 18 months and I have a hard time finding the right motorcycle for me. I stumbled on a guy riding a very old tw200. We chat and I like he was saying but I fear that it had been out of production long time ago. When I got home, I went right away to my computer to find more about it. It looks like exactly what I'm looking for. I have lots of reading to do and I will certainly spend all my free time reading this thread.
    wallydude440, JagLite and Nobade like this.
  18. Jungle Biker
    Jungle Biker n00b
    Oct 3, 2008
    5
    Papua New Guinea/UK/US
  19. Little Bike
    May 13, 2012
    12,573
    Oceanside CA
  20. Little Bike
    May 13, 2012
    12,573
    Oceanside CA
    There’s also a tw forum. The availability of these bikes right now is awful, all the ‘21s are pretty much sold out and the used market is very overpriced (thanks Covid). You’ll want to get a deposit in on a ‘22.
    Yamasakialo likes this.
