The Yamaha TW200 Thread...
Discussion in 'Thumpers' started by neepuk, Jan 10, 2009.
  1. sibyrnes
    sibyrnes Been here awhile Supporter
    Sep 16, 2019
    160
    Western Pa
    Doesn't he realize you should check chain tension with the bike sitting on the ground? Adjusting while on a center stand will result in the chain being too tight when the shocks compress under weight.
    frog13, JagLite, Dno and 1 other person like this.
  2. Dno
    Dno Been here awhile
    Mar 30, 2021
    999
    Nc
    7-27 in the manual highlighted under TIP there should be no weight on the motorcycle. I believe yamaha's spec takes your concern into account. Pretty loose spec. But yes I agree that the chain will get tighter with weight. Thanx now I know after looking up. Other year manuals might have been different.
    JagLite likes this.
  3. WECSOG
    WECSOG Dirt Road Denizen
    Mar 30, 2013
    2,195
    Just past the pavement's end in North Alabama
    I have it on good authority that a stone-stock '22 TW will do 76.5 mph on flat ground, GPS verified. Just thought some of you might like to know.
    frog13, wildknits, JagLite and 2 others like this.
  4. Dno
    Mar 30, 2021
    999
    Nc
    Wonder the rpm. Mine sounds wound out. My xt buried the speedo a few times so Im familiar. The tw is a little less torque but does sound good 55-60mph with a nice pull. Maybe I should worry less and let er rip. Pulls 35mph in 5th like a champ. All stock. Feels a little lean. Brass plug needs to come out!
    frog13, WECSOG and JagLite like this.
  5. JagLite
    JagLite Long timer Supporter
    Jun 17, 2010
    10,089
    Anchorage Alaska
    How strong was the tailwind? :hmmmmm
    :hide
  6. Dno
    Mar 30, 2021
    999
    Nc
    Elbows in or out?
  7. JagLite
    Jun 17, 2010
    10,089
    Anchorage Alaska
    Probably laying flat like Rollie!
    WECSOG and Dno like this.
  8. Dno
    Mar 30, 2021
    999
    Nc
    Superman is the new style. Never seen it on a tw
    JagLite likes this.
  9. sibyrnes
    Sep 16, 2019
    160
    Western Pa
    I know what the manual says but I think they mean no additional weight, like a rider. The bike has no center stand so it is highly unlikely they would spec chain tension with the bike on a stand. I adjust mine with the bike sitting on the ground and it is perfect.
    Dno, Mike Dirt and JagLite like this.
  10. WECSOG
    Mar 30, 2013
    2,195
    Yeah, I was in a full tuck. No tailwind, though. Based on extrapolation from Gearing Commander, it was probably about 10,200 rpm, which I have read is the redline. Henceforth I intend to keep it below 70 mph, and that only for the occasional short highway jaunt.
    wildknits, Dno and JagLite like this.
  11. Dave in Wi
    Dave in Wi Long timer
    Feb 25, 2007
    2,790
    Madison WI (40 Square Miles Surrounded By Reality)
    Hey look at the speedometer, redline is 55 mph!
    I saw 76 on mine (Speedo not gps) in a tuck, with a 47 tooth rear sprocket. I haven’t tried it with the stock 50 tooth, but it sure sounds wound out at 55 or 60. Maybe I’ll try it tonight.
  12. debaisley
    debaisley Long timer
    Apr 2, 2008
    1,602
    Big Bone, KY
    I Don't think its the redline , every Yamaha dual sport from the 80s had the same speedo , I had an xt350 and xt600 with the same speedometer, was red after 55
    JagLite likes this.
  13. sibyrnes
    Sep 16, 2019
    160
    Western Pa
    Right, it's not the redline. In April of 1987 the national speed limit was raised to 65 mph. The TW, introduced in 1987, was designed during a period when the national speed limit was still 55 mph.
    JagLite, mentolio and WYO George like this.
  14. Nobade
    Nobade Keep on keepin' on...
    May 30, 2012
    1,665
    Albuquerque, NM
    It should be still. TWs nationwide would be happier.
    SwampFox883R likes this.
  15. Dave in Wi
    Feb 25, 2007
    2,790
    So I did end up going out for a top speed run with the stock gearing. I cleaned and lubed the chain, and set tire pressures to 18R and 20F.
    I saw 70 for about half a second, in a tuck. I’m curious what others are getting stock. Big difference between 70 and 76…
    JagLite likes this.
  16. Phoenix101
    Phoenix101 Long timer
    Nov 24, 2008
    4,402
    Right Side of WA
    Why???????????????????????????????????????????? It is a TW!
    Ride Now and AJ41 like this.
  17. Motor7
    Motor7 Long timer
    Sep 16, 2013
    1,735
    East Tennessee
    Just joined the Dub-Club, 1999:
    Bogs a bit on initial throttle(needle adjustment?), the clutch cable adjustment is maxed out and there is a 'crunch' after shifting gears. Also missing the odo(ordered) along with a clutch cable.
    I was at Dusty's West38Moto level 2 class in NM last week and another rider was selling it so I bought it and tossed it in the van. When I told the wife I spent 18 on it she about shit a brick...she thought $18,0000....not $1,800...lol.
    Ride Now, WECSOG, JagLite and 2 others like this.
  18. sibyrnes
    Sep 16, 2019
    160
    Western Pa
    Based on what TWs are going for nowadays, you got a hell of a deal!
    Is that rear rack welded onto the frame? On second look it appears to be welded to the passenger peg. Not bad.
    Make sure the clutch return spring (down on the crankcase) is installed and functioning properly. Seems to be a pretty common problem with TW's.
    frog13, JagLite and Dno like this.
  19. Motor7
    Motor7 Long timer
    Sep 16, 2013
    1,735
    East Tennessee
    It needs some TLC and maybe a clutch-pack, but yeah I'm happy. As far as the Tusk rack, I didn't notice, but will look at it in a few. Someone also painted the frame and rack to match...did a pretty good job.
    JagLite likes this.
  20. Dno
    Mar 30, 2021
    999
    Nc
    Wonder about sag now for bike only. 2022 is stiff I think bike alone is very little sag if any. I could always feel and hear tight and loose chains. Ill check havnt had to adjust mine yet
    JagLite likes this.
