Thinking outside the box...Post your Farkels!
Discussion in 'Equipment' started by HighTechCoonass, Oct 27, 2007.
  1. 9mm
    9mm Been here awhile
    Apr 18, 2006
    610
    "Southeast of Disorder"
    Well hell ain't that cool. I learned something here!
    Maggot12 likes this.
  2. mrgizmow
    mrgizmow Been here awhile
    Jan 28, 2007
    182
    Paradise, Calif.
    If you set it up right and have room on the primary shaft, you can set up a dual front as well. When I first started experimenting with this concept I was able to do 13/15 front and 50/55 back without additional chain. It was a fun option to have at the ready for an extended adventure that involved lots of pavement then rough technical back country. Mostly stayed in the 'low' back country range.
  3. HeatXfer
    HeatXfer Bad knees
    Feb 18, 2008
    866
    S.F. Bay Area
  4. Tall Man
    Tall Man Govern yourself accordingly.
    Jul 14, 2007
    6,840
    The Occident
    It's a two-handed job, but a straightforward one. I use a 22mm combination lever to hold the left (welded) side as I tighten the 24mm axle nut on the right side. A 15/16ths socket works if you don't have a 24mm in the tool box.
  5. johnpma
    johnpma Been here awhile
    May 15, 2017
    298
    Western Mass
    Set of $169.00 pegs is not in the budget at this time so I made a set of "peg inserts" to replace the Honda rubbers peg4.JPG peg2.JPG
  6. JensEskildsen
    JensEskildsen Long timer
    Mar 24, 2009
    2,280
    Denmark
    Put some weight against the wheel, or slightly tighten the nut for the axle. Some put a rag or a screwdriver between the chain and sprockets to tighten it up.
    I change gearing a lot, as I use my bike for a lot of things. I hate dealing with the modern ones with nuts.
    I can change gearing on my xt600 in like 5 minutes, and have the chain tension spot on.
    I've done it on parkinglots, gravelroads ect all over the country
    phreakingeek likes this.
  7. Muddler
    Muddler Long timer
    Dec 12, 2008
    1,128
    Dardanup, Western Australia
    Yep, chuck a rag in and turn the wheel so it pulls the chain tight and holds the snail in place while you finish the job. Actually, I find I need to do it with the other type of adjusters too
  8. cycleTown650
    cycleTown650 Been here awhile
    Feb 29, 2016
    249
    San Diego, CA
    Built a quick release bike rack that worked with the puck system of the happy trail rear rack. Can also carry a surfboard or odd long items.
  9. lord_oblivion
    lord_oblivion Been here awhile
    Sep 8, 2011
    178
    On the Roads of Motherland
    Fiskars X10 Axe mounted, for quick release & use. Mostly in the forest trails :D
    Slick and slim :
    Btw, nice tool, very sharp from store.
    Ironforge and Macho Man2 like this.
  10. drakehouse
    drakehouse Burnin' & Turnin'
    Nov 30, 2008
    141
    Pruned up from swiming in the sea of life
    Bump
  11. Patek
    Patek Long timer
    Feb 17, 2015
    1,028
    Raleigh, NC
    I like the ingenuity. However, I'm a bit scared of that setup, not sure why. Maybe it is because it is just one more thing to get tangled with in an accident.
  12. GS Addict
    GS Addict Pepperfool Supporter
    Sep 24, 2006
    7,445
    Sunshine Coast B.C.
    I look at that setup as causing an accident
  13. cycleTown650
    Feb 29, 2016
    249
    San Diego, CA
    I hear ya. I ride at 50% my ability when I throw that rack on so that helps with the fear factor.
  14. Buckee
    Buckee Scott
    May 17, 2013
    1,409
    Northern Neck of VA
    650, brilliant constructive response. You built your design, you weigh the safety factors, you ride with it. ADV is about riding over challenges, not avoiding them. Sounds like you are pretty dialed in when rigged up that way - go!
  15. Gedrog
    Gedrog 1000 mile stare a 1000 stories to tell
    Oct 20, 2013
    3,412
    Lost in the Sahara
    Not my Bike but Garry did a Round Africa trip with a surfboard attached thread here
  16. fhfr436
    fhfr436 Thirsting for ADV
    May 27, 2009
    164
    Suburb of Motown, Michigan
    I'd like to see more photos of this design. It appears that you're using some structure between the Yakima and Happy Trails.
    Functionally, it's the same as the XtraCycle LongLoader, which works amazingly well.
    The extra power of a motorcycle would overcome the biggest problems with using it on a bicycle.
    cycleTown650 likes this.
  17. fhfr436
    May 27, 2009
    164
  18. HighTechCoonass
    HighTechCoonass Living the Dream....
    Jan 18, 2005
    3,218
    land of the swamps!, Cajun Country LA
    A picture I took in Aspen on a 2013 Adventure ride.
    JSL, Te Hopo, Gedrog and 1 other person like this.
  19. Screaming Chicken
    Screaming Chicken Long timer
    Nov 29, 2007
    1,520
    Netherlands
    Didn’t know Ducati made hardtails? :lol3
  20. ben2go
    ben2go Long timer
    Jun 23, 2011
    7,522
    Gone
    I'm trying to figure it out too.
