Throttle Valve Set Point Exceeded
Discussion in 'GS Boxers' started by Coastal Beemer, Sep 20, 2017.
  1. Coastal Beemer
    Coastal Beemer Loven Adventuren Supporter
    Feb 4, 2012
    21
    Wilmington, NC
    Has anyone else had this issue with a 1200 GSA LC?? While sitting at idle, an engine symbol appears on the display and the idol speed picks up dramatically and the engine runs rough. I shut the bike down, start back up and all is normal while riding. When I stop for a minute or so at idle, the same thing occurs. My GS911 reports: "21FAA8: Level 2 monitoring of throttle valve 1, setpoint exceeded
    This fault occurred 4 times.
    The fault is not present now"
  2. LowOnFuel
    LowOnFuel In the crapper
    Oct 2, 2007
    1,724
    Pacific Northwest
    Sounds like Limp Mode. You might want to check out this thread if you haven't already:
    http://advrider.com/index.php?threads/16-gs-limp-mode.1241121/
    Good luck...
    Callisto224 likes this.
  3. taz_va
    taz_va Long timer
    Sep 1, 2015
    2,838
    Sunnyvale
    Something is causing the butterfly to get out of sync with the throttle, that does sound like limp mode territory. Yours could be either the valve itself, or a wiring issue.
  4. BluByU
    BluByU Long timer Supporter
    Feb 24, 2007
    1,082
    Lost in America
    Just for curiosity sake Coastal, how many miles on the bike?
  5. Coastal Beemer
    Feb 4, 2012
    21
    Wilmington, NC
    Almost 28,000 miles
  6. BluByU
    Feb 24, 2007
    1,082
    Lost in America
    Thanks Coastal
  7. FreshupFreddy
    FreshupFreddy n00b
    Mar 18, 2016
    1
    Navarre, FL
    I had this same fault code, 21FAA8. Occurred only at idle, and if I turned off the key and restarted, I could go on as normal. The short answer is that I found a vacuum hose, right behind the right cylinder throttle body had worked itself loose. See the lower center part of the photo below. Re-attaching this hose and adding a tie wrap immediately solved the problem for good! Thank God!
  8. Coastal Beemer
    Feb 4, 2012
    21
    Wilmington, NC
    Yep. I had the same issue and fix. However I trailered 150 miles to the dealer who diagnosed the hose issue in about 60 seconds. It sure pays to look things over really well even before pulling out the GS911.
    #8
    rdbonds and Callisto224 like this.
  9. rdbonds
    rdbonds Breaker of Things
    Sep 3, 2014
    231
    Dallas, GA
    I'm sure that was frustrating...but at least it's fixed!
    #9
  10. 10 bones
    10 bones n00b
    Jun 1, 2018
    2
    Mojave
    I had this same fault code, 21FAA8, found the vacuum hose off like they said. Thanks everyone for the information.
    #10
