Thumper Tires: All Around Western Desert / Mountain Tires 90%+ Dirt
Discussion in 'The Rockies – It's all downhill from here...' started by dieselcruiserhead, Oct 17, 2014.
  1. dieselcruiserhead
    dieselcruiserhead Long timer
    Jul 25, 2008
    1,678
    Park City, Utah
    Yay, another tire thread!
    I'd like to start a thread for guys in this area who ride everything from California and Nevada desert and mountains to as far east as Colorado front range - a very common type of terrain in most of the west, on enduro-style thumpers.
    This is 90% dirt and rock that eats tires quickly, and causes them to chunk easily other than fairly durable tires. Typically 450cc-550c thumpers.
    The point of this thead is to get enough data to build a chart of tire performance,
    according to everyone's input and feedback.
    Photos of the type of terrain we're talking about:
    Tire recommendations and experience vary widely and everyone has an opinion.
    However, at the end of the day I've found there are collective winners, so that's what I'd like to see if we can find.
    First, a couple general conclusions that I've made (please correct me/comment if you think I'm wrong):
    • After running a couple of the Desert specific tires, I've concluded they have really stiff sidewalls and lugs (such as the Bridgestone ED78, Maxxis Desert Cross IT, possibly the Dunlop 739) and many have been around for 15 years in the same design as far as I can tell often before extra heavy duty tubes were widely used.
      This said there is nothing wrong with desert tires and they have a use. My take is that both their stiff sidewalls and really hard rubber cause loss of traction. I think they are great for things like the 1000 mile races or a single super long trip that will eat a tire, but they are overkill on the heavy duty scale for most riding oriented, in favor of durability - thoughts / agree?? I personally am looking for 'desert tires' that still handle well without being too stiff or washing out.
      As a result, I'm personally moving closer to using hard-terrain motocross tires that seem to have a smarter lug design and won't last as long but are relatively cheap, smarter, and meet all of my needs other than they only seem to last about 500-800 miles depending on terrain, temps and location of where I'm riding, and how much slab is on that ride. Basically you get better performance in exchange for having to change tires more often. Luckily they're not super expensive ($60-85 a most on average). As I'm looking for a good tire, I'm looking be something that behaves like a hard motocross tire, but that lasts longer.
    • I've noticed a lot of Rocky Mountain riders are now adhering to the philosophy of motocross tires, but take it a step further with intermediate motocross tires, IE the MX51 Dunlop and the Birdgestone m404 in western terrain. I've seen a couple of posts online that in the Rockies, many rider's favorite tires are the 404 or the MX51. These are the same as their harder counterparts and they don't chunk, but they just last even less in exchange for better traction (in my humble opinion). Personally, the hard terrain motocross tires are great for me and have plenty of traction.
    • I personally keep my eye on my lines in favor of running low pressure. I run 14-15 lbs in the front, at most, and 12 in the rear regardless of what tires I use. Sometimes I run 12 in the front and 10 in the rear. I have almost no dings in 6000+ miles on my wheelset (with good head duty rims), and almost no flats, in years. I change out my tubes maybe every 2 years (way beyond the recommendation of changing every time) and generally run the michelin 4mm heavy tubes.
    • Also, after a long time of dicking around with different gauges, etc, I spent $25 on a ARB Large Dial Tire Gauge (designed for off roader who air down) from a local 4WD shop/buddy. The gaugeface is huge, about 3/4s the size of a dollar bill. I use it only on low pressure moto tires to make sure it stays accurate for years. This is how I know my exact pressures - no more guess work, and no more flats.
    • Tire size matters a lot too and a lot of people mess with this and aren't fully aware of some of the effects that can occur.
      Front tires basically come in two sizes, big, 80/100, and extra big 90/100. They are the same diameter and basic footprint, but the 90/100 have a wider profile in the curve except for the occasional front tire model that just comes extra narrow. Narrow fronts also seem to be DOT typically and more "dual sport" oriented, such as the michelin M-63 which is a very small tire in general.
      A heavy front tire is noticeable on thumpers that see a lot of whoops and need to be kept light. I notice it when I get on my bike with 90/100s, heavy duty tubes, and a HD wheelset when doing lots of whoops. This said I personally still choose 90/100 with the idea that they might do better in sand but recently went back to 80/100.
      Rear tires. KTM and many others OEM spec for rear is a 110/100 x 18 for enduro models, or really close to this size. I have messed with huge rear 120/100 tires like the ED78 Desert, and they are balloons and look cool, but can mess up your turning and balance. Jury is still out for me on these and big rear tires in general.
      KTMs (as I imagine many others) are sensitive to fork position and setup, despite everything on the internet about "later year KTMs that turn better." I find that over 80% of handling, for all years, is actually just correct setup and sag, and where your forks are set in your tripleclamps, with the last 20% being frame design. This includes RFS models. I have ridden many RFS bikes that outhandle tons of 2008+ bikes due to just being setup correctly. Especially having your fork angle and weight-to-fork height by having the suspension in the triples out a couple MM.
      By adding a big ass balloon tire to the rear or vise versa this can cause your suspension setting to be off so its important to pay attention to this in my opinion in all regards. Best way to setup your suspension is go ride some local single track with a few buddies, hopefully 1 or 2 who knows how to do suspension setup (clicks, rebound, etc) and then switch bikes to see what you like and what you don't, and where you bike excels and where it falls short.
      By controlling tire size and profile and can choose and control how the bike handles in different terrain from front-steer (later KTM, Jap bikes, and more motocross style) to rear steer (more older KTM style). There is nothing wrong with this - a lot of it is a matter of choice and simply being use to your bike, and then what terrain you are riding (rear steer is great for desert in my experience), but I like a combo of it all personally. So I think its important to make sure your bike is setup especially if you start experimenting with different tire sizes.
    • Different people have different priorities, for example for some people it's about getting 1500 miles or a wicked cheap tire. That would be great but I find tires that last 1500 miles or are super cheap generally sacrifice performance. Some people also run them bald while others change them out a lot, and then finally a tire's characteristics will change as they wear, and there are tremendous variations in terrain. In short, there are a lot of variables, and lots of opinions but it is helpful to hear them all..
    On to the tires...
    • Current Favorite Tire: Bridgestone m604. Intermediate / Hard Motorcross Tires that are 1-2 lbs lighter than most heavy desert tires, only get maybe 500 miles of hard riding or 600-800 with some slab and lower overall temps. If it is over 85 degrees on slab, they will roast very quickly. However, they stick like glue though especially in rough and rocky terrain. The rear tires have wide spacing which is intended for mud shedding, and in theory this might cause them to last shorter due to less rubber actual rubber in the center areas. The fronts have relatively tight spacing compared to many others and I love this - they really grab. Tires are made in Japan. As they wear their traction actually seems to get even better in rocky areas - there are no major issues with them on desert and rock terrain at even 25-30% in my experience, other than if its greasy or muddy.. They also comes in a 404 version, as mentioned above, which is the same tire with a softer compound for soft/intermediate motocross tracks and many people prefer the 404 for rocky terrain due to even better traction, and the 404s hold up to rocks, just wear quick. To note also, the Bridgestone m404 and m604 are being discontinued for the X30 and X40 new tires, as I understand it. I'll post about these below. The pricing hasn't come down on them though, yet. They are a solid $85+ for the rear tire right now, as best as I can find.
    • Another honorable mention very similar to the 604 is the MX71 Dunlop Geolander Tire. Nearly identical to the m604 but sized slightly differently so in a 18 it's slightly smaller, as I seem to recall. The wear profile for my particular sets of MX71s have been flatter in the middle, oddly for some reason, and this seems to be related to the tire profile. They seem to last lightly longer than the m604 with the additional rubber in the center and have an interesting offset lug design in the middle that definitely highlights it a modern, recently designed tire, and it handles great as well. I got about 600-800 miles out of my last one down to about 25-30% worn and traction remained excellent as they wore. They are made in Thailand I believe, but are still a great tire by a very reputable brand. They also come in the MX51 for intermediate / soft motocross tracks as well, and KTM is stocking this tire on many of their bikes new as a performance tire (their choice of a MX51 for the spec'd tire is a marketing point). The MX51 do not hold up to rocks though, they chunk badly.
    • The front tires between the MX71 and 604/404 are nearly identical in design by volume. I found no major issues with either tire though the 604 seems to grab a little better as noted above and just like the rear, the MX71 will outlast a 604. I found that slab wears the side knobs really quickly on both tires. I'll take and post a photo about this when I get home.
    • The ED78 Bridgestone Gritty. This is a massive, super heavy duty tire that only comes in 120/100 x 18 and is designed for desert racing, It weighs about 14 lbs so it's actually still about a 1/2. lb lighter than than the Dunlop 739, but still super meaty and super heavy duty and it the most heavy duty and durable of the any of the tires offered by any large manufacturers (Michelin, Dunlop, Birdgestone, etc) though the Maxxis Desert IT might give it a run for its money.
      I've been through two of these but stopped using them because they are super stiff and when they get below 50%, in my experience they slide all over the place and the traction isn't great. But they sure do last. I expect to get 1000-1500 miles out of these no problem when using them including plenty of slab at all templs. Because they are also big, high volume, they can create some of the handling issues as I discussed above. They were designed about 15 years ago+ so they are a dated design. They also went way up in price maybe 6+ months ago - they used to be about $85 and were a great HD option but now they are closer to $130 or so. Oddly basically Bridgestone is considering them a performance tire now I suppose. Maybe because they last so long. I personally think they'd be a great tire to try on something like a 690e or 950 SE to see how long they last and how well they handle in this app. They are a large 120 but are not a 130 or 140 necessarily.
    • The famous old d606 Dunlop DOT dual sport tire. This is basically a good combo of hard that also happens to be DOT that seems to stick reasonably well in my experience and have some profile attributes that make it decent for on road. I am actually a fan of these surprisingly even though they've also been around for eons, and I think they are a great tire for what they are. They don't last as long as the desert non DOT tires. On an 800 mile trip I did maybe 3 or 4 years ago through gobs of both slab and tons of really technical terrain, I ran the 606 which were basically roasted by the end, whereas the guys on Maxxis IT had at least 1/2 treat left. The 606 are sort of good at everything but don't particularly shine at anything necessarily either. They don't chunk too bad in my experience. Some people are getting much more (1500 miles) out of them.
    • Maxxis Cross IT Desert - basically the same as the ED78 but different profile with slightly narrower lugs. About $75-85 for them so they're priced where ED78s were before so they are pretty cost effective super heavy duty heavy desert tire. Similar characteristics as other desert tires - they wear a long time andare super beefy, heavy, stiff, and the handling/traction is only so-so.
    Any thoughts / comments / tires to add??? Please post up....
  2. dieselcruiserhead
    Jul 25, 2008
    1,678
    Park City, Utah
    A couple more:
    the Dunlop 739 Desert. Seems to be similar to the other desert tires in that they are heavy (about 14.5 lbs - heaviest of any one the desert tires I weighed). The traction is supposed the best of the desert tires - psyched to try one out. I hear traction is actually decent with these and they wear quickly for desert tires. I do have a used one I scored downstairs and its solid as a rock..
    And then Bridgestone will be eliminating the 404 and 604 in favor of the X30 and X40 respectively. Here are photos. These look pretty sweet too but no idea how they'll handle. Not sure if all the "technology" is hype or if they're really actually pretty cool..
  3. flyingwombat
    flyingwombat frozen dead guy
    May 18, 2009
    890
    Nederland, CO
    Oh boy, it must be winter already. I love a good tire thread. :D
    The Michelin AC-10's are DOT and are pretty good performers in the rocks, hardpack, and sand. They aren't great in any one of those areas but can do it all and work well on pavement also. Wear life is under 1000 miles in my experience.
    For heavier bikes, the Michelin Desert front is amazingly durable and has the same basic tread pattern as the AC-10 front. Run it with lightweight tubes.
  4. dieselcruiserhead
    Jul 25, 2008
    1,678
    Park City, Utah
    Cool..
    I edited the original post quite a bit to get a little more info in there and it a little more organized....
    Hope it helps
  5. FatChance
    FatChance Road Captain
    Jun 12, 2003
    13,765
    Oak Creek, AZ
    That was a lot of words.
    MT21 front D606 rear.
    ryanco likes this.
  6. Slickhorn
    Slickhorn Professional Dirt Bag
    Jun 6, 2008
    107
    South of Heaven, UT
    HairLipDog likes this.
  7. COXR650L
    COXR650L Long timer
    Nov 29, 2009
    2,219
    Denver
    Very well thought out post:lol3. Must be snowing in Utah!
    Rears I have two favorites:
    -M404 is amazing but wears fairly fast. Not bad mind you, but 4 good desert rides is all I can get out of it. Mtn single track without all the rocks it does much better. Hooks up real nice and gives great corner feedback.
    -MX 71 is a great budget tire. Hooks up good enough, is predictable but lasts a long time, at least 1-2 times longer than the 404. It has become my go to tire.
    For fronts I bounce around, but have used the Volcenduro VE39 (i think.... the harder compound one) over and over in between others stuff. Good tire that lasts.
    I run 15 front and 12 rear with ultra duty tubes name brand tubes. A few flats but really very seldom.
  8. DavisWelding
    DavisWelding Banned
    Feb 12, 2014
    845
    Mexico, Colorado
    Michelin Desert front is very good all around but wears very fast on pavement(duh)
    Michelin Desert rear is consistent; it always sucks but it always sucks the same amount!
    I loved the MT16 rear for all 200 miles that it lasted:lol3
    The TrakMaster rear on my XRR has been ok but it seems to be different every time you ride it. Pressure is always the same 15psi but goes from "planted" to "I swear it's flat"
    I've had good luck with 908rr rear but at $200 they are not that good.
    The Tractionator Desert H/T will probably be my next rear to try out. Seems to have good reviews for performance and durability.
    I forgot to add that all these tires I have tried were in the 120/100-18 rear size and 90/90-21(Desert) front
    #8
  9. KDouble
    KDouble AKA BeefCurtain
    Jul 13, 2009
    408
    Colorado, Montana
    Nice I love talking tires. Been running a MEFO Stone Master 140/80/18 (Not the Explorer) on the rear. I love it its expensive with a HARD rubber compound long life like most MEFO's, but a really aggressive tread pattern. Taken it to Utah, Montana, New Mexico, live and ride Colorado. Point is it does it all well. I picked up 2 nails in the Stone Master riding the Kokopelli this year neither one made it to my tube. I carry them both now as good luck charms. Lot of guys running the Pirelli MT43 (rear) & loving it. I've yet to try it still an old school knobie guy. Think the Michelin Desert it the best front tire that exist. Mine still looks new after 1000 miles of Dual Sport mayhem.
    #9
  10. Oldwin1
    Oldwin1 Long timer
    Sep 18, 2006
    2,136
    Front Range
    I ride my bike to the trail so there is no way I do 90/10 because it is 20 miles of road each way, to go for a 150 mile ride. Everything around here is rocks so I run the Shinko 244s. They perform better in the loose rocks, :lol3 than the Dunlops, Michelin, Bridgstones etc. I have tried. I get between 1500 and 3000 miles out of them depending on whether I remember to air back up for the street. I ride a DR650 so I only go down to 20 PSI or the combination of Rocks and heavy motorcycle causes rim pinches.
    I use them on my rental DRs as well and my customers always have positive feedback about them. My customers who come in to ride the TAT to the west coast have always had high praise for there ability to do anything. They are smooth and reasonably quiet on the highway. I have yet to have one let loose on pavement and I push them hard.
    Ron
    #10
    Carlfixit likes this.
  11. OldenSlow
    OldenSlow Been here awhile
    Oct 29, 2013
    608
    SE Wyoming
    70/30 bike (stock 98 DR350) I'm loving my first MT21 up front. Very confidence-inspiring on and off pavement. Didn't like/trust the D606 front, D606 rear was okay, both wore like iron.
    Trakmaster rear currently, frankly not impressed with performance or durability (wears pretty fast/uneven and chunking). Seemed like the first 100 miles of pavement took them down 1/3. For the price I REALLY wanted to like it, but just didn't do it for me.
    Trying a K270 rear next, liked the one I had on an XR650L
    90/10 bike (WR200 2T): IRC Volcanduro mixed set (33 front, 39 or 35 rear IIRC) has been a great and durable (no chunking) in everything from rocks to mud; I have only ridden a little sand but they did well. I have at least 20 hours on them and they show very little wear.
    #11
  12. Rogue_Ryder
    Rogue_Ryder
    Dec 8, 2005
    8,475
    Pinewood Springs, Colorado
    I took FlyingWombat's suggestion and went with the Mich Dez Race on my XR600 and am happy with it so far.
    I've run all kinds of DOT tires over the last 10 years, for years I ran the Pirelli MT83/FIM Scorpion Pro as a front tire most of the time, it worked well but it wore quick (for me) and it's kinda expensive (cheap compared to the Mich Dez though).
    Last year I decided to go with a Kenda Washougal front (DOT Approved). The tire has been AWESOME not only does it hook up well it is wearing really well. It's been on the bike since last August and it still is usable the knobs are just starting to round off at this point the Scorpion pro would be missing knobs and the diagonal knobs would be at a knife edge.
    Another tire that has really surprised me is the ultra cheap Kenda Trackmaster. Again for the lighter bikes. It's DOT approved and I've now run this tire on a DRZ400S, CRF230F and my RM250. The tread is IDENTICAL to the old Dunlop 952 (the tire I removed from my RM). I get good traction and predictable slide from the tire. I didn't like the tire aired up on the tarmac when it was on the DRZ but I've done limited tramac on the RM at dirt pressure without a problem. I also have run the Trackmaster since last August and just flipped it around.
    #12
  13. Bobmentum
    Bobmentum RMTA
    May 9, 2010
    800
    Chipita Park, CO
    Love this for rear tire and good price.... HATE the front. No wait, hate is not a strong enough word.
    But, my opinion may not be valuable since I am of the MT43 ilk and have taken the vow of abstinence from rear knobbies on trail riding.
    #13
  14. jjustj
    jjustj Long timer
    Jun 14, 2005
    7,353
    Back in Colorado. Cedaredge or delta or.....
    mt 43 rear on both 450exc, crf250l. great in sand, and rocks trails etc. bad in mud!Buddy of mine has been in expert class in over 20 years rocky mountain trials association uses one on his xr 650 2 up with wife on back. cisneros trail, rainbow trail. uses the mt 43. We are not ROOSTAFARIANS. :) always open to try new things ( within reason):freaky
    #14
  15. shrederscott
    shrederscott Long timer
    Mar 19, 2014
    2,815
    denver
    Hey
    I ride a ktm 530 with tubless system, run 30 psi slab 12-14 psi dirt.
    This season I switched from the 5.10 shinko 244, DOT rear that I had been very happy with, everywhere other than deep sand and mud, to the Motozs tires
    I ran the both desert and the x-cross in the 130 size.
    Wow are they big ! ! They hook up great. Last way long 1,600 -2,000 miles, never had any other rear last anywhere close to these tires.
    They are a little loud on the slab
    They canyon cave the slab
    They were excellent on a 2 recent Moab trips
    Just mounted the 110 desert, much better size, have yet 2 ride it, but have high expectations.
    I ride pavement, tech 2 track, and single tract with these tires.
    Hope that helps
    scott
    #15
  16. dieselcruiserhead
    Jul 25, 2008
    1,678
    Park City, Utah
    #16
  17. dieselcruiserhead
    Jul 25, 2008
    1,678
    Park City, Utah
    I'd really like to build a chart out of this thread, if possible. Get right to the data...
    Rode with some guys with MX51s this weekend. Basically I think they are ruled out cause.... (see photos below).
    MX51s in the desert:
    Standard 530, not thottle heavy at all...
    Front
    Rear...
    Basically chunking on the side nobs both front and rear. Anyone not had this experience with a 450+ thumper and MX51s??
    #17
  18. DavisWelding
    DavisWelding Banned
    Feb 12, 2014
    845
    Mexico, Colorado
    This is the MT16 that lasted me a whooping 200 mile +/-. These pictures are after a quick 75-mile loop in northern Arizona. I had installed that tire the night before and had to flip it around the next night. It did not last through the next day. I also had two flats that day! You can see the marks on the mud guard where the knobs had been flying off!!
    After turning it around
    #18
  19. jimmex
    jimmex Guero con moto Supporter
    Jan 23, 2003
    4,429
    West Texas/Rico
    +1 Save the trails with a trials tire.
    #19
  20. dieselcruiserhead
    Jul 25, 2008
    1,678
    Park City, Utah
    Whoa.. That is some mean looking super deep tread too....
    #20
