Tie down points on an Aluminum trailer
Discussion in 'The Garage' started by rob, Jul 20, 2019.
  1. rob
    rob Been here awhile Supporter
    Jun 24, 2002
    297
    Arma, KS, USA
    I have an all aluminum trailer and have started to adapt it to carry my large bikes, BMW RT's (2) or one RT with a F800GS ADV or a Ural side car unit. I know I shouldn't use steel with the Al, but what would be the proper method to secure the E channel or tie down hooks?
    Thanks in advance.
    Rob in Kansas
  2. Beezer
    Beezer Long timer Supporter
    Oct 26, 2004
    9,939
    Anchorage, formerly Spenard (hub of the universe)
    it'll be fine
  3. Yinzer Moto
    Yinzer Moto Sloppy 300 rider Supporter
    Jun 13, 2008
    38,722
    Pittsburgh PA
    Check the bolts that are holding your axle on or the coupler up front. They are steel.
    E track or L track are good choices.
  4. cagiva549
    cagiva549 whats a cagiva
    Oct 10, 2004
    7,109
    Cypress Tx
    Three strips of Etrak on the floor of my trailer one in the middle and one on each side , bolted thru the floor into the frame cross braces . harbor freight bike shoes off set so no banging handle bars with holes drilled thru the floor . Just drop a couple bolts thru a set of holes to hold the shoe in place while loading . I had tire straps made to tie the tires to the floor with ratchet straps like a car hauler , thousands of miles with my bikes inside my trailer and no problums .
  5. AwDang
    AwDang Enabler
    Sep 1, 2014
    3,257
    MABDR mile post 0
  6. showkey
    showkey Long timer
    Jun 25, 2007
    2,438
    Wausau
    7B8AE61F-9041-4F4B-B1E0-8AD1AC701105.png Stainless “EYE” bolts.................more the better.
  7. PunkinHead
    PunkinHead Moobless Adventurer Supporter
    Dec 10, 2005
    10,434
    Land of Walmart Shoppers
    I just did this a couple weeks ago. 10' strips of E-Track (cheap from a trucking supplier) through bolted with 1/4-20 bolts and nylocks. I used 1/4" thick strips of aluminum on the bottom side that spanned each set of holes to help distribute the load. The way my deck was fabricated I couldn't bolt directly through frame members. I bought a big stack of precut 1/4"x1.5"x6" aluminum stock off eBay and drilled two holes in them. They were dirt cheap because they're sold as drops from a machine shop. I couldn't have bought raw 6061 and.cut them myself for what I paid.
    katbeanz likes this.
  8. Strong Bad
    Strong Bad Former World's Foremost Authority Supporter
    Oct 29, 2007
    11,602
    Omicron Persei 8
    I have no idea what's up with that image, I couldn't see it, so I went to open it in a new tab and all of my Norton etc. went into full red alert!
    #8
  9. k-moe
    k-moe Long timer
    Jun 27, 2012
    6,790
    44º W
    You're probably thinking of the troubles that come from using stainless steel fasteners in aluminum in a marine environemnt. Not a worry at all to use regular steel, or stainless with a threadlocking compound to stave-off electrolysis.
    #9
    ohgood likes this.
  10. VX Rider
    VX Rider Long timer
    Dec 11, 2015
    6,065
    Phoenix
    OR, one could isolate the bolts with aluminium sleeves and washers....if you're really into isolating the two metals from each other
    #10
  11. BillMoore
    BillMoore Long timer Supporter
    Oct 21, 2011
    1,311
    Snohomish, WA
    I have an aluminum trailer, and have bolted down l- track, some eye hooks, etc with stainless hardware. Trailer is now 9 years old, no issues.
    #11
  12. dhally
    dhally Hammerhead Supporter
    Feb 18, 2006
    6,053
    Kennewick, WA
    My trailer has an aluminum deck. I installed Rivnuts then bolted down L track.
    #12
  13. Racerrrx
    Racerrrx Long timer
    Feb 23, 2012
    1,366
    Columbus,OH
    HELL NO... unless you like busting your ass tripping over shit.
    #13
  14. Racerrrx
    Racerrrx Long timer
    Feb 23, 2012
    1,366
    Columbus,OH
    #14
  15. showkey
    showkey Long timer
    Jun 25, 2007
    2,438
    Wausau
    You put the eyelets in the rails not the floor...........
    #15
  16. Racerrrx
    Racerrrx Long timer
    Feb 23, 2012
    1,366
    Columbus,OH
    So, less pain but you have tiedowns running all over the place.
    #16
  17. NC Rick
    NC Rick Cogent Dynamics Inc
    Aug 31, 2007
    8,634
    Asheville, NC
    I really like my aluminum trailer. It bothers me to put steel stuff in it or to over clutter it with weight. 6x12 enclosed, full height, fully kitted with spare and tie down hardware is 1120# no bikes.
    I likely worry too much but everything is backed with aluminum plate or “C” channel and either welded or bolted to the frame members. I ordered the trailer with 16” centers in place of the standard 24” centers for floors, walls and roof. I found aluminum “E” track and used the airline type stuff in the center. Pit-bull restraints are steel unfortunately. This setup is very adaptable for 1 to 3 bikes. We load track bikes, dirt bikes and dual-sport bikes. If bikes are over 400lbs (none of our above bikes are) we only load 2 max.
    2393FA9D-06E9-42AC-9CA8-AB8E1F9A85DE.jpeg FD008FA5-6C95-4225-9AB4-DB4AF2AF21C6.jpeg
    #17
    wee-twin likes this.
  18. yokesman
    yokesman Long timer
    Sep 12, 2008
    2,713
    SW. Idaho
    bolt the front wheel mount etc to 3/4 ply thru tee nuts. cut ply to fit your trailer. with the bikes on the ply anything short of a rollover your bikes are not moving. add some forged eye bolts from lowes etc to tie down the rear. moved 2 bikes 1000miles, the straps were tight when I got there.. 2 straps per bike, 2 ea front n rear , 2 at the side to keep the vertical plain . 800-1000 lbs of bike on ply is not moving arround if fitted to the floor. we used 2x6 to fit the truck box and screwed them to the ply. forward and side fitted ply also is used on my pickup when hauling our bike. You then still have you trailer for other uses if need be.
    #18
  19. Zuber
    Zuber Zoob Supporter
    Sep 28, 2004
    6,914
    West of the West, Oregon
    Not a fan of those Pit-Bull and other things that hold the bike up by the wheels. That's a lot of stress through the wheel bearings that they aren't designed for and wouldn't normally see. Also, too fiddly to install and use. I'm hauling many different bikes, so there's that too.
    Just a wheel chock and four tie downs on each bike. Haven't lost one since 1971.
    #19
  20. PunkinHead
    Dec 10, 2005
    10,434
    Exactly what forces are put on the wheel bearings that they don't see when supporting the bike while riding?
    #20
    NC Rick and Strong Bad like this.
