Tiger 800 Tuning Thread
Discussion in 'Triumph Tigers' started by theycallmeebryan, Mar 31, 2015.
  1. bikeorfishwhattodo
    bikeorfishwhattodo n00b
    Apr 4, 2018
    5
    Bothell, Wa
    Moderator please delete if this is not OK.
    If anyone is interested in a gen 2 Dyno tuned Power Commander(used), Quickshift(used), and an O2 sensor eliminator kit(new, never installed) please PM me for details. They were on a 2015 that that was rear ended 2-3 weeks post install. I purchased them for my 2013 and ended up not needing them to tune on Dyno.
  2. Thundinator
    Thundinator Adventurer
    May 2, 2018
    19
    Spain
    Hi all,
    Here a 2016xcx owner, have been reading all the posts however not clear in my situation what should do.
    Currently have an SC Project Adventure, with no Db-killers, O2 sensor eliminator and de-cat. Use the bike a lot for off road
    Have arrow map on it (don't know if the current Triumph arrow map is different than the, TUNE ECU one.
    As you know, is not compatible with TUNE ECU my model...
    Should I be going with stock map then? I want to have the power on the low mid range, and reading through the posts seems arrow map gives the torque at the high end RPM range... Which is something I don't want... I can feel the bike pulling like crazy when going over 8000rpm...seems it would go up even more.
    However the arrow maps injects more fuel and I don't know if it's something I should keep because of my current setup with more exhaust air flow...
    Any help would be appreciated, many thanks in advance.
    twowings likes this.
  3. DumDum09
    DumDum09 n00b
    Nov 9, 2017
    3
    NJ
    Hi Did you ever run those two tunes and compare? I have a 2011 Roadie ABS with Arrow, about to put on the 21064 tune, which the TUNE ECU program says is the most updated one. Are there any custom tunes that are recommended instead of the 21064 tune? Better question, are there even any other better options or is that the best so far?
  4. HarryJames
    HarryJames n00b
    Jul 16, 2016
    7
    I never did anymore with modifying the maps. I run the stock arrow map and I’m very happy with it.
  5. DumDum09
    DumDum09 n00b
    Nov 9, 2017
    3
    NJ
    Thanks for the response. I'll try the 21064 and hope for the best.
  6. DumDum09
    DumDum09 n00b
    Nov 9, 2017
    3
    NJ
    So I plugged in the 21064 and am very happy with it. Admittedly, I customized the Air/Fuel mapping to make it a little more efficient, as some smart people have mentioned that 14.70 is the most efficient burn, I bumped up the cruising portion of the throttle/rev range to match that. In addition I dropped my Fan Temp to come on at an even 100*C.
    Otherwise, the 21064 really smoothed out the power delivery on the 2011 Tiger Roadie ABS with Arrow. Seem to be getting a little better mpg too. It is very important that you reset the adaptations after you load the tune successfully, and then turn off the bike, turn it back on and do that 12 minute tune on top of that. (Turn it on, start it, dont touch the throttle, run til fan comes on, run 12 more minutes, then turn it off).. Oh and then go for a ride!
    The only issue is that my fuel gauge is still wonky. Sometimes it reads fuel level, sometimes it doesnt. Hoping that irons itself out.
    666 likes this.
  7. Michelangelo
    Michelangelo 2 wheel rider...anytime..
    May 23, 2005
    1,908
    Rocky Mountain West
    Which cable do I need to use Tuneboy ECU here in the USA?
    I
    JUST PICKED UP A 2012 TIGER 800 XC. It is idling erratically around 2,000 RPM. And the check engine light is on. This is how I purchased the bike.
    I downloaded Tuneboy ECU app and want to make sure I get the correct high quality cable so I can access it through my Android. Does someone have a link to what they are using? I prefer not to use the Bluetooth connector.
  8. Norty01
    Norty01 RIDERCOACH (RETIRED!)
    Jan 30, 2014
    2,186
    CARLSBAD, CA, USA
    Sounds like an intake air leak.
    XYooper906 likes this.
  9. 666
    666 Agnostic and Orange
    Feb 23, 2005
    1,451
    San Francisco, CA
    Same setup, 2014 roadie abs with arrow but with KN airfilter and snorkel prefilter. I am running 20767. It is great power ans mpgs much better than stock .
    For fuel level dealer did some reflashing and it worked great ever since(not sure what, it was 3 years ago)
  10. Jorgezgza
    Jorgezgza n00b
    Jul 31, 2018
    1
    Zaragoza
    For whom this may come in handy.
    I am using the original triumph AFR map, from a 2018 Tiger xcx , this I have taken from the tuneecu maps, and I have passed it to the power commander.
    I have equipped, Arrow, De-cat, BMC filter.
    The next thing I'm going to do is modify the air filter with an "INTAKE TRUMPET" of a Speed Triple, reference triumph T2201244.
  11. OldCheetah
    OldCheetah n00b
    May 6, 2019
    1
    India
    Hi all, a quick one on maps, I have 2016 Tiger XCX with Arrow exhaust and map, now I am planning to install Power Commander V with Auto tune module and quick shifter, do I need to put the stock map back on stock ECU or I can override the same once I plug the Power Commander.
    Thanks in advance.
  12. KildareMan
    KildareMan Long timer
    Oct 5, 2006
    1,132
    County Kildare, Ireland
    It'll make no difference as the pc will change whatever's there on the bike anyway (my understanding). Personally think the quick shifter is a waste. I shift clutchless up and down without one.
    OldCheetah likes this.
  13. Timps27
    Timps27 Adventurer Supporter
    Apr 17, 2019
    88
    Missouri
    Quick question, I have dealertool and their OBD2 usb cable. The dealertool connected to the ECU no problem but after pulling initial data I had to send it in for a key reg. I tried connecting to the ecu using tune ecu and although it picked up the right com and the OBD2 connector was sporadically flashing indicating data transfer it said it cound't connect to the ecu. Anyone been able to hook tune ecu to their ecu using the dealertool cable?
  14. KildareMan
    Oct 5, 2006
    1,132
    The dealer tool is not compatible with tuneecu.
  15. Timps27
    Apr 17, 2019
    88
    Missouri
  16. KildareMan
    Oct 5, 2006
    1,132
    It's too do with the dealertool cable having differing hardware.
  17. mylastbike
    mylastbike Been here awhile
    Feb 28, 2014
    901
    Savannah, GA
    I have a 2012 Roadie ABS and I'm about to install the Arrow pipe. Should I stick with the stock tune or have the dealer install the Arrow tune? I doubt if my bike has ever had its tune updated since it rolled out of the factory.
  18. KildareMan
    Oct 5, 2006
    1,132
    I'd go with the arrow tune. Even the latest standard tune will be a major improvement over an older one.
  19. JohnBoyNC
    JohnBoyNC Been here awhile
    Sep 29, 2019
    113
    Indian Trail, NC
    EXACT same issue as you....same year and everything. I bought a used Arrow in the Flea Market from here and just got it in the mail today.
    Consensus/opinions on dealer Arrow tune vs. custom Arrow tune on this thread vs. custom hybrid tune on here.
    What should I expect with the Arrow and no tune? Just some pings and pops on decel? Ok to run the Arrow for a bit til I can get the tune installed? Can u tell I'm anxious to get it installed?
  20. mylastbike
    Feb 28, 2014
    901
    Savannah, GA
    How do I know that the dealer will install the latest Arrow tune and not an old one?
