Tiger Tales - Dialling in the 800XC for the dirt
Discussion in 'Triumph Tigers' started by Burren Rider, Jul 6, 2011.
  1. akaDigger
    akaDigger Amateur Adventurer
    Feb 10, 2013
    1,562
    Evansville, Indiana
    I just used a 426 Channellock pliers to unscrew them. They came right out.
    Raconnol likes this.
  2. Raconnol
    Raconnol Long timer
    Feb 23, 2012
    1,152
    Victoria, BC
  3. zodillyicous
    zodillyicous Been here awhile
    Jan 30, 2014
    167
    Seattle
    Well that was my problem. Read the triumph manual and it said to drill the heads off the security bolts to remove. That left the soft bolts to grab on to. Not sure why but it took way too long to get out.
  4. Slowpup
    Slowpup Been here awhile
    Nov 7, 2013
    181
    Capertee Valley, 'straya
    The second time we fitted an MSC damper I used a Dremel to cut a screwdriver groove in the head of the stub and saved about 5 minutes of swearing and cursing.
    The Haymaker likes this.
  5. bluestar
    bluestar sheep shagger
    Mar 14, 2014
    26,945
    sheep pen
    :happay:happay:ricky
    Black Rhino likes this.
  6. markbvt
    markbvt Long timer
    Sep 26, 2007
    4,040
    Georgia, Vermont (that's one town, not two states)
    Okay, I'm really late chiming in on this because I've been too damn busy the past few months to check in here, but better late than never.
    For what it's worth, I've got 95,000 miles on the stock clutch on my Tiger. It still works fine, but I'm nearly out of cable adjustment, so I'll be replacing it this winter.
    If you've got plenty of adjustment left in your clutch cable and the clutch isn't slipping, then don't worry about it.
    --mark
    XYooper906 and akaDigger like this.
  7. Raconnol
    Raconnol Long timer
    Feb 23, 2012
    1,152
    Victoria, BC
    For the owners of the GPR V4 stabilizer, did you find them too slow out of the box and if so did you change out the oil for a lighter weight?
    The reason I am asking is a found one used on Ebay with the following comments.
    "They are too heavily dampened out of the box for some reason. Even on the 0 setting it would dampen the steering and at very slow speed situations you don't want that. I called gpr and happened to talk to a tech at gpr who had my exact bike and he agreed and told me how to purge lighter oil through it. 2.5 or 5wt. I don't remember.
    Anywho I did that and it's almost completely free at the 0 setting and I still have never had to turn it past 10 in the most extreme off-road situations."
  8. bluestar
    Mar 14, 2014
    26,945
    sheep pen
    With mine on 0, you can tell it's there. It does tighten it up a little but does not feel excessive to me. I've actually been running mine on pavement with it set on 5 and like the way it feels.
  9. Raconnol
    Raconnol Long timer
    Feb 23, 2012
    1,152
    Victoria, BC
    Cool, thanks for the reply.
    I have been trying to justify the cost for the rocky logging roads and river crossings that I see throughout the year.
    Rick
  10. Lushtrucker
    Lushtrucker Been here awhile
    Nov 3, 2014
    705
    Knoxville
    Not sure what kind of pricing you're finding on the gpr, but this one was around $475 US shipped.
    http://www.mscmoto.com/triumph-tiger-800-xc-12-15
    akaDigger and Raconnol like this.
  11. Mr_Chris
    Mr_Chris Get away, evil car!
    Aug 29, 2011
    300
    Melbourne, Australia
    G'day Mark,
    All the best for the remainder of Silly Season!
    I've had better results since (but not that much yet), though I pre-emptively replaced the stock clutch during the 10k service, when the
    motor gets opened up anyway.
    My problem was, I think, not adjusting the clutch often enough, so now I
    ask the mechanic to check & assist most times it's in for a service, before
    I feel it slipping.
    Good to hear from you!
    Chris
  12. XYooper906
    XYooper906 Been here awhile
    Mar 7, 2013
    165
    Fayetteville, GA USA
    I'm confused as to why the clutch cover would get removed during a 10Km service?
  13. Mr_Chris
    Aug 29, 2011
    300
    Well, let's just say it does when you replace the clutch at the same time. :-)
    It's not normally a clutch cover, but the valve covers maybe? 10k is an oil change and I think a check on the top end for clearances? In any case, as I had The first 800XCx of them all (at least in Oz but at the time, 29 Dec, nobody else was on here with one yet either, so that's everyone right? Lol), there was a missed adjustment and I was having a rough idle issue that was related to valve clearances or something that was different from XC to XCx, so with the bike up on the rack it was the cost of a seal and a half hour of labour, with my Barnett clutch provided. Saved the extra oil change and initial shop time.
    kingofZroad and XYooper906 like this.
  14. Drunk_Uncle
    Drunk_Uncle Long timer
    Dec 26, 2009
    3,613
    Boerne, TX
    I am using the Scott's Performance steering damper and love it. Really helps in the sand. I like the mount most because I was able to use my current risers with it. A shame Rally Raid stopped production of Tiger stuff.
  15. XRman
    XRman Long timer
    Dec 9, 2006
    8,171
    SW Victoria Oz
    Just wondering; is there a history of broken gear fork selectors in the Tiger800?
  16. Black Rhino
    Black Rhino Closer to Dairy Queen than Steve McQueen.
    Dec 7, 2012
    5,696
    West of Atlanta , Ga.
  17. XRman
    XRman Long timer
    Dec 9, 2006
    8,171
    SW Victoria Oz
    Thanks BR
  18. Black Rhino
    Dec 7, 2012
    5,696
    Stolen from another inmate (Jblk9695). Example , with homegrown repair:
  19. XRman
    XRman Long timer
    Dec 9, 2006
    8,171
    SW Victoria Oz
    Thanks for the research BR.
    OK so this pin breaks after falling on the gear shift lever, or is it from hammering through the gears without using the clutch, or what else? Does it happen often? Was there a recall for this on earlier models?
  20. Black Rhino
    Dec 7, 2012
    5,696
    It happens infrequently , but I've seen 1/2 dozen or so references to it here from reading through older post. Not sure of circumstances surrounding the breaks or any recalls. Others may chime in. Good news is it's a relatively easy repair for the mechanically inclined. But yours should still be under warranty , right?
