Tightening R1200GS spokes
Discussion in 'GS Boxers' started by luv2lean, Dec 26, 2007.
  1. luv2lean
    luv2lean not lost til out of gas
    Feb 7, 2003
    1,073
    East of Sacramento
    I understand "trueing" the GS wheels should be left to a pro, but the regular maintenance schedule calls for tightening loose spokes and dont believe bmw techs send these wheels to woody or the like for regular maintenance. I have a few dead tone spokes on my 1200GS and want to snug them up, but am having some difficulty with loosening the set screws inside the spoke. They appear to fit best with a 2 mm allen, but that is a little loose and i am concerned about stripping the allen head. Does any body have some experience or secrets i should know about how to get the set screws loose?
  2. Anorak
    Anorak Woolf Barnato Supporter
    Jul 23, 2004
    55,453
    San Rafael, Marin County
    I think that little buddy is 2.5mm.
  3. luv2lean
    Feb 7, 2003
    1,073
    East of Sacramento
    i cant get a 2.5 in there
  4. Anorak
    Jul 23, 2004
    55,453
    Well, I got motivated to go into the garage and check on an 1150 wheel I have. It is 2mm. I looked up the part #07119904003 and it is the same for all wheels back to the R100GS. Use a straight type allen wrench not ball end.
  5. JimVonBaden
    Feb 11, 2005
    91,757
    Alexandria, VA
    2mm works, but remember that the allen is just a set screw, and NOT the adjuster. Many people don't touch the allen, or do not know about it.
    The torque is only 3nm, so barely snug.
    The technique is to use a wrench on the spoke nut and tighten it in very tiny increments until you get the twang back, then tighten the set screw.
    DO NOT OVER TIGHTEN THE SPOKE! If you do, wobbles will visit you!:deal :D
    Jim :brow
  6. rdcyclist
    rdcyclist Long timer
    Sep 28, 2004
    1,248
    SanHo, NorCal
    The grub screws are 2mm. Make sure you're using a good quality wrench (I like Bondhus) and the heads and threads are clean. Liquid wrench is your friend. If any of the grubs don't loosen, you can just break the spoke nipple loose and replace it with a new grub and nipple.
  7. luv2lean
    Feb 7, 2003
    1,073
    East of Sacramento
    really appreciate the comments.
    thanks much
  8. michnus
    michnus Lucky bastard Supporter
    Apr 14, 2005
    2,353
    South Africa
    Jim the new Hayens manuel I got for Christmas note the torque as 6nm. :deal
    My 1200 rear got a small amount of run out, problem is in the entire South Africa there's not ONE person that can help in straightening it out, and BMW SA say it's better to replace wheels. I tied all the spokes to 6nm but the run out is still there, it's not a problem when riding, maybe it's best just to leave it?
    #8
  9. JimVonBaden
    Feb 11, 2005
    91,757
    Alexandria, VA
    The 2mm grub screw is 6nm?:huh
    I'll check my BMW manual, but that would be similar to the lock nut on the valves, or the valve cover BOLT. I'm thinking that isn't right. I never trust the aftermarket manuals for torque values.:deal
    Oh, and tightening the spokes evenly by torque is a good way to mess up the true of the wheel.
    Jim :brow
    #9
  10. michnus
    Apr 14, 2005
    2,353
    South Africa
    Just had a look again to make sure, sorry I had the cat by the balls, they Hayens list it on page 1.2 as 4nm. :augie
    Jim
    So help me out how am I suppose to do it? :D
    #10
  11. rideLD
    rideLD The further the better!
    Jul 15, 2004
    5,412
    Omaha, Nebraska
    I think the schedule calls for checking the spokes and only tightening if necessary. I check mine by tapping them with a wrench and listening for the tone. If the tone is high pitch they are too tight, if the tone is flat they are too loose. A nice mid tone is perfect. I have personally never had to tighten one spoke on either GS that I have owned. I once asked a BMW tech about it and he said about 1 out of 20 bikes ever needs to have a couple of spokes tightened and those are usually bikes with a slight hop or bend in the wheel from abuse.
    #11
  12. JimVonBaden
    Feb 11, 2005
    91,757
    Alexandria, VA
    According to Woody, of Woodies Wheel Works, THE man for BMW spoked wheels:
    Jim :brow
    #12
  13. michnus
    Apr 14, 2005
    2,353
    South Africa
    Jim, thanks for the trouble getting the information. Both my 1200's have the same problem with the rear wheel running out just slightly.
    #13
  14. luv2lean
    Feb 7, 2003
    1,073
    East of Sacramento
    My spokes are now tight thanks to the helpful information on spoke service provided by Woody.
    I found the most important tip was to back the nipple off 1/4 turn before loosening the set screw.
    #14
  15. michnus
    Apr 14, 2005
    2,353
    South Africa
    The spoke service by Woody, is it a write up on the forum, where can I get hold of that info from Woody?
    #15
  16. luv2lean
    Feb 7, 2003
    1,073
    East of Sacramento
    See JimVB's post above for woody's write up
    #16
  17. Clinton Lesch
    Clinton Lesch n00b
    Jun 12, 2019
    1
    durban
    had an issue with front wheel running side to side +- 8mm felt it on the bars after fitting new tyre
    got same response from BMW (15k for new wheel) "nobody in durban can do it"
    Busy having a go at resetting it myself, almost there. runout currently under 1 mm.
    will get it better still.
    #17
