Timing Problem
Discussion in 'Crazy-Awesome almost Dakar racers (950/990cc)' started by jsrider, May 6, 2006.
  1. jsrider
    jsrider Long timer
    Jun 30, 2004
    3,495
    After completing the ignition rotor and cylinder head nut bulletins, and checking my valves, I put my bike back together. When I fire it up, it idles for a few seconds, then backfires and stalls. I seem to have screwed up the timing. I was very careful to do the bulletins one bolt/nut at a time. I carefully checked the cams to make sure I reinstalled them properly according to the timing marks on the camshaft gears. Any thoughts on where to look next?
  2. coyote
    coyote gagger of lollies
    Dec 5, 2003
    27,987
    on the Rogue
    Did you lock the crankshaft when you did the valve shims?
  3. jsrider
    jsrider Long timer
    Jun 30, 2004
    3,495
    Yes. Did one cylinder at a time. Did the ignition rotor before removing any valve covers. Went back and checked TDC for each cylinder by putting a metal rod down the plug hole.
  4. coyote
    Dec 5, 2003
    27,987
    on the Rogue
    Vacuum leak?
  5. jsrider
    jsrider Long timer
    Jun 30, 2004
    3,495
    Well, I did notice that part of the rubber fitting between airbox and rear intake manifold had gotten pushed under the airbox when I reassembled the bike, but my local wrenching friend didn't think that would cause this problem. Could he be wrong?
    When I first tried to start the bike, it wouldn't idle at all. I left it alone overnight, then tried the next morning. That's when it started backfiring and appearing to exhaust back up the carbs.
  6. jsrider
    jsrider Long timer
    Jun 30, 2004
    3,495
    Looks like he was. Put the airbox and carbs back on and the bike runs like a champ. Moral of the story: be really careful when putting hoses and grommets back together. A little silicone grease goes a long way. From my experience so far, reassembling the airbox/carbs is the hardest part of working on this bike.
  7. YOGOI
    YOGOI Prick
    Jun 21, 2004
    3,771
    Logan, Utah
    :clap .
