Tips and tricks to help remove a sticky exhaust can?
Discussion in 'GS Boxers' started by bostax, Jun 19, 2021.
  1. bostax
    bostax Trying to cross as many lines as possible Supporter
    Apr 14, 2016
    33
    Boston (well, outside of it)
    Hello Inmates!
    Hope everyone is well. I did in fact search the site and found nothing on this particular point. So, if I missed it apologies. Otherwise here we go:
    Does anyone have any tips or tricks to help remove a stock exhaust can from the pipe on a (new to me) 2017 Rallye? I am trying to install racks for the 35L BackCountry from Mosko and I am having trouble removing the exhaust can.
    I removed the three T25 srcrews, the top one above the can (size escapes me) and loosen the 13mm nut so the cuff slides back. I wiggle and cajole as much as I think would be needed to get it to slide off. I don't come BMWs and, while I realise they are tough bikes, I don't want to cause any real damage just wrenching on it with reckless abandon. And before I go down the WD-40/heat avenue I thought I would check with some folks smarter than me. That would be you all.
    Thanks in advance and stay safe out there.
  2. Lead Wrist
    Lead Wrist Mehr Gelände Weniger Straße
    May 26, 2007
    14,948
    Zer0-Zer0-Zer0-Zer0
    ^ If you removed both the clamp btw slip-on/headers and top hanging screw, that's all that holds slip-on in place so using some sort of penetrant and rotating slip-on back-'n-forth to break it free is all you'll need to do...
    bostax likes this.
  3. PaulBarton
    PaulBarton Long timer Supporter
    Apr 14, 2015
    3,727
    Seattle
    On my 1150GS I had a tough time getting the stock can onto the DanMoto Y-pipe. Ultimately I used a strap wrench (sold at FLAPS for under $10). When I needed to remove it to add RTV sealant (decel popping) the strap wrench worked perfectly.
    bostax likes this.
  4. JimVonBaden
    Feb 11, 2005
    95,493
    Alexandria, VA
    Push up and down as far as possible, then side to side as far as possible, the wiggle like hell and pull. This never fails, though you will need to repeat the process a few times.
  5. pharme
    pharme Been here awhile
    Dec 27, 2006
    634
    Portland
    I squirted wd40 on the joints and they come loose easily.
    bostax likes this.
  6. Jim Moore
    Jim Moore "You ain't black!"
    Dec 24, 2001
    37,402
    Jax, FL
    Hammers and crow bars are perfectly acceptable tools for exhaust work.
    ATCguy, JimVonBaden and bostax like this.
  7. bostax
    Apr 14, 2016
    33
    Thank you
  8. bostax
    Apr 14, 2016
    33
    Thanks, I’ll check that out
    #8
  9. bostax
    Apr 14, 2016
    33
    Got it, thanks JVB
    #9
  10. bostax
    Apr 14, 2016
    33
    Good to hear that the original plan was on point, thank you
    #10
  11. bostax
    Apr 14, 2016
    33
    Ahh the tractor approach, good to know.
    #11
    LAFS likes this.
  12. PerazziMx14
    PerazziMx14 Long timer
    Oct 9, 2011
    1,987
    Sometimes cursing violently at the exhaust while wiggling it helps.
    #12
    LowOnFuel, PaulBarton and m931a2 like this.
  13. bostax
    Apr 14, 2016
    33
    Oh good to know I have specific applicable experience.
    #13
    Jim Moore likes this.
  14. JMforPres
    JMforPres Long timer Supporter
    Apr 13, 2008
    1,562
    Charlotte, NC
    Any curses more effective than others?
    #14
  15. Coma
    Coma Long timer
    Jul 11, 2012
    2,689
    The Emerald Coast
    From experience I’ve found an advanced degree in Navy magic words is very effective.
    #15
  16. m931a2
    m931a2 Long timer Supporter
    Oct 2, 2014
    1,068
    Austin, Texas
    Make sure it's aligned correctly as it's a very tight fit. Rotate just a little left and right and pull. BFH with rubber if needed and maybe lube
    #16
    pennswoodsed likes this.
  17. CrustyAPO
    CrustyAPO Long timer Super Supporter
    May 7, 2008
    3,770
    New York state (unfortunately)
    When you put it back together slather some if this where the exhausts slip fit with the header as well as the clamp screw. It makes subsequent removal far easier. Also works as a gasket lubricant on bikes that utilize the tubular Grafoil gaskets like ST1100’s and many others.
    #17
  18. Bluetooth Tuner
    Bluetooth Tuner Been here awhile
    Jun 22, 2019
    224
    London
    AS above but I use some high temp copper slip, first time getting the blighter off was tough as hell millimetre by millimetre, once off copper slip makes it so much easier now.
    #18
  19. vagueout
    vagueout Long timer
    Mar 3, 2010
    5,102
    sydney, east
    Along with the copper slip anti seize suggestions I clean the contact areas with scotchbrite before the anti seize and re-fit. Prevention over cure.:*sip*
    #19
  20. bostax
    Apr 14, 2016
    33
    Thanks everyone for all of the replies. Everything worked out fine. Appreciated.
    #20
    Bluetooth Tuner likes this.
