Tire guage?
Discussion in 'Trials' started by Gordy, Jan 8, 2011.
  1. jonnyc21
    jonnyc21 Trials Ninja
    Feb 8, 2011
    3,984
    Boise aria
    I definitely need a better low pressure gage... mine I think measures a half pound low. But don’t have a better gage to check it against at the moment.
    #21
  2. Yinzer Moto
    Yinzer Moto Long timer Supporter
    Jun 13, 2008
    37,203
    Pittsburgh PA
    There is 27.7” of water column in a PSI, so in theory, if I have something like 110.8” of tubing that is filled with water, connect it to the gauge, it should read 4psi, when the tubing is stretched out vertically, like out a second story window.
    I think I might make this rig this evening and test some gauges.
    #22
    jonnyc21, edgerat and Norman Foley like this.
  3. Yinzer Moto
    Jun 13, 2008
    37,203
    Pittsburgh PA
    Here we go:
    Roughly 109.3” of water column. The gauges that i wanted to test have roughly 1.5” stems off of them. So the total to the actual part that measures pressure should be 110.8”. I used a small funnel help fill it with water. There is a schrader valve from a tubliss system at the bottom, I left the rim lock on it to provide some weight so the tubing stayed straight. Initially I tried dumping water straight in but the surface tension of the water kept it from filling. So I put a few drops of dish soap in the funnel to break up the surface tension. The drops sank down the tubing and broke up all the air pockets.
    Here is my selection of gauges that I may use for low pressure. The one on the left goes in my dual sport and sometimes I may run as low as 5 psi in the rear of it. The next one lives near my air compressor in the garage, you may notice that the needle is at 2psi right now. Moving further to the right is a newer Slime gauge that I keep in the moto van. Finally, the furthest right is one that also was in the moto van.
    Surprisingly, the digital one was accurate. Right at 4 psi. It will read in .5 increments.
    The Slime gauge that is stuck at 2psi actually read 6psi. I would say that is accurate enough. I put a label on it to remind me to subtract 2psi from the result.
    The next slime gauge read perfectly.
    Finally the pencil gauge only read 1.5psi. So it went in the trash.
    #23
    LemmeTry, Gordy, flo10 and 4 others like this.
  4. fprintf
    fprintf Been here awhile
    Oct 24, 2017
    321
    Connecticut, USA
    I tried to. Unfortunately the 0 - 15 psi gauges are backordered right now at the Tryals Shop, so I am patiently waiting for Mike to ship one out to me. Great guy, thought I'd be happy with a 0-30 gauge instead and is making it right for me once the new ones come back into stock.
    #24
    Norman Foley likes this.
  5. lineaway
    lineaway Long timer
    Oct 1, 2011
    11,494
    nm
    20200629_142718.jpg Yeah, after 1 hour of mowing my riding area I rode for 2 hours. Mianly 3 20 minute sections of hard practice followed by adjustnents to the bike.
    Followed by two hours of hauling dirt as some of my railroad ties were moving and needed some support.
    Then I 2 did a water test, my 220lbs moved 15000 gallons less than 1/128 of an inch.
    #25
  6. edgerat
    edgerat Been here awhile Supporter
    May 18, 2020
    274
    Olympia, WA
    yinz really outdid yinzself there, LIKE IT!!!
    #26
    Gordy, oldtrialer, jonnyc21 and 2 others like this.
  7. NAVIGATOR
    NAVIGATOR Wanderer
    Dec 21, 2002
    1,906
    SOUTH OF THE USA BORDER(friendlier Mexico)
  8. motomofo
    motomofo Been here awhile
    Jun 13, 2014
    261
    TX
    #28
  9. Brewtus
    Brewtus Buffoonery, Inc.
    Jul 30, 2008
    7,364
    Portales, New Mexico
    There's also a Roadkill marathon on Motor Trend..... :D
    #29
  10. lineaway
    lineaway Long timer
    Oct 1, 2011
    11,494
    nm
    #30
    motomofo and Yinzer Moto like this.
