Tire heater for cold weather
Discussion in 'The Garage' started by MotorcycleWriter, Oct 31, 2019.
  1. MotorcycleWriter
    MotorcycleWriter Vis ad locum
    Dec 1, 2012
    2,938
    $$$ Valley, Utah
    I'm going to build a simple tire heater of some kind for cold weather tire changes. I have a brilliant idea that uses a big cardboard box and a hairdryer-style heat gun but wanted to see if anyone has already built one and might be willing to share lessons learned. Ideally I'll dispose of the box after the work and only store the heating system. When I need to do some tire work I can always source a box from any of the many places you can find boxes. Keep it simple.
  2. slobinski
    slobinski easily amused
    Oct 7, 2006
    725
    Relocating
    One of those noisy propane torpedo heaters aimed into a large cardboard box works fine; your tire will get plenty hot.
  3. shu
    shu ...
    Feb 23, 2010
    1,820
    Colorado
    Too much work.
    You live in Utah, no? Typically sunny even if cold outside.
    Put the tire in a black plastic trash bag and set it out against a wall in the sun. Maybe put a blanket inside the bag against the wall. I've warmed up many tires this way in Colorado.
    If it's too cold outside for the trash bag to work, fire up a small space heater and put the tire next to it. Flip the tire a few times and it should be pretty pliable. Really cold out? I'll fire up my woodstove and do the same.
    .............shu
  4. dhally
    dhally Hammerhead Supporter
    Feb 18, 2006
    5,763
    Kennewick, WA
    I use a heat gun.
  5. LuciferMutt
    LuciferMutt Rides slow bike slow
    Aug 19, 2008
    16,349
    New(er) Mexico
    Heat producing implements aimed inside a flammable box sounds like a terrible idea.
    Why not just buy a tire warmer like what racers use, and wrap it around the unmounted tire?
    Boatman likes this.
  6. kantuckid
    kantuckid Long timer
    Nov 29, 2007
    9,649
    Kentucky-Eastern that is!
    Take it to the house overnight, sit it near the heat source.
    Need For Speed and sieg like this.
  7. AwDang
    AwDang Enabler
    Sep 1, 2014
    2,923
    MABDR mile post 0
    Tire warmers are slow to get up to temp.
  8. slobinski
    Oct 7, 2006
    725
    Relocating
    Also I had both the heater and an economy-sized box on hand. Net outlay, zero.
    #8
  9. Tim McKittrick
    Tim McKittrick Long timer
    Dec 29, 2003
    2,352
    Wasilla Alaska
    I use my race warmers- takes about 30 min to get the tires toasty. A rear warmer will work easily on a dismounted front tire/wheel assembly.
    Used warmers can be had pretty cheap and they roll up into a small space.
    #9
  10. jdrocks
    jdrocks Gravel Runner
    Jul 6, 2007
    7,934
    you already have a tire heater, it's called a car/truck. set the tire on the front seat with the temp control set to broil, 30 minutes later mount the tire.
    #10
    shu likes this.
  11. KeithinSC
    KeithinSC Long timer
    Oct 18, 2009
    5,748
    Sandhills of SC
    I used an electric blanket from the thrift store once. Worked pretty good. But I usually just toss the tire in the cab of my truck, parked on the sunny side of the yard.
    #11
    shu likes this.
  12. shu
    shu ...
    Feb 23, 2010
    1,820
    Colorado
    Great idea: in the car or truck.
    Put it in the black plastic trash bag before you put it in the car, too. It's amazing how much heat is gained and stored by the tire inside the bag.
    .............shu
    #12
  13. JimVonBaden
    Feb 11, 2005
    90,944
    Alexandria, VA
    I just set my new tire against a 1500 watt oil filled electric heater. One on each side is at least as good as direct sunlight.
    #13
  14. marc11
    marc11 Been here awhile
    Nov 5, 2009
    459
    New York
    I purchased a set of tire warmers a few years ago for $200. One of my best investments, makes the tires super hot and they go on so much easier. I wrap the tire whole removing the old one, and by then it's warm enough to pop on, if I want I can wait 15 mins more or so and get the tire stupid hot.
    I've never been in such a rush to change tires that "tire warmers take too long" to warm the tires. Within 15-30 mins it's nice and hot, in that time I can enjoy a beer or coffee or coffee beer.
    Zero regrets with that purchase, zero.
    #14
  15. richarddacat
    richarddacat Do enjoy your party Super Supporter
    Nov 22, 2006
    5,991
    Heart of Tennessee
    I’ve done that using a small space heater, worked good.
    Don’t walk off and leave it.
    #15
    MotorcycleWriter likes this.
  16. 2WheelieADV
    2WheelieADV Long timer
    Sep 30, 2010
    1,147
    NJ, USA
    Just put a fen on hot in the tire for 15 mins. Will get on a rim like a glove.
    #16
  17. MrPulldown
    MrPulldown Long timer
    Aug 18, 2009
    8,322
    Truckee
    I used an electric radiator oil type heater. Set a 2x4 on top and the tire on top of it.
    #17
    Coma likes this.
  18. JimVonBaden
    Feb 11, 2005
    90,944
    Alexandria, VA
    Exactly! :deal
    #18
  19. VX Rider
    VX Rider Long timer
    Dec 11, 2015
    5,978
    Phoenix
    Today in Phoenix @78
    New tire in Back seat of car
    Parked in sun
    Off at 4PM
    40 min drive home
    Removed rear wheel and tire
    Use Bead popper and 2.5 lbs hammer
    Remove old carcass
    New tire out of car...apppx 90
    Lots Ruglyde
    Tire pops right on the rim
    Only needed tire irons on second side for last 10 to 12 inches
    Tire pops on
    More Ruglyde
    Hook up 12v tire pump
    About 10 m8 utes the bead pops on
    And runs up to 42 psi
    #19
  20. Bigbob1
    Bigbob1 Rain Rider Supporter
    Sep 20, 2009
    996
    Juneau Alaska
    I live in Alaska so I use a electric heater year around to heat up my tires.
    #20
    JimVonBaden likes this.
