Tire options for Africa Twin
Discussion in 'Japanese polycylindered adventure bikes' started by BRITTURB, Jun 15, 2017.
  1. Drif10
    Drif10 Accredited Jackass
    Jun 12, 2003
    52,559
    Gates of Moscow
    Just go with the Motoz adventure rear. You run dirt a lot, having run that tire, I think you'll be very happy with it.
    seancampbell and Junglejeff1 like this.
  2. Junglejeff1
    Junglejeff1 Long timer
    Oct 20, 2016
    5,588
    Upper Michigan
    Thanks,that is my next back tire and going to try the goldyntire 90/100 on front.I think this is about as far as I can go without switching to straight dirt tires.Wife likes this stuff and I like to make her happy.I like to rip on my yz250 pol.
    C.J. likes this.
  3. Yooper_Bob
    Yooper_Bob Insert witty saying here....
    Aug 31, 2005
    5,270
    Da UP, eh! (Marquette, MI)
    +1 on the Motoz rear....it handles just like a knobbie in the dirt, in my opinion.
    Still hunting for a front with more bite. The Motoz tractionater was good... but did not last very long. The shinko is great on the tarmac, ok on hard packed, but not enough side bite in sand and mud.
    Junglejeff1 likes this.
  4. Zave
    Zave ******
    Jun 16, 2014
    1,498
    BC Canada
    I'm not happy with the 804 i got i think it is defective a little out of round i get a very annoying hop between 50-60 km/h it's prob just a one off tho no one else has had the problem. I broke the bead and reinstalled nothing seems to work. I'm going for a e10 up front next
  5. Drif10
    Jun 12, 2003
    52,559
    Gates of Moscow
    I have the same experiences with those two tires. :nod
    Tried a tkc80 front. Loved it in a 19" on my GSA, still hate it in a 21". Based on our talks, I don't think you'd like it.
    These Karoo 3's are a much more open tread. The front might suit you better, but I haven't beat on it enough to recommend it.
  6. advdoctor
    advdoctor Been here awhile
    Sep 18, 2009
    260
    Interior Alaska
    I experienced a serious and reproducible tank slapper at 70 mph with the motoz tractionator up front.
    Junglejeff1 and C.J. like this.
  7. C.J.
    C.J. Sierra Nevada Rider
    Jan 4, 2005
    246
    Shingle Springs
    If you go with the Golden 90/100 up front you will need to raise the front fender. This is a ROX kit bringing it up 1" barely makes side clearance. Will check it out tomorrow. Motoz in back. That tire is a keeper. [​IMG][​IMG]
    Sent from my SM-N910V using Tapatalk
    Blaise W and WoodrowBDR like this.
  8. nohumdrumlife
    nohumdrumlife Adventurer
    Mar 19, 2010
    93
    Parker, CO
    I wonder how Motoz Adventures in back and a Karoo 3 in front would perform for 50/50? Even Karoo 3's front and back sounds pretty good on an AT.
  9. C.J.
    Jan 4, 2005
    246
    Shingle Springs
    Works very well up front, more than a 50/50 setup with the Motoz in back.
    nohumdrumlife likes this.
  10. Junglejeff1
    Oct 20, 2016
    5,588
    Upper Michigan
    20171031_162513.jpg I'm cool with that.Looks like it has alot deeper knobs than the shinko.
    C.J. likes this.
  11. C.J.
    Jan 4, 2005
    246
    Shingle Springs
    Did 130 miles today outside Las Vegas area. Most dirt, rock and such. The Golden 90/100 works very well on the front of our bikes. Your going to like it.
  12. Lumpster
    Lumpster n00b
    Oct 25, 2017
    4
    Clinton Pennsylvania
    I ditched the stock junk at 3000 miles for the Shinko 804/805 combo. Very happy with this combo save for the lateral grip issue and some instability on the highway. Lateral grip is terrible. Even on gravel roads, when I pick up the throttle mid corner the rear steps out. It catches you by surprise at first, but adjust your riding style accordingly and you get used to it quickly.
    Lack of lateral grip caused a couple of tip overs for me in off camber/side hill situations where the rear just refuses to track straight. As mentioned, this thing is 500lbs, but there are tires that handle these situations better, Most are twice the price though.
    I also experienced a bit of highway instability with these tires above 75 mph. It just seemed right on the edge of a tank slapper cruising at highway speeds. Not terrible, but not confidence inspiring either.
    I removed the 804/805 combo with about 3000 miles on them. The rear had some highway miles left, but I was heading out on a 2000 mile trip, and I don't think there was 2000 miles left on the rear tire. The front was fine but I chose to keep the tires matched up and spooned the 705 shinkos on due to the trip being 100% pavement.
    I have been very happy with this combo as well. Much better highway stability, but the front tire is noisier than the 804 knobby. A very noticeable hum above 60 mph. Annoying but not a deal breaker.
    A lot of twisties on the trip, and although they take a bit more effort to turn in, I was very impressed with these tires. I was riding with an advance level rider on a concourse 14 and I had no problem keeping his pace in the twisties with confidence wet or dry. I have done some gravel roads with them as well, and I think the front gives up a little to the 804 in gravel, but I think the rear is better. Definitely doesn't step out mid corner like the 805 does. Probably gives up a bit of forward drive, but it is still pretty good.
    I haven't been off road with them yet, but I think they would do fine in dry dirt. I'm sure they will give up some in all out forward traction in the slimy stuff, but I am interested to see what lateral traction is like with these. Can't be much worse really. I have ridden on a lot of different tire brands through the years, and I really think that these two lines of Shinkos are great tires, not just great tires for the money.
    I am at about 2500 miles on the 705's, most of which was spirited riding in the twisties, and they are showing very little wear. Good stuff! Ride safe!
    Drum Dog likes this.
  13. danptobin
    danptobin Been here awhile Supporter
    Jul 28, 2013
    769
    orange county,NY
    anyone find a tire that works better in mud then the tkc 80?
  14. Junglejeff1
    Oct 20, 2016
    5,588
    Upper Michigan
    Screenshot_2017-12-24-20-54-27.png this is what I am going to try on back this spring.Has about the best reviews for mud before going full knobby.
  15. craighkzn
    craighkzn Been here awhile
    May 8, 2016
    846
    South Africa
    Motoz Tractionator rear and Pirelli scorpion Rally up front...very impressed with this combo
    seancampbell likes this.
  16. craighkzn
    May 8, 2016
    846
    South Africa
  17. ICBiker
    ICBiker Adventurer
    Nov 6, 2008
    109
    Flinthills
    I am using the Mefo Super Explorer on the rear and a Pirelli MT-21 on the front. I do mostly dirt and gravel roads and find this to be a pretty good combo.
    twinrider likes this.
  18. advdoctor
    Sep 18, 2009
    260
    Interior Alaska
    Just FYI, had a bad tank slapper problem with my MotoZ tractionator adventure up front. Rear great.
  19. Junglejeff1
    Oct 20, 2016
    5,588
    Upper Michigan
    Thanks just going to try rear.Have not heard much good on front.
  20. Drif10
    Jun 12, 2003
    52,559
    Gates of Moscow
    Still haven't gotten any feedback on the 2.0 version of the front Adventure. I've heard that it's available, but not seen any commentary on it.
