Tire options for Africa Twin
Discussion in 'Japanese polycylindered adventure bikes' started by BRITTURB, Jun 15, 2017.
  1. Muddler
    Muddler Long timer
    Dec 12, 2008
    1,136
    Dardanup, Western Australia
    Very good for a non-knobby 90:10 tyre. They went better off road then I thought they would
  2. maddoggie501
    maddoggie501 Been here awhile
    Nov 15, 2007
    199
    Albuquerque, NM
    Just installed the Dunlop Missions. So far great on the street. No noticeable difference than the stock tires. I've done a test off road on a smooth damp hard packed surface and they stuck like glue. They also stopped without excessive skidding. The stock tires would slide and skid way more than the Missions. They give me a lot more confidence off road.
  3. Ian-NH
    Ian-NH Adventurer
    Jan 12, 2017
    76
    Raymond NH
    I see quite a few of you guys referencing the Shinko 804/805.
    When I got look them up all I find is "TL" for tubeless. Can these be used on tubed rims or are you guys all going tubeless?
    I want something more aggressive than my stock tires but everything I find is tubeless
    Also, quite a few more options open up if you switch to the 140/80-18, any thoughts on this skinnier tire?
    Ian
  4. leethal
    leethal 3 wheel Monarch #37
    Oct 14, 2008
    567
    Mornington peninsula, Melbourne
    TL Shinko is fine with tube. I run mine tubeless now though.......far easier.
  5. Junglejeff1
    Junglejeff1 Long timer
    Oct 20, 2016
    5,588
    Upper Michigan
    Putting a 3rd set on mine and they work just fine with tubes.They only last about 6k but good do it all tire except the front don't like mud.
  6. William Wolfen
    William Wolfen Long timer
    Dec 5, 2015
    4,383
    Cypress, TX
    Do any tires truly like mud?
    Junglejeff1 likes this.
  7. RoyQ
    RoyQ Long timer
    Dec 13, 2004
    2,552
    Mississippi
    On my 2nd set, they work really well for me. Fast on pavement and good enough on gravel which is about as far as I go with a 500# +/- motorcycle. I get decent mileage from them when not pushed hard in tight corners all the time. Very good mileage on the straight slabs.
  8. AZT2
    AZT2 Adventurer
    May 21, 2008
    26
    Glendale, Arizona
    Just put the Motoz Tractionator GPS on the front and rear (50-50). So far I like them on the road as well as in the dirt and mud. I did not find them loud as some say. The front does not track the road snakes as the OEM tires did.
    Lost Cartographer likes this.
  9. William Wolfen
    Dec 5, 2015
    4,383
    Cypress, TX
    Glad to hear another positive review. That's what I plan on getting when tire time comes.
  10. Junglejeff1
    Oct 20, 2016
    5,588
    Upper Michigan
    The motaz adventure,s are the loud ones.
  11. Motociclo
    Motociclo Former Af Twin owner!
    May 18, 2017
    1,293
    The Hunter.
    20200106_201432.jpg Onto second set of Motoz GPS. Got 25k km out of front. Getting about half that for rear.
    Been quite happy with them. Balance well also.
  12. Amphib
    Amphib A mind is like a parachute....
    Sep 19, 2018
    3,968
    Wnc
    I am as well. I'm about 3k miles into my 2nd set. I pulled the previous off at 7400 miles. There was probably another 500-750 left on rear, tons left on the front, but wanted to compare another front tire. It balanced with a fraction of the weight and runs smoother than the previous. At this point, I have no reason to try anything else. Its perfect for where and how I ride.
  13. Junglejeff1
    Oct 20, 2016
    5,588
    Upper Michigan
    Damit I was hoping they did better than that.Replacing the shinko,s every 6 to 7k and was hoping for the unicorn 10k.Still going to try a gps in back after I burn up a new set of shinko,s I have setting in corner.
  14. Amphib
    Sep 19, 2018
    3,968
    Wnc
    I was hoping for more as well, but I am heavy handed and usually on the low end of milage estimates. An easier rider, less rough, rocky riding could get quite a bit more out of it. Plus my estimate could be off as well. The old ones were pulled prior to my Thanksgiving trip.
  15. Junglejeff1
    Oct 20, 2016
    5,588
    Upper Michigan
    I guess I am screwed on it anyway using the bike for all 2 up riding.Maby if I cut the food off to wifey and get her down to 100 lbs it will help lol.
    Amphib likes this.
  16. Amphib
    Sep 19, 2018
    3,968
    Wnc
    :lol3
    Curious what I'd get out of a shinko for better comparison. I've never run them, but given you're getting 6-7k, which sounds great, maybe worth a try on the GPS. From reading, it sounds like you're on the high side of milage estimates. I was thinking, from trying to compare other reviews, that I might get 5k out of that tire. One of these days I should probably give it a try.
  17. Junglejeff1
    Oct 20, 2016
    5,588
    Upper Michigan
    5k would be better but I run them till I hit the carcass. Does the gps slide out easy in mud?I tried a standard E-07 with the center strip so that solid center on that GPS spooks me a bit.The shinko slides out easy but the midas put me on my ass a few times.
  18. Amphib
    Sep 19, 2018
    3,968
    Wnc
    Ive been shocked how well they do in mud. Of course I adjust my riding accordingly, but mud has not put me down yet <knocks on wood >.
    If you're running tires to the carcass, I'd sure think you'll get 10k easy on the GPS. At 4ply there's a massive amount of rubber on those tires. I'm usually out solo and many times not sure what I'll be getting into so I always want tread on my tires. Personally I think they do better than they look.
  19. Junglejeff1
    Oct 20, 2016
    5,588
    Upper Michigan
    When they get down on rubber I stay out of the nasty stuff.Its not that I am cheap but hate changing the back tire.Wish they were like my trials bikes.Can almost yank those off by hand there so soft.
    Amphib likes this.
  20. DCTFAN
    DCTFAN 2019 CRF1000LD Supporter
    Mar 17, 2016
    2,305
    GA
    "TL" with tubes is fine.
    But if you're going with 140/80/18 try to keep pressures above 30 psi.
    I forgot to air up from about 28 psi on a MotoZ Desert H/T and ripped off the valve stem after some twisty roads.
