Tire pressure gauge question
Discussion in 'GS Boxers' started by DT455A, Jun 29, 2020.
  1. DT455A
    DT455A Adventurer
    Nov 14, 2015
    16
    California
    When u use an tire air pressure gauge you lose a bit of air. Anyone know how much? I seem to lose about a pound of air each time, seems like a lot for that brief time. Just wondering
  2. SPX
    SPX Long timer Supporter
    Nov 27, 2011
    1,506
    IMO, it depends on the gauge, technique, angle of the valve, and whether you have spoked or cast wheels.
    I find the vertical (older) valves cause more air to escape due to the angle that you have to go in at with the gauge. The horizontal/90° valves I can do with basically no air escaping.
  3. DT455A
    DT455A Adventurer
    Nov 14, 2015
    16
    California
    Good info, thanks
  4. 150flyer
    150flyer Been here awhile
    Oct 8, 2016
    121
    Ft. Worth
    If you think a straight valve looses more air, it’s just because you’re fumbling around trying to square up the the face of the gauge to the opening of the valve and loosing air. Whether the valve is straight or angled or the wheels are spoked or cast has nothing to do with how much air is lost. The amount of air lost depends on how much air a specific gauge must sample for a reading. I have a small digital gauge with no hose that can take half a dozen readings before losing even one pound of air. On the other hand, I have a large analog gauge with a 12 inch hose that looses over a pound of air for each reading.
  5. Barnaby'sDad
    Barnaby'sDad Been here awhile
    Sep 20, 2019
    404
    Virginia
    I use an old school stick type pressure gauge. With proper technique/alignment, you don’t lose a measurable amount. I go literally weeks without having to add air to my tires.
    If you’re losing 1psi or more every time you check your tire pressure...that’s operator error and/or an equipment issue. Ex. Properly align the pressure gauge BEFORE you press down on the valve stem.
    cpallen and side-burn like this.
  6. SPX
    Nov 27, 2011
    1,506
    Perhaps I was unclear, but you’re saying exactly what I was trying to say... of course the wheel type or valve alignment makes no difference, other than how easy it is to square up the valve and the gauge. Aka: user error. ;-)
  7. cpallen
    cpallen Nearly Adventurer
    May 26, 2003
    1,865
    Panora, IA
  8. sceep
    sceep Long timer
    Jun 15, 2010
    1,509
    Edgewood NM
    #8
  9. lewisjr1
    lewisjr1 Long timer Supporter
    Sep 26, 2008
    5,529
    DC metro
    If we're transitioning to show & tell...
    I'm a fan of the 0-40 psi Liquid series QuickCar Racing Products 56-041 Tire Pressure Gauge with Swivel Chuck and Relief Valve. The gauge tops just shy of where some may like to set their pressures, but it works well for me across multiple bikes and cars. There's a corresponding 60 psi model -061, but I'm old enough that the easy-reading -041 model works well for me. And it's worked well for over a decade. Now that I've typed this it'll probably fail the next time that I use it.
    #9
    cpallen and sceep like this.
