Tire Pressure Monitoring/Alert system Cyclops Adventure Sports
Discussion in 'Vendors' started by Off Road Ryder, Apr 20, 2017.
  1. Off Road Ryder
    Off Road Ryder Long timer
    Mar 29, 2010
    3,939
    Kent Wa
    After more than a year in development, We are really excited to bring you something new.
    What is the single most important item on your bike? If you think about it, Probably the most overlooked and potential self inflicted hazard for us riders.
    Tire pressure,lack of checking pressure before jumping on the bike and leaks from impalements while we ride.
    Our New Motorcycle Tire pressure management system is ready for shipment. use this promo code to save $30.00 for a very limited time. Use code TPMS
    Now update your bike with a Cyclops Tire Pressure Monitoring System. Get real time info on tire pressures and tire air temperature. A huge safety advantage, know what your tire pressures are when you jump on your bike. Easy to install and operate, this system uses replacement valve caps to actually show your tires current air pressure and air temperature on the multi-color display in real time. Set an adjustable audible alarm for low and high pressure warnings. mounts to dash or handle bars, both mounts included.
    http://www.cyclopsadventuresports.com/Motorcycle-Tire-Pressure-Monitoring-System_p_171.html
  2. BrittC
    BrittC Been here awhile
    Apr 10, 2009
    624
    Westmont, IL
    I may have to give this a try. My bike came with dead TPMS batteries inside the wheels which means breaking the tires from the rims to change them....
    DRV and Off Road Ryder like this.
  3. Off Road Ryder
    Mar 29, 2010
    3,939
    Kent Wa
    Thanks. We really feel this will be a great safety feature. Most bikes do not have a TPMS.
    I know I don't think about my tires to much until I'm rallying down some road with my wife on the back of the 990, then ... yikes I forgot to check my tires... Ive also lost a front tire at speed twice in my life, both times ending in a totaled bike with injuries. One was a pothole and low air pressure, the other was a high speed banked corner with low air pressure, these factors were what pushed us into this product, we know it will be of benefit for anyone who rides a bike without a factory TPMS.
    REALGRAVEROBBER likes this.
  4. BrittC
    Apr 10, 2009
    624
    Westmont, IL
    Do the sensors have replaceable batteries or do the valve caps get replaced when dead?
    Off Road Ryder likes this.
  5. HAYVIATOR
    HAYVIATOR Don't be me dude.
    Dec 1, 2012
    453
    Skagitopia, WA
    Ordered.
    DRV likes this.
  6. DRV
    DRV Been here awhile
    May 18, 2012
    704
    Seattle
    The batteries are replaceable in the valve caps.
    Kerrizor, Scot66 and Off Road Ryder like this.
  7. Rootkiller
    Rootkiller Been here awhile
    Mar 23, 2003
    436
    Monroe, Washington
    Looks great, suitable for tubed tires?
  8. Off Road Ryder
    Mar 29, 2010
    3,939
    Kent Wa
    Yes they use watch style batteries.
    #8
  9. Off Road Ryder
    Mar 29, 2010
    3,939
    Kent Wa
    Thank you!
    #9
  10. Off Road Ryder
    Mar 29, 2010
    3,939
    Kent Wa
    Absolutely. tube or tubeless.. Photos of the sensors and mounted on the bike coming..
    #10
    Scot66, Rootkiller and maritan like this.
  11. MtnRider
    MtnRider Been here awhile Supporter
    Nov 23, 2008
    529
    Santa Rosa, CA
    What is the approximate weight of the sending unit (cap)? In other words is it enough to upset the balance of a currently balanced wheel?
    #11
  12. DRV
    May 18, 2012
    704
    Seattle
    It shouldn't throw the balance off, just put one sender on the kitchen scale weighs 1/4 ounce or 10 grams. Thanks drv.
    #12
    MtnRider likes this.
  13. MtnRider
    Nov 23, 2008
    529
    Santa Rosa, CA
    Thanks for the info. I've got your LED's for Hi/Low and they rock...I'm sure these are also fantastic. Order will be placed in the near future
    #13
  14. flei
    flei cycletherapist
    Apr 1, 2013
    10,797
    Western Mass.
    Ordered. I've been waiting for something like this to come along. Most reviews I have read of other valve cap systems (some at 3x this price) report them as unreliable. Given your reputation and the discount price, willing to give these a try. The closest I've ever come to wrecking was a front flat; maybe with this system that risk will be reduced.
    #14
  15. DRV
    May 18, 2012
    704
    Seattle
    Awesome! Thank You Very Much. drv.
    #15
  16. Parrothead
    Parrothead Cu Dubh
    Aug 12, 2004
    694
    One Particular Harbor
    Ditto on what Flei said above (except for the wrecking part: most of mine were from speed, youth and stupidity!). Ordered and looking forward to this. You guys are great!
    #16
  17. Off Road Ryder
    Mar 29, 2010
    3,939
    Kent Wa
    Thank you Sir!
    #17
  18. Off Road Ryder
    Mar 29, 2010
    3,939
    Kent Wa
    Thank you we took quite a while to test, modify and determine we wanted to move forward with this product. One major change we made during the Beta testing was to move to 12v power rather than batteries for the display power.
    #18
  19. GB
    GB . Administrator Super Moderator Super Supporter
    Aug 16, 2002
    67,932
    Awesome product :thumb Can these be used with rubber valve stems or is it best to replace the rubber stems with metal ones?
    #19
  20. Off Road Ryder
    Mar 29, 2010
    3,939
    Kent Wa
    Thanks Gb. I appreciate you cleaning that up. . I know of no reason why a rubber valve stem would need to be replaced with metal. We have been beta testing for close to a year on both stem styles and have seen no issues either way.
    If a valve stem is aged to the point of cracking or being brittle, replacing might be a good idea, we will be coming out with a internal version as well in the future. provided this product is well received. Most tube tires have a metal stem.
    #20
