Tire pressure new wheel sizes 21/18 to 19/17
Discussion in 'The Garage' started by Chillis, Sep 5, 2019.
  1. Chillis
    Chillis Long timer Supporter
    Aug 25, 2005
    11,610
    Las Vegas
    Stock CRF450L tires are 80/100-21 front and 120/90-18 rear. Honda says 22 psi f/r.
    Just mounted up these beasts:
    110/80-19 and 150/70-17.
    Any rec's on tire pressure?
    For mountain biking you lower the pressure for the more voluminous tires.
    I have it at 22 f/25 r.
  2. Yinzer Moto
    Yinzer Moto Long timer Supporter
    Jun 13, 2008
    32,013
    Pittsburgh PA
    Considering the weight/size of the bike, I’d be shooting for closer to 10 than 20. You might want to apply chalk to the tread and see what kind of contact patch you get at different pressures.
    I ride a bike that is a similar weight and on traditional 18/21 tires, I run 15 for all around riding. 20 if it is going to be an all day highway blast. 10 if it is going to be totally in the dirt. I’ll drop to 5 if it is really muddy.
    Do some volume calculations and that should lead you to a percentage of difference, then you can apply that number to your pressures. You might be looking at close to 10 f/r.
    Bitingdog, Chillis and 2WheelNeal like this.
  3. CDN Rick
    CDN Rick Canoodia Eh?
    Jan 8, 2015
    18,439
    Niagara, Canada
    Obviously a spreadsheet is in order here....
    I hope the OP posts it when it's done so I can print it out and hang it on my shop wall for future reference.....
  4. Bultaco206
    Bultaco206 Back-to-back motos suck Supporter
    Feb 11, 2007
    45,310
    Mineral Point, WI
    They’re radials and don’t like the lower pressures, even off-road. They get very sketchy and vague. I’d not really want them below 20 on a super-light bike like an Elle. My CB500X didn’t like them below 30 on any surface.
    Chillis, CDN Rick and Yinzer Moto like this.
  5. Yinzer Moto
    Jun 13, 2008
    32,013
    Pittsburgh PA
    Radial tires on a dirtbike? :hung
  6. Yinzer Moto
    Jun 13, 2008
    32,013
    Pittsburgh PA
    So, radial tires are not really intended to conform to the terrain. I am so pigeon holed into the world of small dual sports, I forgot about radial tires. I remember from back in my rock crawler Jeep days, the bias ply tires were better.
    Bitingdog, Chillis and Bultaco206 like this.
  7. foxtrapper
    foxtrapper Long timer
    Sep 6, 2011
    4,055
    @Chillis,
    Start at stock pressure, then go up 5 psi, and down 5 psi. You don't have to ride far to get a pretty good idea which direction worked right, and which direction didn't. If it wasn't clear enough, do it 10 up and 10 down.
    From there, go another 5 psi in the right direction. Then another 5 psi.
    You'll quickly reach a point where there doesn't seem to be any appreciable change from a 5 psi change. You're in the range of "right" at that point. You can further dial in, but it becomes difficult to optimize because most of us aren't sensitive enough.
    Use a notebook.
    Chillis likes this.
  8. Chillis
    Aug 25, 2005
    11,610
    Las Vegas
    Running 22f/25r seems good but I was bouncing like crazy on washboard. Traction was decent though.
    Rear at 25 psi, no problems anywhere. Bike is very neutral handling as well.
    I won't truly be able to dial it in until the lowering links are on and sag is set. Right now there is too much weight up front.
    #8
  9. shinyribs
    shinyribs Thumpers for life
    Sep 24, 2011
    4,826
    The South
    Smaller diameter tires will do that. You'll just have to adapt.
    #9
    Bitingdog and Chillis like this.
  10. Chillis
    Aug 25, 2005
    11,610
    Las Vegas
    Still waiting on lowering links, speedo healer, and smaller rear sprocket before I tackle tire pressure testing.
    Good news is they arrive today.
    #10
  11. ohgood
    Sep 21, 2010
    9,679
    alabama
    nice looking street tires.
    air pressure is changed for the terrain. if you're riding street, set street pressure, if you're riding dirt lower it.
    #11
