Tire won’t seat. Tried every trick
Discussion in 'The Perfect Line and Other Riding Myths' started by HOTPASS, Mar 31, 2018.
  1. DavidR8
    DavidR8 Wanna-be ADV rider
    Jun 14, 2013
    266
    Victoria, BC, Canada
    I think we lost the OP.
    #21
  2. TheProphet
    TheProphet Retired; Living the Dream
    Mar 7, 2014
    10,257
    NW Illinois, Driftless Zone
    What is the brand name and model # of the rim? :confused
    #22
  3. Bar None
    Bar None Long timer Supporter
    Mar 2, 2007
    12,405
    SWFL WNC
    I hate that when it happens!
    #23
  4. sieg
    sieg Wearing out tires......2 at a time, day after day. Supporter
    Jul 9, 2008
    7,358
    Southern Illinois USA
    DR rims are tube type, so assuming the OP has a tube in it; removing the value core or using a bead blaster or a tie down around the tire would have no bearing on the result. But it's an aftermarket rim so it could be tubeless, OP has never given us this info. ?? But he has gotten it to hold air, because he said when he deflates it, it falls in to the valley with the push of two fingers. So if it tubeless or tubed doesn't matter as he is getting it "beaded up" well enough to hole air. It just falls in when deflating. So could it be that the new rim just doesn't have a "safety bead" or "mounting hump" ? Therefore there is nothing to hold the bead out against the outside of the rim. OR does the rim have a safety bead or mounting hump and the tire is not popping over it ? A picture of the aired up tire and rim and a picture of the inside bead flange of the wheel would help a lot, for understanding the problem.
    #24
  5. DavidR8
    Jun 14, 2013
    266
    Asking this question for my education: are there standard bead and rim profiles?
    #25
  6. outty
    outty (☞゚ヮ゚)☞
    Feb 4, 2018
    323
    Edmonton, Alberta
    Try a ratcheting strap around the center of the tire and ratchet it down, effectively squeezing the bead outward, before airing it up.
    #26
    TheProphet and dtysdalx2 like this.
  7. VX Rider
    VX Rider Long timer
    Dec 11, 2015
    5,706
    Phoenix
    Yes....and one of the major topics of
    Discontent between motorcycle tire and car tire on a motorcycle discussions
    #27
  8. foxtrapper
    foxtrapper Long timer
    Sep 6, 2011
    4,067
    Yes. But there's quite a number of them.
    #28
    DavidR8 likes this.
  9. bigdog99
    bigdog99 Weaned and neutered
    Mar 25, 2004
    556
    Grass Valley, CA
    Sounds like a defective tire. If the bead is lubricated and he's been to 100psi, then something is wrong with either the rim or tire.
    #29
  10. Strong Bad
    Strong Bad Former World's Foremost Authority Supporter
    Oct 29, 2007
    10,930
    Omicron Persei 8
    A seated tire means the tire bead is pressed fully up against the outer lip of the rim from inflation, on a tube tire & rim it has nothing to do with being able to squeeze the tire with your fingers when deflated.
    #30
  11. VX Rider
    VX Rider Long timer
    Dec 11, 2015
    5,706
    Phoenix
    No pictures
    Is it
    A
    Car tire?
    #31
  12. bungie4
    bungie4 Frostback
    Jan 15, 2009
    656
    Sudbury Ontario
    I had this exact problem mounting a 120/70-17 PR3 that had been sitting in my garage for 2 years. The tire had taken a 'set' with the beads only an inch or so apart. No amount of loob, ratcheting, wiggling, swearing or offerings to the gods would get it to seat.
    The bead blaster took care of it in 2 seconds. It cost me 2 coffees. Best money I ever spent.
    #32
    Bar None likes this.
  13. Moose Dog
    Moose Dog Mr. Nice Guy
    Feb 22, 2009
    9,991
    Allegan Michigan
    It's the Pro Wheel rim, they're made in China, built a set for my CRF using Pro Wheel rims, neither tire will seat completely, the rim is simply to big in diameter from the factory where they are rolled and welded together.
    #33
    lnewqban likes this.
  14. Jbrjbr21
    Jbrjbr21 Been here awhile
    May 17, 2017
    583
    Marion Il
    Said that on first reply, made in China :(
    #34
  15. Bayner
    Bayner Long timer
    Mar 27, 2008
    2,340
    Penticton, BC, Canada
    It's not uncommon for narrow dirt bike specific rims to lack any type of welt or rise to keep the tire against the rim with little or no air pressure. I've had multiple (especially front) rims that I could squeeze with my hand and unseat when deflated. I don't think it's a problem.
    Assuming that's what he's trying to describe. If he means the tire doesn't ever come into contact with the outer flange of the rim, then that's an actual problem...
    #35
    lnewqban and sieg like this.
  16. High Country Herb
    High Country Herb Adventure Connoiseur
    Apr 5, 2011
    27,995
    Western Sierras
    We had a similar problem on my wife's front tire. This was at a small shop, so I watched while 2 experts struggled with it.
    The solution was a giant pair of tongs, like you might use to get metal objects out of a forge. One guy inflated, while the other guy pulled on the tire at multiple points around the circumference. Eventually, all parts of the tire were pulled up on the bead.
    He told me to keep it at 70 psi for a while before dropping the pressure.
    #36
    RVFlyer likes this.
  17. Jarlaxle
    Jarlaxle Bregan D'Aerthe
    Nov 2, 2014
    12,538
    New England
    Yeah, they're pretty good!
    #37
  18. Tinker1980
    Tinker1980 Doesn't ask why, only asks how
    Dec 10, 2012
    4,720
    Nowhere, OK
    I fought with one like this on an old Intruder. Nothing would make it seat. I tried everything except giving up and taking it to a tire shop.
    So of course, I gave up and took it to a tire shop. They took the rim back in their shop, I heard a pretty loud POP, and they brought me my tire back correctly mounted. They said it took 120 psi. Yikes. I aired it up to 60 and was getting nervous.
    #38
  19. Norty01
    Norty01 RIDERCOACH (RETIRED!)
    Jan 30, 2014
    2,159
    CARLSBAD, CA, USA
    Sounds like it's the tire bead circ, or the rim bead circ. Or both. Seen this happen with knobbies that were "re-capped."
    I'd hesitate using anything that didn't "fit as designed" when it comes to tires/wheels. Tires go flat, then come off their beads are a recipe for disaster.
    #39
  20. TheProphet
    Mar 7, 2014
    10,257
    I've used a length of rope, placed around the outer circumference and center of the of the tire tread, then a breaker bar twisted around the two ends to tighten the rope until the tire is spread, and pushed up against the bead. Apply air nozzle, move the tire back n' forth until a seal is achieved, and it usually works.
    #40
