1. eNewsletter Sign Up
tires for big bend in feb
Discussion in 'Tejas and the Gulf States' started by danptobin, Aug 12, 2019.
  1. danptobin
    danptobin Been here awhile Supporter
    Jul 28, 2013
    718
    orange county,NY
    I'm planning to ride my tiger 800 to big bend national park in Feb to ride some dirt roads. will pirelli scorpion str be aggressive enough? or should I bring more aggressive tires with me?
  2. DirtyDog
    DirtyDog Omnia mea mecum porto Supporter
    Apr 27, 2007
    12,855
    Tulsa... it's OK
    BBNP is relatively mild terrain because it's all roads and no trails. The worst conditions you'd experience are possibly some deep, fine gravel or sand on River Road and maybe some loose rocky climbs on Black Gap Road, as far as I can recall. If you are confident on a typical 4x4 high-clearance desert road with your current tire choice, then you'll be fine.
    https://www.nps.gov/bibe/planyourvisit/maps.htm
    In short, knobby tires are not needed, but an offroad-biased DS tire will suffice.
  3. danptobin
    Jul 28, 2013
    718
    orange county,NY
    thanks
  4. terrascout
    terrascout Long timer
    Mar 30, 2009
    3,806
    NW Arkansas, Hills and Curves close at hand
    If you are riding from NY to TX to ride BB then you may want to look at one of the longer wear DS type tires like the Hiedenau, Mefo or Mitas large chevron like tires that can last 5000 miles if you are not into excessive rear tire slip on the pavement and or dirt. If you are trailering to TX buy what ever you like or what is cheap as some or the NWA inmates would suggest. :D Do you want an oil recommendation also?
    I have run the Pirelli Scrpn on a 990 to and on the jeep roads of Colorado and they worked fine. I just did not get as many mniles out of the rear tire as I did with the other three mentioned. Maybe I use less throttle as I age, or realize I am healing slower.
    lane01 likes this.
  5. danptobin
    Jul 28, 2013
    718
    orange county,NY
    terrascout having never been to big bend i dont know what the dirt roads are like. im ok with changing tires on a trip.
  6. c_m_shooter
    c_m_shooter Ninja Warrior Supporter
    Feb 25, 2009
    880
    Paradise, TX
    It will depend on the weather and if road graders have been down in awhile. Expect a bunch of deep gravel, some sand, some hardpack, and few rougher sections with baby head sized rocks and maybe a ledge or 2. I think knobbies would be a waste for 90% of it, assuming you can ride and aren't afraid of keeping a little momentum.
    The state park is much rougher and even more remote. Knobbies would be needed to get anywhere off the main access road. I would scout everything before attempting to ride a big bike over there.
    scarysharkface likes this.
  7. danptobin
    Jul 28, 2013
    718
    orange county,NY
    thanks
  8. Tigger's Toy
    Tigger's Toy Beast Rider Super Supporter
    Apr 18, 2012
    163
    The Woodlands, TX
    Mitas E07+
    I put them on my GSA recently and the performance on road is outstanding. My riding style is “normal” I would say. I’m a pilot by trade so I do my yankin-n-banking in the air not the pavement. Plus I live in N. Houston where it pays to ride smart and save that yankin-n-bankin for texting teenagers!!!
    #8
  9. flei
    flei cycletherapist
    Apr 1, 2013
    10,105
    Western Mass.
    IMO, if you ride your Tiger off pavement in NY with your scorpions and do ok, Big Bend National Park should not be a problem. other than some sand, the riding is not very technical compared to what we encounter off road here in the northeast.
    #9
  10. cagiva549
    cagiva549 whats a cagiva
    Oct 10, 2004
    6,644
    Cypress Tx
    I’ve ridden every road in the park on my 950 KTM with stock pirrelli scorpions and a whole lot of the ranch . I did run a terrorflex one time and roosted river road from one end to the other but the terror part showed itself when it was on pavement . Just stay on pavement if it’s wet . Nothing will work then .
    #10
    scarysharkface and Stephen like this.
  11. danptobin
    Jul 28, 2013
    718
    orange county,NY
    thanks the strs should get me there around there and back. id change tires when i get there if i had to the trail 2s i have on now are fine till i get to sand or mud then the bike is a real handfull. the strs do alot better on that and handle the roads really well. the shinko 804/806 could do the whole trip but arent as good on wet pavement or light snow which im likely to run into on my way there
    #11
  12. oughtsix
    oughtsix Reverse Engineer
    Oct 11, 2013
    535
    NELA
    Found this thread on a search. Planning a trip this spring with a friend, both on xrr type bikes, trailering over from LA.
    I’m planning to just spoon on a fresh k760 Trakmaster rear, a tire I dearly love.
    Any recommendations on a front? I realize the river road isn’t that hard, but I don’t have a lot of sand experience.
    #12
  13. c_m_shooter
    Feb 25, 2009
    880
    Paradise, TX
    On an XR the tires won't matter. With a little momentum street tires will get you through, knobbies will be a waste over 90% of the time.
    #13
  14. henrys
    henrys Been here awhile
    Nov 16, 2015
    216
    North Texas
    I'm really liking the new Dunlop trailmax 50/50. Really good all around tire.
    #14
  15. FlyGuy92
    FlyGuy92 n00b
    Dec 16, 2019
    5
    Houston
    Old Ore Road and River Road West offer the most difficult terrain in my opinion due to some softer sandy sections. The Pirelli STR's should be a good choice.
    #15
  16. danptobin
    Jul 28, 2013
    718
    orange county,NY
    got a set of the new battleax knobbies to cheap to pass up they seem good on my scrambler. may just keep my trail 2s on and keep it simple and not try anything that needs knobbies. my buddy cant get the time off so ill be riding solo
    leaving ny feb 2 probably take me 3 days riding to get there. the trail 2s will be more predictable if the weather is bad on the road
    #16
  17. sieg
    sieg Wearing out tires......2 at a time, day after day. Supporter
    Jul 9, 2008
    7,567
    Southern Illinois USA
    My wife and I be riding/camping in the area from February 11 to 23 if you're still there we can hook up.
    #17
  18. danptobin
    Jul 28, 2013
    718
    orange county,NY
    i need to be back in ny on the 15th
    #18
  19. crownhorse
    crownhorse Been here awhile
    Aug 21, 2008
    290
    cabot,ar
    sieg tom from loose nut ride wife and i will be there most of feb, maybe we can ride some, dine at the starlight
    #19
    sieg likes this.
  20. sieg
    Jul 9, 2008
    7,567
    Fursur. :-) We'll be at Maverick Ranch, I'll contact you when we get settled in.
    #20
    crownhorse likes this.
