Tool Tube?
Discussion in 'Equipment' started by wayno, Jun 13, 2008.
  1. jon_l
    jon_l Long timer
    Feb 8, 2008
    7,954
    Collingwood, Ontario
    Thanks for the feedback guys. I am pretty sure this is condensation, since it hasn't gotten wet for a couple months (Sept), but the temperature has dropped from highs in the 70s to lows in the upper 20s
    The entire inside was damp, but no water pooled.
    Pretty sure it is not a leak. The cap is angled up when parked so water can't get past the threads when on the sidestand, and the small drain hole is facing down and well sealed with silicone.
    I doubt the cap is air tight, so the pressure differential idea may have merit. And it usually lives in a cool garage, so rolling it out into the sun on a warm day would cause the black plastic to warm quickly while still having cool air inside.
    Exhaust doesn't get hot enough to bother the saddlebag 3/4" away on the plastic heat shield, so I don't think it could affect the tube a foot away, especially with air flowing over the bike.
    If it is condensation, I can't be the only one. Mine is mounted in a fairly exposed location, but I see photos of them on the back of panniers all the time, so hopefully guys who have them mounted can comment.
  2. jonnyc21
    jonnyc21 Trials Ninja
    Feb 8, 2011
    3,752
    Boise aria
    I pull my tools if the bike sits for a time because of the same thing. I found that plugging or not plugging it didn't seem to change my results much. Just my EXP.
    FYI: mine is mounted to the sub frame opisit to the pipe so not close by heat from the bike involved.
  3. wayno
    wayno Long timer
    Mar 14, 2004
    7,773
    East of KCMO
    Might unplug hole during storage or the desicant packs are cheap...or just take the lid of if stored inside....
  4. BigEasy
    BigEasy Fish Eyed Heathen
    Jun 23, 2007
    3,691
    South of Indy in the hills
  5. ben2go
    ben2go Long timer
    Jun 23, 2011
    7,522
    Gone
  6. NellieDriver
    NellieDriver Been here awhile
    Jan 26, 2011
    221
    Germany
    For german riders: does anyone of you know where to get a box like those (it seems they are owner's manual boxes ) in Germany? Maybe by internet.
    Weis jemand von euch wo man so etwas in D bekommen kann, am Besten über Internetversand.
    N.D.
  7. ben2go
    ben2go Long timer
    Jun 23, 2011
    7,522
    Gone
    Check with welding shops or welding suppliers,may be tool suppliers.They have tubes very similar but made for holding heavy arc welding rods.About 16 inches long(400mm to 450mm). Some maybe be bigger or smaller.
  8. NellieDriver
    Jan 26, 2011
    221
    Germany
    Thank you, I think I found something.
    ND
  9. Simonhantler
    Simonhantler waiheke simon
    Jun 11, 2013
    539
    Waiheke island New Zealand
    whats that pipe on your hp2?
  10. kenstone
    kenstone worn out
    Mar 3, 2013
    1,866
    Boysee
  11. Phil
    Phil ADV Rider
    Jan 20, 2011
    168
    Beauvechain, Belgium.
    kevin134 likes this.
  12. Mastery
    Mastery Mr. Funny Man
    Mar 25, 2011
    2,435
    Hoosier Daddy?
    For Americans...$5.99 plus shipping: LINK
    Goo Gone takes the yellow paint off easily.
  13. c-m
    c-m Long timer
    Apr 14, 2008
    1,177
    UK
    I bought one of the manual holder canisters. Turns out I can't mount it on my bike the way it's configured, so that sucks.
    Crash bars get in the way and the tabs are the pain. Will have to look for an alternative.
  14. k-moe
    k-moe Long timer
    Jun 27, 2012
    6,622
    44º W
    Cut the tabs off and use hose clamps around the body of the tube.
  15. 9Realms
    9Realms Drawn in by the complex plot
    Jul 23, 2010
    5,919
    Central Mn
    WD40 and a rag also takes off the yellow writing, I just cleaned it off the cap area. On my previous bike -a KLR, a tube fit nicely between the Motech rack and the frame on the non-exhaust side of the bike. It all but disappeared when the Pelicans were "docked" om the SW Motech racks.
  16. Antti
    Antti Been here awhile Supporter
    Mar 14, 2003
    469
    Finland
    Well, I wouldn't recommend this popular tooltube.
    I had mine in GS and it did last just a bit over a year.
    Dropped it yesterday.
    It was properly assembled from both ends. I have given some rough rides for the bike but still..
  17. c-m
    c-m Long timer
    Apr 14, 2008
    1,177
    UK
    Ah you used the tabs. They are flimsy rubbish. Use a P-Clip or Worm drive clip.
  18. geolpilot
    geolpilot Been here awhile
    Nov 3, 2011
    315
    Texas Coast
    I lost $100 worth of tolls Keebler pass Co. When the lid came off and it had a hose clamp over the lid threads!
  19. geolpilot
    Nov 3, 2011
    315
    Texas Coast
    Tools, not tolls.
  20. John Smallberries
    John Smallberries Long timer Super Supporter Supporter
    Aug 31, 2009
    2,019
    Northville, Michigan
    Here are mine on my little mule. These were the biggest ones available and fit .7l fuel bottles nicely.
