Tool Tube?
Discussion in 'Equipment' started by wayno, Jun 13, 2008.
  1. fhfr436
    fhfr436 Thirsting for ADV
    May 27, 2009
    164
    Suburb of Motown, Michigan
    Although it might seem like a good tool-storage tube, it's made to hold a paper booklet. The tabs just aren't made for what you (and so many others) are trying to do. The insulated P-clamps are a better route for a secure mounting.
    bomber60015 likes this.
  2. Antti
    Antti Been here awhile Supporter
    Mar 14, 2003
    469
    Finland
    Yep, i allready made a new one out of PVC drainpipe :)
  3. Phil
    Phil ADV Rider
    Jan 20, 2011
    168
    Beauvechain, Belgium.
    looks like a pair of rockets, but ... usefull lol (BTW, never opened during my Alps Tour recently done).
  4. kenstone
    kenstone worn out
    Mar 3, 2013
    1,866
    Boysee
    Why would anyone use something made to hold a booklet, to carry tools?
    How about something made to hold tools...to hold tools
    A tool tube from an ATV
    :lol3
  5. Jeff@TheQuadShop
    Jeff@TheQuadShop TAT survivor
    Nov 28, 2004
    7,513
    Crestwood, Kentucky
    Because it works (when mounted properly) and is very inexpensive.
    Phil likes this.
  6. kenstone
    kenstone worn out
    Mar 3, 2013
    1,866
    Boysee
    Yeh, if your going to cut off the mounting flanges and use/devise/engineer something else, why not start with welding rod holders, which are thicker plastic:dunno
    Those quad TOOL tubes are plug and play, thick/built to carry tools, with no cutting/designing/ or added mounting hardware to source/buy.
    That, and underneath panniers seems to be a great place to mount them :fpalm
    Put a couple of hundred dollars worth of essential tools into a thin/cheap plastic tube, then figure out a way to mount it, somewhere out of sight :confused
    jmo
    :lol3
  7. Jeff@TheQuadShop
    Nov 28, 2004
    7,513
    Crestwood, Kentucky
    I use the flanges to mount mine, it's been on there for about 6 years and still going strong.
  8. DaleE
    DaleE TransAlp Adv
    Jan 13, 2006
    736
    Boulder, CO
    ??? Link to a source ???
  9. Andrew
    Andrew Optimus Primer Super Moderator Super Supporter
    Sep 25, 2001
    22,992
    Eastbania
    I used a hacksaw to cut off the flanges, and carry the tube in my sidecase. It makes a neat organizer for the tools. That is all.
  10. kenstone
    kenstone worn out
    Mar 3, 2013
    1,866
    Boysee
  11. DaleE
    DaleE TransAlp Adv
    Jan 13, 2006
    736
    Boulder, CO
  12. Fordbailey
    Fordbailey Been here awhile
    Jul 4, 2014
    106
    Columbia County, New York
  13. Laconic
    Laconic Boomer Berserker Nativist Rube
    Sep 28, 2007
    27,509
    Moran Nation
    The gilding is off the lily!
    Use a welding rod tube or go the PVC route. I had a chance to get a couple of the document holders for free the other day and passed on them, too flimsy.
  14. portablevcb
    portablevcb Long timer
    Apr 25, 2015
    1,484
    nm usa
    I've had one full of tools on my bike for a while. Only two of the bolt holes used. It's only been on the bike for 20k road miles. No signs of cracking and it works nicely.
    Off road? I agree the mounting is probably not worthy. For that I'd get Al tubes and good solid mounts.
  15. MotoMigrant
    MotoMigrant Been here awhile
    Feb 12, 2009
    419
    Pittsburgh, Pennsylvania, USA or Celje, Slovenia
    Made a locking plug for my tool tube that only cost $10. The locking plugs you see online usually go for $30 for a 4". I'm outfitting 2 DR650s and each will have 2 so spending $120 for locking plugs was out of the question. Simple is better (maybe this has been done before but I didn't see it). Get plug for $7, drill a hole for an eye bolt,50cents (I even welded the gap), lock nut on the back, drill hole in wing nut, spray paint & add a lock.
    Sent from my SPH-L720 using Tapatalk
  16. UnclebudinTX
    UnclebudinTX Half Moose Whiskapalian TEX-LEX
    Jan 18, 2011
    425
    Plainview TX
    I like your idea but when someone sees that lock they are going to think some valuble is in there and maybe give them the idea to break in.. iv never.had a problem wiyh any body messing with my bike.. do i lock up my cases hell yes.. do i chain my helmet to my bike.. no.
  17. BiGR Rich
    BiGR Rich Been here awhile
    Dec 8, 2011
    684
    Kgm, how long have you had that lock? I had a pair of those on a some hard bags for a couple months before one crapped out. The numbered rollers were getting tougher to spin, and one day I unlocked it and it wouldn't shut again. My best guess was the combination reset itself when it was open. Didn't trust it after that.
  18. MotoMigrant
    Feb 12, 2009
    419
    I'm heading to central america (Panama and back) for 2 months. I'll be locking my helmet ;)
    I can agree with the thought process of just keeping it shut without a lock. If someone wants in, they will get in anyways. But at least this is kinda low key but also a little tamper proof. I'll let you know in April, lol
  19. MotoMigrant
    Feb 12, 2009
    419
    Hmm, had these a couple years but I could see that happening. I just made this and put the lock on, it will have to be on road testing...
  20. RTinNC
    RTinNC Long timer
    Mar 21, 2002
    1,505
    Charlotte, NC
    Do you use those plugs in the normal tool tube? Or did you make your own tube? Like the locking idea!
