Torque Wrenches
Discussion in 'Equipment' started by TedyDarwin, Oct 29, 2018.
  1. TedyDarwin
    TedyDarwin Been here awhile
    Jun 5, 2015
    127
    Salt Lake City, Utah
    Was wondering if anyone has any recommendations for torque wrenches. I have been researching them a bit and found most of them are for automotive and have very high torque specs. So I found some made for bicycles that look quite good. They are from Park Tools and look to have 90% of the torque specs for the repairs/adjustments I would make at home.
    These are what I found:
    Park Tools TW 5.2 (2-14 nm)
    https://www.amazon.com/Park-Tool-TW...F8&qid=1540825986&sr=8-4&keywords=park+torque
    Park Tools TW 6 (10-60 nm)
    https://www.amazon.com/Park-Tool-Ra...F8&qid=1540826914&sr=8-9&keywords=park+torque
    I want to buy good quality torque wrenches because I know torque specs are important. Does anyone use any that they would recommend that fall within the torque specs of the water-cooled R1200GS?
  2. TUCKERS
    TUCKERS the famous james
    Dec 23, 2005
    19,640
    Villa Maria Sanitarium, Claremont, CA. USA
    You need two. Footpounds and inch pounds.
  3. wakdady
    wakdady Adventurer
    Apr 19, 2010
    26
    get a snap on 3/8 digital torque wrench. goes from 5ft/lbs to 100. will display, NM, ft/lb, in/lb.
    atech2fr100b is the model I have and it's wonderful.
  4. henrys
    henrys Been here awhile
    Nov 16, 2015
    205
    North Texas
    You really want 3... 1/4 (in-lb), 3/8 and 1/2 drive
  5. lewisjr1
    lewisjr1 Long timer Supporter
    Sep 26, 2008
    4,884
    DC metro
    Even when I got paid to work on Bimmers, I didn't have that much money sunk into a torque wrench; special tools, sure, but not everyday items. Were I to step up to that plate, FACOM would be my brand of choice, and I'd still save a couple of hundred bucks.
    There's nothing wrong with the Park Tools brand that OP inquired about, though the addition of their blue paint is pretty expensive. Honestly, were it me who was building a tool set for a GS, I'd likely go with the alternative model listed on that Amazon web pg. for the 10-60nm wrench.
    There's nothing magical about these wrenches. You need a good one, but it doesn't have to be great. The 3/8" drive it definitely the size to go with for one's first wrench to be applied to a motorcycle, or a car. I own a 1/4" torque set, but it's been used fewer than a dozen times on my bikes. And 1/2" torque wrenches aren't required very often on a bike, at least not outside of major component repair.
  6. PaulBarton
    PaulBarton Long timer Supporter
    Apr 14, 2015
    1,567
    Seattle
    Craftsman used to have some quality ones in the three sizes you need (listed above). At Christmas each year they would go on sale. For about $150 you could get all three. I'm sure I have the craftsman part numbers somewhere but I don't know that they exist in that iteration anymore. I know that Sears sold off the Craftsman name.
  7. yaycep
    yaycep Been here awhile
    Jun 9, 2014
    444
    Freiburg, Germany
    The range (roughly) between 15Nm and 100Nm would cover almost all your needs, there are usually 3/8” wrenches for that. Smaller bolts are not load bearing and not so critical, and there’s only a couple larger ones that you normally do not touch.
  8. AdamChandler
    AdamChandler Ascending n00b Supporter
    Feb 29, 2016
    6,247
    Hanover, NH USA
    CDI and Snap-On are the same company if you're looking to compare prices.
    #8
  9. GSBruce
    GSBruce Been here awhile
    May 3, 2011
    318
    The Woodlands, Texas
    I have the little Park Tools torque wrench you reference and a 1/4” and a 3/8” Proxxon. I have a Harbor Freight 1/2” I only use on lugnuts. I need a quality 1/2”, I’ll probably get a Proxxon.
    #9
  10. Jim Moore
    Jim Moore Souped-Up Weasel
    Dec 24, 2001
    33,819
    Jax, FL
    I have a Tekton that I really like for big things.
    #10
    appliance57 likes this.
  11. Friz Freleng
    Friz Freleng Religious zealot Supporter
    Jul 23, 2008
    1,424
    North SF Bay Area
    My question: where do you go to get your torque wrenched calibrated? After years of use I wonder if mine are out of spec.
    #11
  12. tzracer
    tzracer Been here awhile Supporter
    Dec 30, 2011
    190
    SE Wisconsin
    In the past I took my Snap-On to the repair center not far from my house. Calibrated while I waited. Not sure if they still do that.
    Otherwise I have to locate a Snap-On distributor and give it to them. Last time I checked, it was no charge.
    There are places that will calibrate them (if they can be), try the phone book.
    #12
  13. TUCKERS
    Dec 23, 2005
    19,640
    You need up to 120 and down to 2 (spokes)
    #13
  14. TUCKERS
    Dec 23, 2005
    19,640
    The 3/8 Harbor Freight is guaranteed for life.
    #14
  15. usgser
    usgser Long timer
    Nov 6, 2005
    3,549
    Westside WA
    +1
    All torque wrenches are only accurate mid-range of their rated spec. You'll want a 3/8" drive in in-lbs and a 1/2" drive in ft-lbs. If accuracy is important (it should be) one size does not fit all.
    #15
  16. dpike
    dpike BeeKeeper Supporter
    Nov 21, 2015
    1,625
    New Jersey
    #16
  17. toramorgan
    toramorgan Adventurer
    Aug 30, 2018
    40
    Barcelona
  18. rkover1
    rkover1 doc
    Apr 22, 2006
    422
    Moku o Keawe, USA
    For my non-USA bikes (BMWs and Yamaha), I wanted something that would read directly in Nm, not some conversion from ft-ib. So I have Proxxons: 1/4" (5-30 Nm) and 3/8" (20-100 Nm) drive. Use them both. A lot. Just remember to loosen the knob at the end all the way when you're not using them.
    doc
    #18
    ultane likes this.
  19. foxtrapper
    foxtrapper Long timer
    Sep 6, 2011
    4,064
    The Harbor Freight click type torque wrenches work remarkably well. They are accurate and consistent. Number of reviews and studies on them showing this, not just me babbling it. On sale, you can buy all three sizes (1/2, 3/8, 1/4) for less than most stores charge for one.
    #19
    worwig likes this.
  20. worwig
    worwig Long timer
    Nov 30, 2009
    1,947
    Hog Mountain
    Get a cheap beam type. If the needle points to zero unloaded, it is calibrated.
    We used to use 'clicker' types in our factory. Those were often out of calibration when checked. I suspect due to them being used 24/7, so they were never 'stored' unloaded.
    #20
