Toyota Tundra Tires
Discussion in 'The Garage' started by ozmoses, Aug 10, 2019.
  1. ozmoses
    ozmoses Contrary
    Jul 3, 2009
    37,706
    USA??
    Load range E.
    What are you running? :ear
  2. muddywater
    muddywater Untermenschen
    Oct 1, 2007
    2,854
    East TN
    Not a Tundra, but I currently run LT tires rather than P Tires on my half ton Chevy.
    Most of the LT tires are either D or E rated....mine are E rated (I had to look).
    My 3/4 ton Ford has an E rated tire.
    Heavier side walls, can really feel the difference towing.
    Fewer flats.... every set of P/passenger tires has been plagued with flats (job site related).
    LT tires ride rougher and seem more skiddish on wet roads. I drop my 3/4 ton from the recommended 75 psi to 50 psi in the rear if going on an extended run while empty.
  3. ozmoses
    ozmoses Contrary
    Jul 3, 2009
    37,706
    USA??
    I've always run E rated on both 1/2 and 3/4 ton work pickups and vans,for obvious reasons.
    This truck came with P metrics in 255/70/R18- a size for which there is no LT, E range, tire available, therefore my question.
    E range choices are plentiful in the 275/65/R18 size.
    The difference is just over 3/4" in width which should not present a clearance issue.
  4. r1150r
    r1150r Out standing in my field
    Aug 1, 2004
    1,171
    The Woodlands, Texas
    Trying to educate myself on load range vs load index. LI is what is shown on the link and indicates a max inflation pressure @ 80 psi...which seems(?) to correlate to load range E?
    I've always mounted Michelin LTX on my Tundra and other vehicles if the LTX is offered.
    https://www.discounttire.com/buy-tires/michelin-defender-ltx-m-s
  5. RonKZ650
    RonKZ650 Been here awhile
    Jun 11, 2009
    913
    Lakewood, CO
    Most Tundra run p tires as you are most likely never carrying anything with the 4ft bed they all have. Load range E for 3/4t or 1t trucks. Doesn't hurt I suppose though to run them, but ride will suffer, and that is more important than load rating obviously for most that own a Tundra.
  6. Hollywood D
    Hollywood D Been here awhile
    May 24, 2018
    239
    Colorado
    I have BFG KO2 right now. They’re okay but wearing funny. I have about 9k left in them and probably won’t buy them again. Everyone around here runs duratracs on their trucks.
  7. ozmoses
    ozmoses Contrary
    Jul 3, 2009
    37,706
    USA??
    My Chevy Express 2500 came with the Michelin LTX; I swapped them out pretty quickly for a set of Cooper Discoverer ATs which I did not care for very much.
    The LTX was not great on the dirt roads and farm roads where I was spending most of my time, but was great on pavement and gives good mileage as I understand.
    I have an 8' bed.
    And carry/tow shit regularly.
    I've found BFGs last well to a point, then wear very quickly and lose traction; great when new,though.
    Currently, I am leaning toward the Continental TerrainContact A/T:
    https://www.tirerack.com/tires/tires.jsp?tireMake=Continental&tireModel=TerrainContact+A/T&partnum=765SR8TCATOWL&vehicleSearch=false&fromCompare1=yes
  8. tvpierce
    tvpierce Been here awhile
    Sep 5, 2011
    890
    Maine
    The Tundra isn't offered with a 4' bed. I don't even think there's a Tacoma with a 4' bed.:dunno
    #8
  9. GabeHanson
    GabeHanson GabeHanson
    Sep 3, 2012
    87
    Corpus Christi
    FEE7C122-9E4A-42B0-AF36-72C125D55570.jpeg I’m running C rated Nitto Ridge Grapplers on my 2018 Tundra. They started quiet but have gotten a bit noisy over the last few thousand miles
    Excellent traction and are wearing nice though
    285/75/17
    They also ride nice, was worried the 10 ply of the E rated would make it ride too rough
    #9
    bmw345 likes this.
  10. tominboise
    tominboise Long timer
    Jun 17, 2007
    3,008
    Boise, ID
    2008 Landcruiser here - running Hankook Dynapro M/T in E rating. 285/70R17 size. Work great in rocks, mud and on the street. Not too noisy so far.
    #10
  11. kantuckid
    kantuckid Long timer
    Nov 29, 2007
    9,083
    Kentucky-Eastern that is!
    Ford F-150 the main, most common tire size is the 275R75-18. My OEM set of GY's has 59k on them and still well with-in TWI's but I have a set of 116T load rating Michelin LTX M/S tires to go on next. I really don't tow very heavy RV trailer but just what I decided to use. On 4 new Tundras I never went past the first set except for one truck. In that size tire your getting enough width IMO w/o going to a lower height tire. I like clearance.
    #11
  12. ozmoses
    ozmoses Contrary
    Jul 3, 2009
    37,706
    USA??
    You've got 17s ??
    #12
  13. GabeHanson
    Sep 3, 2012
    87
    Corpus Christi
    Yessir!
    #13
  14. bmw345
    bmw345 Adventurer
    Nov 12, 2017
    39
    Connecticut
    Running E rated Nitto Terra Grapplers G2's 285/50-22 for the summer. Seem to be wearing pretty well. Run them at 40psi.
    #14
  15. ozmoses
    ozmoses Contrary
    Jul 3, 2009
    37,706
    USA??
    #15
  16. ozmoses
    ozmoses Contrary
    Jul 3, 2009
    37,706
    USA??
    Whoa! That's an aggressive tire.
    I always liked Hankooks on my VWs.
    #16
  17. tominboise
    Jun 17, 2007
    3,008
    Boise, ID
    Here's a shot of the Dynapros from Moab this spring....
    #17
  18. Stasher1
    Stasher1 Been here awhile
    Jul 24, 2013
    560
    Lilburn, GA
    I'm running 275/70/18 Hankook Dynapro ATM on my Tundra. Not as aggressive as the MT, but definitely not a passenger car tire.
    The slightly larger diameter helped fill the fender wells a bit better and fixed my speedo error.
    #18
  19. ozmoses
    ozmoses Contrary
    Jul 3, 2009
    37,706
    USA??
    Oh man, I miss Moab !!!
    #19
  20. ozmoses
    ozmoses Contrary
    Jul 3, 2009
    37,706
    USA??
    Was gonna say, I see them closest in 285/65/18 which is almost 1 1/4" wider than stock for me.
    #20
