.TPX files on a Garmin 60CSx
Discussion in 'GPS 101 - Which GPS For Me' started by BLUEThunder, Sep 29, 2014.
  1. BLUEThunder
    BLUEThunder Ride on!
    Jan 19, 2008
    526
    Shenandoah Valley, VA
    Ok intelligent inmates :norton....question for the geekiest of the geeks...
    I have a Garmin 60CSx on which I have loaded and successfully used .gpx files as routes.
    I have Delormes Topo North America program on my laptop that I can create routes on however they are .tpx files.
    Does anyone know if the Garmin I have will load and run a .tpx file???
    I know the first response is why don't you just try to load it and see...but the simple answer to that is that my son currently has the GPS and he is located four hours away, or I would have done that.
    I figure there are likely a few intelligent individuals out there that could tell me right off the top of their heads.
    Any ideas?
  2. BLUEThunder
    Jan 19, 2008
    526
    So, I also have MapSource on my laptop. It's version 6.16.3. I have multiple routes that others have created on that software (.gpx files). However, for some dumb reason the version I have does NOT show ANY back roads and certainly not any Forest Service roads. Others I know who have that software do show FS roads and such on theirs. Any ideas on that?
    I was going to try to create my route on there since it makes a .gpx file...but it doesn't show the roads I need. I opened one .gpx file that I got from someone on the Blue Ridge Trail for example...it opens in my software and you can see the route but it's in the middle of nowhere on my map...like not on roads...where in reality it is.
    Do I have messed up software? Why doesn't it show mountain roads like others cleary do? Are the backroads possibly a layer that I have off?
  3. mcnut
    mcnut Long timer
    Apr 26, 2006
    1,757
    Bakersfield CA
    In response to the first post;
    GPSBable is the most comprehensive GPS format converter I know of and it is free/shareware. If GPSBable doesn't do it likely nothing will.
    Delormes Topo North America doesn't allow saving as .gpx?
    As to the second;
    What maps do you own and have installed in MapSource? MapSource itself does not contain detailed maps. You can buy maps or explore the open source maps. Also be sure the detail setting in MS is set to High.
    Bruce
  4. Countdown
    Countdown Long timer
    Oct 20, 2003
    6,933
    Carson City/Ridgecrest
  5. Countdown
    Oct 20, 2003
    6,933
  6. TRZ Charlie
    TRZ Charlie That's MR. Asshole
    Nov 13, 2008
    20,770
    Tucson, Arizona
    Jerry,
    This doesn't involve the OP's questions but I have one for you. I have Roads n Recreation but it is 32 bit. My Samsung Kronos is 64 bit. I can view the RnR maps, use it within Mapsource. I can plan a track, mark waypoints and other normal functions using RnR however, it will not load onto the Chronos as a permanent installation. Any thoughts on this? Perhaps you have heard of this happening? Maybe a work around other than booting from the disc all the time?
    Thanks in advance, and OP...sorry for hijacking your thread.
  7. Countdown
    Oct 20, 2003
    6,933
    Don't exactly understand question.
    Are you just using R&R from the disc? And it is not installed?
    There is a thread and it is on my web site on how to install R&R. If you already tired to install it form Disc, you may have to uninstall.
    Short story you copy complete R&R disc to hard drive then go to hard drive and install R&R from there.
  8. BLUEThunder
    Jan 19, 2008
    526
    With all due respect I have to differ. I did load (possibly wrong terminoligy) or copy a .gpx file to my 60 for the Blue Ridge Trail. I was able to see the route (or track, whatever) on the screen and successfully follow it. I am not looking to load a route for turn by turn directions but simply for "breadcrumbs" to follow through a confusing area.
    I do have City Nav for the 60 and use it occasionally and also have a Topo USA card that I use more. It is very helpful...Just sometime the Topo card has TO many details on it when you are trying to navigate on the dirt bike...with all of the contour lines and the small display it's very cluttered.
    Thanks for the advice guys...I need to check my resolution (details) on Map Source and make sure it's set to high.
    Thanks again.
    #8
  9. BLUEThunder
    Jan 19, 2008
    526
    Not a problem man! We're all on here to learn, :y0!:scratch
    #9
  10. Countdown
    Oct 20, 2003
    6,933
    With all due respect, you will get much better help if you use the correct terms. Anyone helping knows that when you use "breadcrumbs" you really mean Tracks, but when you use the word Routes, we all think you are talking about Routes (not Tracks). Routes and Tracks are two very different things.
    In fact, you did not load or copy any .gpx file to your 60 you downloaded data from MapSource, .gpx had nothing to do with anything.
    Yes like you, very few riders use topo while riding for the reason you found, topo is very useful in MapSource on your PC but since you only have it on data card, that is not an option.
    City Nav should show you most small roads on your GPS and in Mapsource (Detail set to "Highest" in Mapsource and "Most" on 60). Do you have it on PC and GPS?
    I actually prefer the old Roads & Rec map and it shows all know forest roads and trails back in the 80's. It may be worth your time to try to find an old copy on e-bay.
    You may want to check out my GPS setup tips for the 60 on my web site DualSportWest.com
    Back to your first question: Is your real question "How can I get Mapsource to open a .tpx (or other) files to download the data to my 60?"
    The answer is NO, Mapsource will only open .gdb (prefered) and .gpx. However as stated, there are programs like GPS Babble that will convert other file formats to .gpx.
    #10
