TR200 fatcat
Discussion in 'Thumpers' started by rmhrc628, Aug 19, 2010.
  1. Six4Sure
    Six4Sure n00b
    Jul 2, 2017
    3
    First post!
    Evening, yesterday I picked up a 1986 Fat Cat. I live in Southern New Mexico, so we really dont deal with a lot of rust! Just sun baked plastics. But this Cat was decently maintained. Most importantly is I have the title for it and it came with a Factory Service Manual. Last week I missed out on a 250R Honda 3 wheeler, now im thankful, this popped up yesterday!
    Its definetly been ridden for 30 years, but its in decent enough condition. The only real concern to me is the tires, they are cracking. Any go to tires I should be looking at. Being the desert we deal with a lot of sand.
    Broken link fixed
  2. XRHondafan
    XRHondafan Long timer
    Oct 29, 2016
    1,271
    Anyone fitted a better carb to the cat? I know it has a fixed manifold but that could be modded.
    What is standard carb size and how large could you go?
  3. Six4Sure
    Six4Sure n00b
    Jul 2, 2017
    3
    The Book has it as a PD69A
    venturi diameter 24mm
    XRHondafan likes this.
  4. Jeff@TheQuadShop
    Jeff@TheQuadShop TAT survivor
    Nov 28, 2004
    7,115
    Crestwood, Kentucky
    What's wrong with the stock one?
  5. XRHondafan
    Oct 29, 2016
    1,271
    So would a fcrmx from a crf150r make much difference ?
  6. XRHondafan
    Oct 29, 2016
    1,271
    Just bought two of these tyres
  7. cappt
    cappt Been here awhile
    Oct 21, 2014
    201
    Nevada
    So photobucket wants 399$ to link my pics on third party sites now? Yeah that's not happening.
  8. XRHondafan
    Oct 29, 2016
    1,271
    Cheaper to buy two new tyres!!!
  9. XRHondafan
    Oct 29, 2016
    1,271
    New Cheng shin c832s
    They are quite a square profile but with air I guess will balloon out
  10. Six4Sure
    Six4Sure n00b
    Jul 2, 2017
    3
    Those look good! What sizes did you order?
  11. XRHondafan
    Oct 29, 2016
    1,271
    Brand new plug 5 mins of running
    Do think it’s rich?
    Carb rebuild time ??
  12. cappt
    Oct 21, 2014
    201
    Nevada
    I would take the carb apart and give it a good clean out, make sure all the little passages are clean and clean the jets. Make sure the float is not hanging up. Depending on the condition it might need a rebuild. Clean out the air filter or replace.
  13. XRHondafan
    Oct 29, 2016
    1,271
    Capt
    Guess what I pulled the needle jet holder and no needle jet!!!
    The needle jet was not in the carb!!
    Just the main jet and needle jet holder (which the main jet screws into)
    So now I search for a needle jet for a 30 year old bike - anyone got one that fits?
  14. cappt
    Oct 21, 2014
    201
    Nevada
    Are you sure it's not stuck in there, they don't usually fall out, need to poke it down or tap with a small wood dowel.
  15. XRHondafan
    Oct 29, 2016
    1,271
    How would I tell?
  16. cappt
    Oct 21, 2014
    201
    Nevada
    You can see it, that small brass piece.
  17. cappt
    Oct 21, 2014
    201
    Nevada
    Tap it out from the slide side. It's very soft so use wood or plastic.
    To give the carb a good clean out remove jets and holders, remove air screw, remove float needle.
    Spray out the carb with cleaner and compressed air, every passage should spray through and come out somewhere else.
    Use a old toothbrush on the jets and jet holders to clean out every little passage.
    Reassemble and ride.
    Use a inline gas filter to prevent tank dirt from the carb.
  18. XRHondafan
    Oct 29, 2016
    1,271
    Is it press fit or lose in there?
  19. XRHondafan
    Oct 29, 2016
    1,271
    What about an ultrasonic clean?
    Is that best?
  20. cappt
    Oct 21, 2014
    201
    Nevada
    Slightly pressed in. It should tap out with just light taps.
    It's not imperative that you remove that piece to clean it. Just spray it out real good.
