Trailer ID request
Discussion in 'Equipment' started by Maxwell00, Jul 1, 2020.
  1. Maxwell00
    Maxwell00 Adventurer
    May 7, 2020
    35
    Cleveland, OH
    Any ideas? Looks like a 4’ basic utility trailer with a front wheel bump out. Never seen anything similar.
  2. Stasher1
    Stasher1 Been here awhile
    Jul 24, 2013
    648
    Lilburn, GA
    Looks like a modified cheapo from Harbor Freight, Northern Tool, or one of the big-box hardware stores.
    katbeanz likes this.
  3. katbeanz
    katbeanz earthbound misfit, I Supporter
    Feb 12, 2005
    10,210
    Kansas City
    • I just bought a used one, six trips to dmv to tag a 4x6 $300 trailer. :fpalm They're about $600 new at local farm/ranch supply chain. Tilt bed geometry isn't correct for utility quad but it's low enough to drive on. I may do similar to your photo to take big bike in for 24mo service. Weight is around 300lbs empty, 2000# GVWR, easy to shove around, 4x12 tires + 1-7//8 ball :puke1, may mount a flag to verify it's still back there empty. PITA to back, by the time you see in mirror about two degrees and 6ft from jack knifing. :lol3 49" inside width.
    • I thought of making wood sides for a floorless popup tent or covered wagon, angle iron's pretty light, 2"x2"x1/8" thick. You could cut the front rail and make a bolted removable section, add a bike chock to a plank or bolted construction same shape as your picture if not a welder.
    https://www.orschelnfarmhome.com/au...rs/trailers/4-x-6-tilt-trailer-101306831.html
  4. PineyMountainRacing
    PineyMountainRacing Oops....
    Jul 2, 2008
    5,910
    Sarasota, FL / Sylva, NC
    maybe the trailer originally didn’t have enough tongue weight and swayed back and forth going down the road. looks like a pretty good idea to me for a small light trailer.
