Trans-America Trail Prep
Discussion in 'Americas' started by jcbr6, Jan 19, 2014.
  1. Bajaexplorer
    Bajaexplorer Alien
    Jan 26, 2014
    66
    Earth
    Found one link on adv, but it was broke.
    Other links I found on web just did not give the information that I thought should have been there.
    Meaning current temp, snow buildup, etc.
    I will look some more when i get a chance, gota get back to work right now.
    Found this one. Maybe they will start updating again when spring gets here.
    BushDucks Passes
    Seems like there should be a web site updated daily.
    #41
  2. FBR
    FBR Long timer
    Jul 9, 2013
    1,366
    Southern WI
    From what I have read, the stator and clutch basket bolts should all be locktitghted on the DRZ. I have taken out, cleaned, locktighted, and reinstalled just about every bolt on my bike. I used the medium grade (blue). It was also a great way to find what tools I could need on the trail. I only use the tools I picked out to take now when I do anything to the bike. The list is a lot smaller than I thought it would be. The stock kit will do 95% of what you will need, but I added a few tools (wire strippers, vise grips, allen wrenches, etc).
    I am doing the TAT on a DRZ as well, at the end of June in hopes that the passes are open.
    Good luck, maybe we will see ya out there!
    #42
  3. One Less Harley
    One Less Harley OH.THAT'S GONNA HURT
    Nov 16, 2006
    6,762
    Bowling Green, Ky
    never heard that about the clutch basket.....bring some bailing wire and zip ties, along with some common nuts and bolts.
    #43
  4. Bajaexplorer
    Bajaexplorer Alien
    Jan 26, 2014
    66
    Earth
    This one might be what was talked about before.
    This link came from advrider, posted by (well cant find the thread now).
    http://weatherspark.com/#!dashboard;ws=29941
    #44
  5. TRZ Charlie
    TRZ Charlie That's MR. Asshole
    Nov 13, 2008
    21,062
    Tucson, Arizona
    My 2000 Drz went through 5 stators in five years.
    #45
  6. jcbr6
    jcbr6 Adventurer
    Apr 19, 2007
    67
    md
    Has anyone had these bolts come loose and cause damage? Or is this just done during normal inspection?
    #46
  7. FBR
    FBR Long timer
    Jul 9, 2013
    1,366
    Southern WI
    Yes, they come loose and if they fall out cause a lot of damage. When I checked mine everything was tight, but I only had 400 miles on it. Sounds like it is a fairly common problem. Only took an hour of work for piece of mind. I think I read about it on ThumperTalk.
    #47
  8. wbbnm
    wbbnm Long timer
    Dec 18, 2007
    6,626
    MN and NM
    Sounds like my old BSA Victor 441. The stator was located next to the primary drive chain and small metal flakes would imbed in the stator and damage it. At least that was the conventional wisdom at the time.
    #48
  9. One Less Harley
    Nov 16, 2006
    6,762
    Bowling Green, Ky
    I've had two stators crap out in 3 years. I would buy a new one from Ricky Stator and put it in before the trip......I added a kick start but haven't had any luck starting it with it well when the bike is cold.
    always lock tight the stator not needed for the clutch basket.
    #49
  10. Dark Helmet
    Dark Helmet Go to ludicrous speed!
    Nov 22, 2006
    977
    You'll know when I know...
    Like a number of you I am hitting the TAT this year solo. One item I have decided to take with me is what Bestrest calls a motorcycle recovery system. It's basically pulley system to help pull your bike out of deep mud, over unclimbable obstacles, or getting your bike on the trail should you take a little unplanned detour. Looks like a good piece of insurance for a solo rider..
    I had the misfortune of having my third gear explode last year and totaling my tranny and one of the cases on my 2001DRZ. Knowing I was going to do the TAT this year I took the time while the bike was apart to lube every bearing/pivot, put on new radiator hoses and check every piece on the inside of the engine. Also did all the locktite fixes. Certainly something can still go wrong and I am thinking about a stator replacement JIC.
    Good thread, thanks for all the insights. Here is a great weather trip planning site that has helped better pick my start date of August 1. http://weatherspark.com/#!dashboard;ws=29941
    DH
    #50
  11. Bajaexplorer
    Bajaexplorer Alien
    Jan 26, 2014
    66
    Earth
    I am thinking about taking a big game lift. Weight ratio is better as multi-loop pulley.
    Can't find them now, but the snatch blocks were only about 3in width, with something like 4/1 lift ratio.
    edit - I know why I can't find them, 40 years ago seem like just last week.
    #51
  12. FBR
    FBR Long timer
    Jul 9, 2013
    1,366
    Southern WI
    Just wondering, are you guys running some aux stuff (hand warmers, chargers, etc) that is burning these out, or just junk stators? Its looking like I better start looking into a aftermarket set up.
    #52
  13. Dark Helmet
    Nov 22, 2006
    977
    I will have to check that out. The one from Bestrest I am modeling after is a Z-rig 2 pulley system that reduces weight by 2/3. Link here: http://www.bestrestproducts.com/p-340-motorcycle-recovery-system-mrs.aspx
    Weight, a big consideration, is about 2.5 lbs.
    #53
  14. Dark Helmet
    Nov 22, 2006
    977
    Thought I would list my DRZ mods for the TAT. In addition to having rebuild my engine as mentioned earlier, I put in new rings, new radiator hoses, locktite fixes. Lubed all bearings and pivots.
    -new chain
    -rear shock rebuild with Goldvalve and heavier spring for increased gear
    -changed fork oil
    -Racetech fork springs
    -Seatconcepts seat for those long days
    -Trailtech Vapor computer. Need a much more accurate odometer than stock for roll charts. Also has Tach and radiator temp light
    -Trailtech lighting kit for improvement over stock lighting (between light and computer reduced front end weight 2.5 lbs.)
    -Highway Dirt Bikes handguards
    -Giant Loop tank bag
    -Spot GPS locator
    -emergency rescue insurance through Spot (Pretty good deal, covers two Emergency rescue costs per year, $50k coverage per. ~$17/yr)
    -Happy Trails pannier racks
    -Wolfman Expedition panniers
    -Ortlieb large duffel
    -bike already had full Yosh exhaust and 3x3 mod and jetting
    -bike retrieval system mentioned in above post
    -Zumo 550
    -Roll chart holder
    DH
    #54
  15. jcbr6
    jcbr6 Adventurer
    Apr 19, 2007
    67
    md
    sounds like a good setup.
    #55
  16. One Less Harley
    Nov 16, 2006
    6,762
    Bowling Green, Ky
    hum, didn't know about the insurance offering by Spot...that's a good deal.
    Hope you have a steel rear sprocket....
    BTW- the stock DRZ ODO is pretty darn accurate...speedo not so.....at least mine was. Easily adjust up and down to.
    heated grips are nice to have...not a necessity..but nice to have.
    #56
  17. jcbr6
    jcbr6 Adventurer
    Apr 19, 2007
    67
    md
    Got some work done on the DR.
    Made a tool container to fit on the tail section.
    checked and lubed the steering bearings.
    They needed grease. There was only a thin coat.
    Checked and lubed the swing arm bearings. Also noticed the bearings in the shock linkage needed attention also.
    Lubed all locations and going back together.
    PennADV365 stopped over with his DRz400, Going to make another rack for the back of his bike. (similar to mine)[​IMG]
    #57
  18. jcbr6
    jcbr6 Adventurer
    Apr 19, 2007
    67
    md
    Did you ever check what your stator output was ?
    Did you ever check what the current draw was with all electrical components on?
    I havent done the "free power" mod yet, but thinking of doing it before the trip.
    #58
  19. One Less Harley
    Nov 16, 2006
    6,762
    Bowling Green, Ky
    I only added 3 electric items, the heated grips, gps and ONE led light for the high beam. I can turn off the head light when using heated grips at low rpm. just wired a switch to the head light ground.
    If you're only running a GPS off the battery don't worry about the drain, but would add a volt meter. The new stator I put in before starting the TAT wasn't quite up to snuf on my way home from the TAT. It supplied enough volts, but was replaced AGAIN after I got home. Was putting out 12.7 volts.
    My extra LED light only comes on w/ the high beam.
    monitored voltage with an idiot light. The $28 one
    #59
  20. jcbr6
    jcbr6 Adventurer
    Apr 19, 2007
    67
    md
    How much draw did the extra led light have?
    #60
