TransAlp Valve Clearance Adjustment Procedure
Discussion in 'Japanese polycylindered adventure bikes' started by Palak, Sep 29, 2010.
  1. Palak
    Palak Adventurer
    Dec 1, 2009
    93
    I own a 1990 Honda Trans Alp XL600V. I checked and adjusted the valve clearances for the first time a month back. Thought I would post the procedure, together with my thoughts, recommendations, and experiences, for others out there that have this or a similar bike. I know I use search engines a lot to find out how to work on my bike, and advrider comes up pretty often on the searches. Hopefully someone out there will find this helpful.<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:eek:ffice:eek:ffice" /><o:p></o:p>
    <o:p></o:p>
    I combined the instructions shown in the Honda Service Manual with the Haynes Manual, for what should be a complete and thorough description of the procedure. I have also added my and others&#8217; comments in italics, and have posted a few pictures below.<o:p></o:p>
    <o:p></o:p>
    <o:p></o:p>
    Valve Clearance Procedure for TransAlp Motorcycle<o:p></o:p>
    <o:p></o:p>
    Equipment needed:<o:p></o:p>
    • Wrench 10x12mm for turning the lock nuts. An offset spanner or boxwrench is helpful, but is not required. <o:p></o:p>
    • Valve clearance adjusting wrench to adjust and hold the adjusting screw. A crescent, spanner, box wrench, or even needle nose pliers may also be used. I used needle nose pliers, and they worked serviceably. A really handy DIY tool would be an adjusting wrench made out of 1/8&#8221; strap steel, and with the right size slot cut into it. Holding the adjusting screw is probably the most fiddly task involved in adjusting valve clearances. The clearances are very sensitive to minute movements in the adjusting screw. If you can&#8217;t hold the adjusting screw perfectly immobile while tightening the lock nut down, you will have to redo the procedure.<o:p></o:p>
    • 17mm socket for turning the flywheel. A normal depth socket worked fine for me.<o:p></o:p>
    • 10mm allen wrench for opening the crankcase hole cap.<o:p></o:p>
    • 24mm box/spanner wrench. This was also a very critical item. I thought I could get away with using a crescent wrench. However, the front exhaust valve port has very restricted access, and you almost have to have a 24mm wrench. Luckily, the neighbor came through for me here and saved me a trip to the autoparts store.<o:p></o:p>
    • Feeler gauges. At a minimum, need 0.15mm (clearance for intake valves), and 0.20mm (clearance for exhaust valves.) I got two cheap sets at Harbor Freight (about $2.50 per set.) I confirmed with a micrometer that the gauges read true to their stampings (they did). Using a bench vise, I bent the ends into ells (see picture), which helps greatly in the procedure. I also used the next largest size (0.18mm, and 0.23mm) for both valves, to make a kind of go-nogo two-gauge set for each valve (e.g., if 0.15mm drags, and 0.18mm doesn&#8217;t fit, then the intake valves are adjusted correctly.)<o:p></o:p>
    Procedure:<o:p></o:p>
    • The engine must be completely cool before checking valve clearances, so let the engine sit overnight.<o:p></o:p>
    • Remove the fuel tank. It will also help to remove the air duct. Because I was also doing some work on my carb, I had them out as well, so I had lots of room. Carb removal is nice, but probably not worth the trouble if you don&#8217;t need them out for some other reason.<o:p></o:p>
    • Remove the right-hand radiator mounting bolts and either remove or displace the radiator. I was able to get just enough clearance by displacing the radiator, and using a strap to keep it out of the way. Sure beats draining the system.<o:p></o:p>
    • Remove the crankcase hole cap and timing hole cap. Make certain the 10mm allen wrench you use to remove the large center plug is a tight fit. It's very easy to round off the hex hole in this cover since it's only aluminum. If you find you can't get the plug to budge - sometimes CAREFUL heating of the cover around the plug with a plumbers torch will help things separate. You could also try icing the plug to maximize the expansion difference between the plug and the cover....DO NOT OVERHEAT ! You might also try to break this plug loose with the bike warmed to operating temps before you tackle the job (if you do this, then make sure you allow the bike to completely cool down before adjusting the valves). Many have stated that these plugs can be very frustrating. I used penetrating oil on mine, and let them sit for about 30 minutes. They came off relatively easy.<o:p></o:p>
    • Remove the valve adjusting covers from the cylinder head covers. These are the long oval cover with two 8mm bolts holding it in place, and a round cover with a large 24mm bolt-head on top. The long oval cover covers the two intake valves, and the round cover is over the one exhaust valve. <o:p></o:p>
    • For the inspection and adjustment of the front cylinder head, rotate the flywheel counterclockwise to align the &#8220;FT&#8221; mark with the index notch on the left crankcase cover. It is easier to turn the engine over if you remove one or both sparkplugs (as for me, no way am I going to the hassle of removing the front-fore and the rear-aft sparkplugs). However, if it is about time to change the sparkplugs, now would be a very convenient time. Also, have a strong ligh to shine through the timing hole, and make sure you are stopping at the correct mark. In addition to &#8220;FT&#8221; and &#8220;RT&#8221; marks, there are other labeled marks on the flywheel that could potentially confuse you.<o:p></o:p>
    • Make sure the piston is at TDC (Top Dead Center) on the compression stroke. The service manual assumes everybody already knows how to do this. I didn&#8217;t, but here&#8217;s how. When the piston is at TDC, both the intake and exhaust valves will be closed. There will be some free movement between each rocker arm and the valve in all three valves (both intake and exhaust). If there is not, then the piston is not at TDC. If at FT mark and not TDC, rotate flywheel CCW through one full turn (360 degs) to get to TDC. Confirm that there is now freeplay in all rocker arms indicating that the engine is correctly positioned. <o:p></o:p>
    • Inspect the clearance of all three valves by inserting a feeler gauge between the adjusting screw and the valve. Intake valve inspection and adjustment requires two feeler gauges, one inserted between each adjusting screw and intake valve, because these valves share a common rocker arm. Proper clearance is indicated by a slight drag on the appropriate feeler gauge(s). Others have written that using the &#8220;slight drag&#8221; feeling can be overly dependent on prior experience or judgment, and can lead to leaving the clearances too loose. They recommend using a go &#8211; nogo technique, whereby if the proper size feeler gauge fits, but the next larger feeler gauge does not fit, then the valves are properly adjusted. I did this, and it was a good confirmation over the feel method. Also, I feel that you could get away with only having one set of gauges, and doing each intake valve separately.<o:p></o:p>
    • The Valve Clearance specs are: Intake &#8211; 0.15mm, Exhaust &#8211; 0.20mm. The Service Manual does not list tolerances.<o:p></o:p>
    • As mentioned above, a set of angled feeler gauges makes this job easier and much more accurate. You can't get the feeler gauge to fit exactly perpendicular to the gap with a standard straight gauge. The gauge gets bent and goes in on an angle. Normally this yields measurements a bit on the loose side. No bad thing. If you err at all....err on the "loose" side. The gauges look like this ( _/ ) in cross-section.<o:p></o:p>
    • Adjust by loosening the lock nut and turning the adjusting screw until there is a slight drag on the feeler gauge, or until the next larger feeler gauge will not fit between the screw and the valve. <o:p></o:p>
    • When the screw is adjusted to spec, hold the adjusting screw and tighten the lock nut. The service manual says to torque the locknut to 17 ft-lbs, but most won&#8217;t have a torque wrench that allows an open-ended wrench fitting (top access to the locknut is blocked by the need to hold the adjusting screw), so guesstimate as best you can. <o:p></o:p>
    • Expect the gap to change when you tighten down the lock nut. So...., RECHECK the gap after you've tightened the lock nut. If it got smaller you may have to set the gap a bit on the loose side, then tighten the lock nut and have the clearance close up to spec. Not all the adjusters will do this since it depends on how the parts are machined. Be ready for a bit of inconsistency here. Just recheck after the lock nut is tight. You may find you have to "play" with a certain adjuster multiple times before the locked-down gap is just right. In all, I had to adjust four out of my six valve clearances. The front exhaust valve took me nearly an hour. I just could not keep the adjusting screw from moving when tightening the lock screw. Part of this was due to the awkward and limited access to the valve. The other valves took only 5-10 minutes each to adjust, working carefully. A good tip is to hold the adjusting screw as firmly as you can when tightening the lock nuts. The barest movement may put your clearance out of spec. <o:p></o:p>
    • After adjusting all three valves on one cylinder, turn the engine CCW two full turns (720 degs), align the marks to TDC, and recheck the clearances. (Re)Adjust as necessary.<o:p></o:p>
    • Rear cylinder valve inspection and adjustment is done in the same way as the front. Rotate the flywheel CCW to align the &#8220;RT&#8221; mark with the index notch on the left crankcase cover. Make sure the piston is at TDC on the compression stroke. Access to these valves is better than the front cylinder (especially the exhaust valve.)<o:p></o:p>
    • Inspect and adjust the valve clearances.<o:p></o:p>
    • Check the o-rings of the valve adjusting covers for damage and replace if necessary. Install the front and rear valve adjusting covers.<o:p></o:p>
    • The manuals say to apply MoS2 paste grease (containing 40% or more moly) to the timing and crankcase hole caps. Install and tighten them. Others have indicated that other greases/pastes may work as well, such as antiseize grease. I used antiseize. Won&#8217;t have confirmation for how well that worked until the next valve job.<o:p></o:p>
    <o:p></o:p>
    All in all, not an overly difficult procedure, just a lot of prep work to get access to the ports. The hardest part: definitely working on the front exhaust valve. Access is a bit of a trial here. Also, you have the engine minorly open here, so make sure you keep ports plugged or covered when not working on it, and keep dust, debris, etc. away from the bike if you don&#8217;t want uglies to make their way into the cylinders.<o:p></o:p>
    <o:p></o:p>
    This is one of these jobs that I feel I can do better than the dealer. Sole reason is, the access can be limited, and the adjustment finicky, and I won't be (as) tempted to cut corners. Many shop mechanics, after having the adjusting screw move for the fifth time after tightening the nuts, will probably say F*** it, good enough, resulting in maybe having a valve or two marginally out of spec. When it&#8217;s your bike, you take the extra time to do it right.
    <o:p>Here's a set of my "homemade" feeler gauges.</o:p>
    <o:p></o:p>
    <o:p>[​IMG]</o:p>
    <o:p></o:p>
    <o:p></o:p>
    <o:p></o:p>
    <o:p></o:p>
    <o:p></o:p>
    <o:p>Here's an example of the flywheel just past the FT mark.</o:p>
    <o:p></o:p>
    <o:p></o:p>
    <o:p></o:p>
    <o:p></o:p>
    <o:p>[​IMG]</o:p>
    <o:p></o:p>
    <o:p>Here's a picture of the front exhaust valve, showing the adjusting screw, lock nut, and a strange glob of white substance that I have no idea what it is or how it got there. I was able to rub most of it off with alcohol.</o:p>
  2. BOBaloo22
    BOBaloo22 Tony & Catnis
    Aug 21, 2009
    4,464
    Orangeburgville, Va
    :thumb Palak, Thank you for taking the time to post this. I've been planning to check mine this winter and your notes will make my job easier.
    Thanks again,
    Bob
  3. KilgoreTrout
    KilgoreTrout adventure flyfisher
    Mar 23, 2009
    391
    Alberta Rockies
    Palak thanks for posting this. I have a new to me 87 Alp with 27000klms on it. It runs smooth now so I not going to fudge with it yet but I am wondering how much mileage you have on your bike so I will have an idea as to when I should be doing this procedure.
    Thanks again for posting this info.:clap
  4. Palak
    Palak Adventurer
    Dec 1, 2009
    93
    You have an '87 TA? Didn't realize Canada got them two years before the States. Or is it a Euro transplant?
    Service manual says that the valve clearances should be checked every 8000 miles.
  5. NordicRider
    NordicRider Been here awhile
    Dec 27, 2005
    125
    Denmark, Scandinavia
    ...I have been holding off on checking valves because of the access difficulties you describe, but am now ready to give it a go!
  6. KilgoreTrout
    Mar 23, 2009
    391
    Alberta Rockies
    Thanks for the info on the clearances, they were available here for two years 87,88 but very hard to find although not as rare as the Africa Twin which I do not believe was ever available here.:(: Thanks again for the info.
  7. Palak
    Palak Adventurer
    Dec 1, 2009
    93
    Don't let it put you off. It's a bit of a pain, but hurts a lot less than paying the dealer!
    I think I've done nearly every procedure in the Maintenance section of the Service Manual (plus a bunch of other stuff.) Thus far, the biggest pain in the necks, for me, have been changing the foremost front cylinder spark plug (zero visibility and limited access) and pulling the carbs off the bike after who knows how long they had been last pulled.
  8. jwb
    jwb Local minimum
    Jul 27, 2008
    342
    Oakland
    Hey, I am about to tackle this job on my '89 (50k miles, or maybe 150k; nobody knows, and none of the maintenance has ever been done, as far as I can tell). I have all the tools, even the 24mm, except I don't have an offset 10x12mm box wrench. Is the one in the toolkit good enough? Also, which end is it? 10mm or 12mm?
    Thanks in advance,
    jwb
    #8
  9. jwb
    jwb Local minimum
    Jul 27, 2008
    342
    Oakland
    So anyway, it's the 10mm, and the offset wrench in the toolkit is adequate. On the other hand, you really need a low-profile 24mm to get the cover off the front cylinder exhaust valve adjuster without whanging the frame. Also "displace the right radiator" is full of lulz.
    I think next time I need to do this I am going to fabricate a little wrench with 8 points for turning the adjusters. Turning them with plier, especially on the front cylinder with all the coolant hoses and the carbs in the way, is stupid.
    #9
  10. MookieBlaylock
    MookieBlaylock Long timer
    Feb 29, 2004
    2,584
    IntheeaglewingpalaceoftheQueenChinee
    I was intimidated but no longer, i will give this a go as i had planned to do plugs and jetting anyway. One question is when synching the carbs and plugging into the vacuume line that operates the petcock, does the bike still get fuel without this connected?
    #10
  11. R_Rick
    R_Rick Been here awhile
    Jul 31, 2010
    515
    Halifax, NS
    You will need to either rig up a fuel supply or make your petcock gravity flow and install a much longer fuel line .... the first doesn't require stripping the petcock apart.
    #11
  12. Santa
    Santa Focused on the Future
    Jul 12, 2001
    1,559
    Motion pro makes a great tool for this.
    I was able to locate just the one for the Honda. It works very well and is extremely simple to use.
    #12
  13. MookieBlaylock
    Feb 29, 2004
    2,584
    I ended up taking the cyl head covers off, but i got it measured and adjusted. They were all off by around .8, as in the .8 feeler wouldnt go in the intakes and .13 was stopped by the exhausts. Is that bad? I guess the indy mechanic who supposedly adjusted the valves a thousand miles ago ripped me off pretty good,oops.
    #13
  14. JBMorse
    JBMorse Been here awhile
    Jan 2, 2009
    279
    NH
    That's a great looking tool! I wish I'd seen it before I did mine. I used a little 4mm wrench from Craftsman (the one that only comes in a kit of tiny wrenches for which I have no use). It was very hard to hold with its tiny handle. I didn't have much confidence I was getting the clearances right so I checked them three times.
    #14
  15. jwb
    jwb Local minimum
    Jul 27, 2008
    342
    Oakland
    Mine didn't have any clearance on any of the six valves, and that's with the engine cold. No wonder it didn't have any power.
    Runs like a top now, though.
    #15
  16. jwb
    jwb Local minimum
    Jul 27, 2008
    342
    Oakland
    That tool looks completely brilliant. Shame that they insist on selling them in triplets, though. I wonder if I can find anyone who bought the set to get the 8mm, who wants to sell off the 10mm.
    #16
  17. jwb
    jwb Local minimum
    Jul 27, 2008
    342
    Oakland
    A good way to rig up fuel for syncing the carbs is with a hospital I.V. stand and a bottle of gas. It's perfect and you can hang the vacuum gauges from it too.
    #17
  18. SEA3PO
    SEA3PO Adventurer
    Nov 10, 2005
    61
    summer=Chester Ca. Winter=Camarillo Ca.
    I have 32,000 on my Transalp and the valves have never changed...I just che4cked them and they are spot on... but what a pain to check... I ended up buying a 15/16" crow foot wrench just to get the front exhaust plug off...that worked well once I had it...but what a pain just to check the valves.
    Joel
    #18
  19. jwb
    jwb Local minimum
    Jul 27, 2008
    342
    Oakland
    What model do you have? The front exhaust valve adjuster cover is, indeed the most irritating of the four, but I found that "displacing the right radiator" actually works. Remove the rock guard from the radiator and this works much much better. Note that you displace the radiator rearwards. Then you can reach it straight on with a 24mm open end wrench. There's not enough room between the engine and the frame for a box end wrench.
    Note that dismounting the carburetors makes adjustment of the intake valves much, much easier.
    That's on my '89 anyway. Your experience may vary.
    #19
  20. happyclam
    happyclam Been here awhile
    Apr 25, 2011
    253
    Mary Land
    Thanks Palak, Just did mine. It only has 6k miles on it and they all needed adjustment. Intake valves were way too tight. Maybe that explains the carbon biuld up on the exhaust? I didn't know what tdc was either, great reference. It'll be awhile before I test her, many phases to this project.
    #20
