Travel Trailers because (TTs, 5ers, pop-ups, A-frames and homebuilts welcome)
Discussion in 'Camping Toys' started by Hannda, Sep 27, 2017.
  1. Hannda
    Hannda Short, fat, bearded, old & slow
    Apr 27, 2005
    47,448
    Not yet far enough away from town
    When SWMBO and I were young this would have been perfect. Now I'd need to be single to use it, but it'd be a great TT if you drove a Tacoma, 4Runner, Frontier or Ridgeline.
  2. mslim
    mslim If it's worth doing... it's worth overdoing
    Jan 11, 2015
    1,500
    Austin of the Ozarks
    We used to to something similar to your spacers on small block Chevy steel valve covers to keep them from warping at the four hold down bolts.
    IADRTRIDER and ER70S-2 like this.
  3. BCC
    BCC I know better
    Jul 22, 2004
    17,349
    Central Florida
    Good friends of ours are also empty nesters. They wanted a larger trailer than the 17 footer they sold, and wanted it to be similar sized and somewhat comparable to the layout of our Airstream 27fb. I really like it. The video below has a somewhat annoying salesman, but it’s still a decent walk thru. They bought a 2019, but I think it’s essentially the same.
  4. hankgs
    hankgs Long timer
    Dec 2, 2005
    3,916
    Near Santa Babylon, CA
    Friend has one for sale in Ventura, CA
    Hannda likes this.
  5. WYO George
    WYO George I have no idea
    Sep 1, 2005
    6,361
    left of nowhere, WY
    My son has a bunch of friends over today and the nerf battle / screaming kids noises were starting to agitate me so I decided to retreat to the camper for some relaxation. I’ve spent the last hour untangling and restringing fishing rods while watching some quality TV. It’s 21 degrees out and snowing so this is about as close as it gets to camping for the next six months.
  6. Dfrnt
    Dfrnt Just pluggin' along Supporter
    May 27, 2007
    1,410
    Grass Lake, Michigan
    Saddest day of the season.
    1stgenfarmboy, Hannda, BCC and 2 others like this.
  7. BillMoore
    BillMoore Long timer Supporter
    Oct 21, 2011
    1,293
    Snohomish, WA
    Posted this a few hours ago in the Motorhome thread in Shiny Things, but just realized there might be more interest in it here since it is related more to towing...
    My WinnieVan came with the factory towing package with the 7 pin connector at the hitch, but no brake controller. We recently traded our little 5x8 cargo trailer for a new one that has brakes (and is color matched to the van), so I wanted to get a controller for the van. After reading up on it, I realized what a pain in the butt it is to add a brake controller to a Ford Transit that didn't come with the factory unit. There is no quick plug in harness available for it, you have to trace out the wires and tap into them.
    Because of this, I decided to go with the Tekonsha Prodigy 90250 RF controller. This controller mounts on the trailer, not the tow vehicle, and has a handheld controller that gets paired to it that plugs into a 12V outlet. Took about an hour total to find a good location to install it, drill the holes and hook it up, then pair the handheld unit and test it out. Works really well, and the beauty of it is that the brakes will work with any tow vehicle, just plug in the handheld unit and go. The brakes will work even without the handheld unit, you just lose the ability to manually brake and make adjustments to the settings.
    It was a little pricey at $280, but a lot less than it would have cost to get the factory unit installed (at least $500 in parts, and then a trip to the dealership to get it programmed for whatever that would cost), and a lot easier than figuring out where to tap wires for a hardwired aftermarket unit.
    Hannda, AlH, BCC and 3 others like this.
  8. AlH
    AlH Long timer
    May 8, 2015
    3,795
    SC/NC
    I've put brake controllers in 2 Transits, a 2015 and my current 2018. Both had factory towing packages, but not the optional controller.
    I spent hours trying to find the so called harness in my 2015. Finally decided there wasn't one. Ford later released a bulletin stating there wasn't one. Gee thanks Ford wasted a lot of my time when you don't even know what you built.
    Similar on my current 2018 found the harness inside using a tone tracer, it was not under the center console cup holder as Ford said.
    The connector was routed to an inaccessible spot high up on the firewall in front of the glove box.
    Would take major disassembly to find it.
    In both cases I found the only connection you need to made inside is the brake light switch.
    All the other connections can be made under the hood- and in fact there IS a factory pigtail available if you have the towing package. Some Transits come with it in the glovebox, most don't. Doesn't help to have the pigtail if the mating plug is buried 2 hours up under the dash- maybe.
    Knowing what I know now I could probably do a third in under an hour. Why Ford makes it such a PITA is a mystery.
    Still even with all the little foul up's I love my Transit.
    BillMoore likes this.
  9. Bueller
    Bueller Cashin? Super Supporter
    Sep 25, 2003
    20,271
    Hide Away Hills, Ohio
    I feel for all who are done for the next few months. We get 1-3 inches of snow tonight, cold tomorrow, but then temperatures will moderate. Just in time for the drive to FL, which happens in 11 days. I can hardly wait. We will stay until the snow and road salt are gone some time in April, though I do have to make a couple of short trips back this winter for various things.
    Fuck winter :finger
  10. Maggot12
    Maggot12 U'mmmm yeaah!!
    Feb 21, 2010
    19,933
    Canada's ocean playground
    Will you be rv'ing the whole time. Moving around?
    Bueller likes this.
  11. Bueller
    Sep 25, 2003
    20,271
    We have one home base, a small RV park/nine hole golf course. The place has about 55 spots, most of the RV’s are permanent, many of the residents are full time. The few transient spots are almost always occupied. We got lucky finding this place. Affordable, clean, and the people are really great.
    We will take a few two wheeled trips to visit friends, watch rocket launches, and hopefully spend a weekend in the keys, but the RV will stay at the park.
    Maggot12 likes this.
  12. Daniii
    Daniii geezer Super Supporter
    Sep 29, 2005
    40,502
    Plano Tx
    We are headed south on the 25th. T-Day at my sister's in Sarasota, Next weekend with mom in Stuart. Gonna have to get out the electric heaters for the RV tonight - supposed to get into the mid 20's early tomorrow morning. It's always a roulette game with not winterizing. I'll turn on the 100W trouble light in the pump compartment, turn on the water heater, run a second 115 VAC line to the RV for a second 1500 W electric heater and open the cupboards. We'll take our time heading down and back.
    Bueller likes this.
  13. FTL900
    FTL900 White and nerdy
    Oct 3, 2005
    1,270
    Las Vegas
    I used to do that with a 19 foot boat in Atlanta... it was too big for the garage, so I covered it and then on freeze nights, I'd put a drop light into the engine bay. It worked great through several inches of snow.
  14. Hannda
    Apr 27, 2005
    47,448
    Quigley Down Under or one of the Sackett movies? Regardless, the temps you're watching are far warmer than the temps you're living. I like the way you think.:thumb
    IADRTRIDER, ER70S-2 and WYO George like this.
  15. WYO George
    Sep 1, 2005
    6,361
    left of nowhere, WY
    Quigley was correct. One of my favorites. Usually I watch it while cleaning my Sharps, but since I haven’t shot the Sharps lately I just watched it while restringing fishing rods.
  16. Hannda
    Apr 27, 2005
    47,448
    Is that you, Roy?
    :lol3
    ETA: Wouldn't it be more fun if you were having this discussion with the inmate named "adingoatemybaby" instead of me?
  17. WVhillbilly
    WVhillbilly Long timer
    Oct 20, 2010
    40,002
    WV
    ER70S-2, Hannda and MikeFromMT like this.
  18. AlH
    AlH Long timer
    May 8, 2015
    3,795
    SC/NC
    Naaahh doesn't look good to me.
    He didn't hook up the safety chains- other than that no problem:lol3
    ER70S-2 and Hannda like this.
  19. Hannda
    Apr 27, 2005
    47,448
    :yikes Wow, just wow.
    But just think of all the things he can now fit in the bed.
    IADRTRIDER likes this.
  20. WYO George
    Sep 1, 2005
    6,361
    left of nowhere, WY
    The way I see it he has three ball mounts / adapters rated at 1,000 pounds each so he’s obviously good for 3,000 pounds of tongue weight....
    Kenny M., goosecreek, ER70S-2 and 3 others like this.
