Trial's rigs to get to the event
Discussion in 'Trials' started by mung, Nov 28, 2017.
  1. Norman Foley
    Norman Foley Devotee of the Husqvarna Supporter
    Mar 20, 2004
    4,201
    New York... The Finger Lakes
    Ian@3D, North ride, riabma77 and 2 others like this.
  2. Norman Foley
    Mar 20, 2004
    4,201
    480BBE73-11F2-493A-A6F8-8EAF9072F15F.jpeg 480BBE73-11F2-493A-A6F8-8EAF9072F15F.jpeg
    jonnyc21 likes this.
  3. Norman Foley
    Mar 20, 2004
    4,201
  4. Brewtus
    Brewtus Buffoonery, Inc.
    Jul 30, 2008
    7,286
    Portales, New Mexico
    I've towed thousands of miles with Trials bikes in the back of various trailers. Never had problem one with bolts backing out. YMMV.
    Norman Foley likes this.
  5. lineaway
    lineaway Long timer
    Oct 1, 2011
    11,322
    nm
    And I have pulled his trailer home. Luckily he loads them well.:imaposer
    Brewtus and LemmeTry like this.
  6. DyrWolf
    DyrWolf Long timer Supporter
    Jan 21, 2012
    2,713
    RICHMOND VA
    F5963BA0-9E24-456C-B03A-1DA763FA2383.jpeg 928D3C49-4F8B-4E1C-912C-49EE1A3B96B4.jpeg Check this out. I never saw one before F7E47525-F6EB-4E49-B032-8FECB63B31D2.jpeg
  7. jonnyc21
    jonnyc21 Trials Ninja
    Feb 8, 2011
    3,950
    Boise aria
    For years I have been using a small trailer for our bikes, not a bolt loose yet. Thou I will echo lineaway with be good about the straps, have had a strap come loose once and the bikes where rubbing against each other.
    LemmeTry likes this.
  8. riabma77
    riabma77 Been here awhile
    Nov 29, 2018
    425
    Ruidoso, NM
  9. North ride
    North ride Long timer
    Jul 10, 2017
    3,225
    Nwt Canada
    Nope every time I go to a event I do 5000 km return in this trailer no issues. But for the long hauls I put the bikes on stands and turn buckle the foot pegs to the floor as I don't like the idea of the suspension cycling up and down for all those hours.
    DyrWolf, LemmeTry, jonnyc21 and 3 others like this.
  10. Junglejeff1
    Junglejeff1 Long timer
    Oct 20, 2016
    4,626
    Upper Michigan
    Can you give me some info on the hitch set up.I would like to set my Africa twin up to tow my trials bike.So far have not found a hitch kit for AT.
  11. jonnyc21
    Feb 8, 2011
    3,950
    Boise aria
    Well, this isn't my bike or setup, however... I had a custom hitch and trailer I built with my brother for my 04 BMW R1100S. It was quite a bit of work to get it well sorted...
    On that note, I doubt you will find a hitch setup for an Africa Twin as most bike hitch's for anything but large touring bikes (Think Honda Goldwing) are usually custom built... I also wouldn't suggest towing much of a load without a very custom trailer with some kind of brakes as anything more than backpack type camping gear on a smaller bike will push you around something dreadful in an emergency braking situation.
    Though I admit I would be willing to do it again on a large BMW R1200GS or the like to be able to get a setup like this. Though it would be quite a change over what I had with my R1100S.
    Junglejeff1 likes this.
  12. markbxr400
    markbxr400 Been here awhile Supporter
    Sep 26, 2016
    633
    Lower Alabama
    Norman - tell us about the front wheel chock in this pic. Sure would come in handy in my toy hauler, and when I have a 3rd trials bike backwards in my truck bed. Thx
  13. Norman Foley
    Mar 20, 2004
    4,201
    It's the wheel chock that came with my Sprinter. I use that or a 2X4 I cut to fit across the back door opening.
    markbxr400 likes this.
  14. Norman Foley
    Mar 20, 2004
    4,201
    Trials transport, 1936 style. Photo: C.H. Wood (David Wood Archive Bradford, England)
    I found this in the Scott Trial section of the Trials Guru website.
    DyrWolf, Huzband, Bucho and 9 others like this.
  15. LemmeTry
    LemmeTry Over-thinker...
    Jan 27, 2016
    323
    Bozeman, MT
    DyrWolf likes this.
  16. jonnyc21
    Feb 8, 2011
    3,950
    Boise aria
    I know someone that used one for a time on a Gas Gas trials bike.
    Short version would be maybe a 3 out of 5 star rating.
    What he thought: His comment to me was that it is a great concept but for trials bike they end up being to tall and don't put enough pressure on the suspension to really lock it in place well. I remember him wrapping a tie down over the bike every time he loaded it and cinch it up over the center of the bike to give it more security for travel.
    I don't remember him ever saying it came loose without the strap, but then again I don't think he ever used it on a trials bike of any brand without the extra strap.
    My two cents would be that if I was to do something like this, I would make my own stand and use a set of turnbuckles or something else attached to some adjustable mounting rails.
  17. Brewtus
    Jul 30, 2008
    7,286
    Sooo... Maybe sorta Trials related, but here goes.
    I've missed my rusty, leaking Abductor Van over the years. It burned up (down) a head gasket 2 weeks before we moved to Hooterville, and took out the cylinder head/engine block with it. :bluduh I figured that I would get it fixed right after the move was done.
    That was 3 years ago.
    I recently acquired a running 360, just had "a blown head gasket". Yeah right, the blown head gasket turned out to be a broken #8 exhaust pushrod, jammed tightly into it's broken lifter -
    With the corresponding #8 intake pushrod jammed into it's rocker arm....
    Yet.... The pistons are all tight in their standard bores, and all the valves are sitting happily on top of their seats. I'm thinking a ring/bearing/gasket refresh, along with a new camshaft will have Brewtus' Abductor on the road again! :D
    DyrWolf, Yinzer Moto, Huzband and 4 others like this.
  18. Paul7
    Paul7 Been here awhile
    Jul 20, 2016
    232
    VA
    No bent valve?
  19. Brewtus
    Jul 30, 2008
    7,286
    I was expecting one (or worse), but nope! The pushrods/rocker arm took the bullet. :thumb
    Paul7 and Norman Foley like this.
  20. ridenm
    ridenm Missing my emotional support squirrel Supporter
    Jan 18, 2010
    9,704
    Carnuel, NM USA
    Usually it's the expensive parts that fail protecting the cheap ones...
    Brewtus, 2whlrcr, FASTRacing and 2 others like this.
