    Dismiss Notice
TRIOM headlights LED replacement ?
Discussion in 'Equipment' started by *kartman*, Jan 7, 2016.
  1. *kartman*
    *kartman* GO Bacon GO !
    Dec 29, 2008
    1,037
    Cottbus, Germany
    Hi there fellow Advriders !
    On my Rally KTM is mounted such a horribe TRIOM 2x35W headlight ... As I may want to participate at the Hardalpitour, I definately need better headlights ! Can anybody of you may recommend me a good solution, that will fit with just little adjustments ? It should be a double LED headlight, I know there are some nice products from the rally scene ... but which one to take ?
    Best, Martin
  2. Droptarotter
    Droptarotter Long timer
    Jul 11, 2007
    2,288
    Cloverdale,BC
    Kartman;
    This is what I did with my 640.......a 60mm Hella HID and a Baja Designs Squadron Pro......it was quite a bit of work for the install, but well worth it.
  3. *kartman*
    Dec 29, 2008
    1,037
    Cottbus, Germany
    Ok, I´ll have a look for them.
    The original Adventure lens headlight is not bad at all ... are you new headlights much better ?
  4. shrederscott
    shrederscott Long timer
    Mar 19, 2014
    2,769
    denver
    Hi
    I run the baja design squadron on my ktm 530...it ROCKS
    scott
  5. *kartman*
    Dec 29, 2008
    1,037
    Cottbus, Germany
    Lyndon Poskitt has also mounted the Baja Squadron and Hella HID on his bike. I will have a look, Hella for low beam and the other for high beam ...
  6. shrederscott
    Mar 19, 2014
    2,769
    denver
    Why
    One squadron is a LOT of light.
    But if you feel the need for 2.
    Baja design makes a race dual squadron kit too
    From my experience. ..one squadron WITH a high output helmet light is the way to go.
    Off road helmet lights + bike mount light.....no question works better than any bike mount only light (s)
    Off road best is to have both
    Scott
  7. *kartman*
    Dec 29, 2008
    1,037
    Cottbus, Germany
    I don´t think the Squadron is legal as a low beam, is it ?
    The Hella would be for a DOT approved low beam in normal Traffic.
    I need two lights anyway for my 660 RR. But I could also use one of my broken TRIOM headlights (one glass gone) and insert the Squadron on the other side ...
  8. shrederscott
    Mar 19, 2014
    2,769
    denver
    Hi
    Check your headlight, do you see a DOT stamp on it ?
    Bet, you could not find one.
    I run the squadron XL as my sole light on my street legal ktm. I use a dimmer, and have it aimed down....it still throws light a LONG ways down the road, and is very wide.
    Dimmer is set to 70% power for low beam, and 100% for high beam....toggles back and forth with my my standard high/low, turn, horn switch.
    Also keep in mind the squadron light encompasses multiple models, and there are big weight, size, light output and light pattern differences between models.
    I run the XL, it is the biggest, heaviest, and has the highest light output, with 3 different light pattern lens standard ....long range, wide, and combo.....I run the combo lens, works GREAT.
    It would be nice have a DOT light pattern, but it is not needed.
    As many DOT lights, do not have a DOT stamp...how can a cop tell the difference?
    scott
    #8
  9. *kartman*
    Dec 29, 2008
    1,037
    Cottbus, Germany
    My lights habe various marks like "E13" and other E-Numbers. This is mandatory in germany / europe :(
    That´s why I just can use the other lights as addition.
    #9
    DonM likes this.
  10. *kartman*
    Dec 29, 2008
    1,037
    Cottbus, Germany
    #10
  11. Droptarotter
    Jul 11, 2007
    2,288
    Cloverdale,BC
    Martin;
    My headlights are spectacular........I can now run at 100kmh and actually see far down the road.
    I went this route for a couple of reasons......
    -Hella low beam is DOT. 35W HID
    -Squadron is not DOT
    - Both high and low beam on at the same time.
    - Lights draw 77W on high beam
    -Wanted to run a 2 light system.....if you just run one squadron as suggested and it quits, you have no light at all. Rare, but it has happened.
    - Hella bulb easy to replace
    -You can dim the Squadron, but the light pattern can still be blinding for oncoming traffic
    Don't get me wrong, the Squadron is a fantastic light and certainly has it's place. One of the reasons I chose this system is that Britannia Composites uses the same set up and he is very close to me, so I was able to pick up the lights and a wire harness that made installation simple.
    Go here for info.....
    http://www.britanniacomposites.com/index.php/productmenu/lynx-r
    Hope this helps.
    #11
    *kartman* likes this.
  12. *kartman*
    Dec 29, 2008
    1,037
    Cottbus, Germany
    #12
  13. HaRRuK
    HaRRuK n00b
    Jun 11, 2013
    5
    Amsterdam
    Hi Martin, all, what is the brand and type of the headlights above? I find them great and they fit ;)
    #13
